Question about Bissell 8910 ProHeat Clear View Upright Vacuum
Motor shaft/Brush pulley
I have a Bissell Proheat that I borrowed from my mom. I noticed that the brush belt had came off. When I went to put it back on I noticed the silver pulley that the brush belt goes on has came unattached from the red piece by the motor belt. Does any know how I can fix this or reattached to the red piece? We have tried everything at home to fix it or to figure out how the silver pulley attaches to the red piece. Thankyou
  • dolores4321 Apr 26, 2008
    Im having the same problem with a proheat 8910..Does anyone know how to fix it..
    Thanks
  • heathergr974 Jul 16, 2008
    i tried everything to put to pulley back and nothing works. I even called Bissell and they said it has to be carried to a repair shop.
  • 5 Answers
It cant be repaired you have to order a new pump @http://www.vacuums24x7.com/bistclpa.html
Bi-010-7185 $23.99 or bring it in for repair.
Has anyone tried liquid steel filler?
Posted on Sep 10, 2008
    Scholar:
  • 74 Answers
Hiya tool girl...any chance of you posting a pic of the part.. and which model is it?
ProHeat 2X 9200-E or the ProHeat Clearview 1698M
Let Me know please!
Regards Faggly
Posted on Mar 19, 2008
Brush won't spin. Put it back on the ribbed belt
Make sure the driving motor (power on) is turning (without the belt attached). Make sure the brush turns freely when the belt is off (it's probably jammed with wound-up hair, thread, and other debris--remove the brush and clean/lightly oil the bearings). Check the tension of the belt which should be fairly firm--replace if sloppy. Rotate the motor shaft by hand when everything is back together and make sure the brush can be driven without the belt trying to jump off. Hope this helps!
Mar 03, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell Proheat Shampooer
Take off belt cover on the left side of the top cover, turn cleaner over, take out screw from red lock and remove, pull cap and brush roll out, unhook the cogged belt, then you can replace the pump belt thru that opening. Put belt over the pump pulley and stretched to go over the motor shaft. Then check the cogged belt and the cogged end of the pully to make sure that there are cogs, replace belt if there are cogss missing or belt is broke, if no cogs on the pulley, then you will have to replace the pump. Pulley only comes witht he pump.
Jul 03, 2008 | Bissell 1699 ProHeat Clear View Upright...
Brush Motor Replacement
This the number for the brush roll motor, 2036757, is it the one you got? I don't remember having to remove the pulley, I am thinking that the pulley is on the new motor. The 8920 is a good number? Where you on the Bissell site, or some other site.
May 11, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
How to change pump belt on bissell pro heat
First take off the cover on the left side oif the top cover, then turn it over, remove the screw holding the red lock and pull the cap and brush roll out, remove the cap, remove the cogged belt, then you can put the new pump belt thru that slot, put over the pulley on the pump and then stretch it to go over the motor shaft. Then put back together.
May 05, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
How to fit new drive belt
May 02, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Belt
First take off the cover on the left side of the top cover, then turn it over, remove the screw holding the red lock and pull the cap and brush roll out, remove the cap, remove the cogged belt, then you can put the new pump belt thru that slot, put over the pulley on the pump and then stretch it to go over the motor shaft. Then put back together.
Feb 13, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell Proheat 2x Series 8920 - Brush Belt Metal Shaft Sprocket won't turn
Most likely the brush motor is bad and not turning, part #2036757, would sell for around $23. To get to it, start taking out screws on the top cover, that motor is under the that top access cover.
Jan 22, 2008 | Bissell 8910 ProHeat Clear View Upright...
Belt removal Bissel PowerSteam ProHeat
Jan 18, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Smelled like rubber burning
First take off the cover on the left side oif the top cover, then turn it over, remove the screw holding the red lock and put the cap and brush roll out, remove the cap, remove the cogged belt, then you can put the new pump belt thru that slot, put over the pulley on the pump and then stretch it to go over the motor shaft. Then put back together.
Dec 14, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Power brush on Green Bissell power steamer
Take off belt cover on the left side of the top cover, turn cleaner over, take out screw from red lock and remove, pull cap and brush roll out, unhook the cogged belt, then you can replace the pump thru that opening. Put belt over the pump pulley and stretched to go over the motor shaft. Then check the cogged belt and the cogged end of the pully to make sure that there are cogs, replace belt if there are cogss missing or belt is broke, if no cogs on the pulley, then you will have to replace the pump. Pulley only comes witht he pump.
Sep 24, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 8910 ProHeat Clear View Upright Vacuum Logo
272 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
