I cant install Computer Speakers can someone help me? I have taken speaker wire out of port over and over again and nothing happens.
    Scholar:
  • 101 Answers
First of all check your wiring is right. If you have a pair of speakers they need power so they should have a wire which goes into the electrical supply. Then they need to be connected to each other and thirdly they need to be connected via a wire probably green-tipped into a port on your computer. Probably green also. Once all these wires are in you can test them.
Find a CD or something and see if it will play. If not you need to go into control panel. Click start and find the control panel. You can type the word "control" in the "run" or "search" option if you want to(depends on whether you have XP or Vista) Look for your sound options. They may be set to mute or no-sounds. Enable them and your speakers should work. Also check that your volume is up......obviously :)
Posted on Mar 22, 2008
I keep hear noises through my computer speakers that sounds like a camera shutter, it is not constant, nor does it happen regularily or when I do anything particular. Just every nor and again I hear the...
It sounds like you have interference coming into your speakers that has nothing to do with your computer or any software. Do you have a modem or router or anything with BLINKING LIGHTS nearby? Less likely problems are disc players, tape players or anything with a motor, even the little ones that pull in and push out the discs.
The best way to troubleshoot is to move each piece of equipment you have within say, 10 feet of you speakers, the lead wires, or even the amp, and see which one makes it go away.
Mar 09, 2012 | Audio Players & Recorders
My speakers are plugged in, the error messae sounds are coming through the speakers but the sounds and audio devices say there is nothing plugged in and any media players say the same. I can't find any...
look in the control panel for sounds and audio devices, if the error sounds are coming through, then the speakers are working, leave them plugged into that port, check your speaker configuration setting try setting it to stereo speakers. It also sounds like you may have it set to 5.1 and are only hearing the rear audio channel. problem being your two speakers connected to a 5 - 6 speaker configuration. Again, solved by setting the speaker configuration to 2 speakers (stereo) . Let me know the outcome. Thanks
Aug 27, 2010 | Computers & Internet
Cant get any sound from my dell speakers
There are 3 audio drivers from Dell HERE Download and install the one that matches your sound card, if you are not sure which one, try them until you find one that works!
May 11, 2010 | Dell A215 Computer Speakers
Cant figure out why my protect LED indicators continue to go on.. Why is this happening?
disconnect speakers at the amp, turn unit on, if it goes into protect, it needs service. If it stays on, re-connect speaker wires without speakers attatched at the other side and test again. (make sure wires are separated and not touching metal!) if it stays on still, check speakers one by one, when it goes into protection, you have found your problem. Disconnect the bad speaker and test again. Process of elimination. It can only be one of three things. Internal amp problem(nothing connected and protection) wires(no speakers connected and protection) or speaker(s) (when speaker connected,protection) Hope this helps. If you need deeper troubleshooting with this issue, post a comment and I can help you further.
Nov 04, 2009 | Nady Systems XA-900 Amplifier
Using headfones while having rear ports for speakers
This MotherBoard has a special software that comes with it to handle all the sound related stuff. If you install this program it should be easy to control the sound then.
Mar 01, 2009 | MSI K8MM-V Motherboard
I moved, and now my speakers won't work
check for the power button is on behind the woofer or speaker,if ur speakers does not have switch hten select the volume control optin and click the properties and check the sounds by clicking the speaker images in that window.if u have problem again,askme through fixya again.
Aug 16, 2008 | AOpen MS-810 Computer Speakers
Speeker problems
suggestion 1: Find out from your computer whether the audio output device is properly installed. Try re installing it.
Suggestion 2: Check the wire connections or the connection port jack.
Mar 15, 2008 | Acer 90.00012.30B Computer Speakers
How do i know where the grren cord goes, there is 2 different green slots and i tryed both of them
Hi, itryed
Well, first thing first! you mean, someone Format your computer? if so. Just see in device manager if the person install the correct drivers for yous specific sound card . (device manager) if not install them from the CD that is drivers for your computer. (sound)
then put the cables and check!
that should do the trick
Nov 19, 2007 | Ozaki DT-500 3-Piece Speaker System...
Help needed for speakers
lo-ve stated: but i cant still get to it in my windows system1.gif and sound options. But there's nothing there.
If there's nothing there your computer can't find a sound card!
blue
Feb 06, 2007 | Creative Labs Inspire 2500 Computer...
88 people viewed this question
 Grubhead
Grubhead
