Question about Epson RX620 All-In-One InkJet Photo Printer
Epson R1800 printer won't recognize new ink cartridge
I replaced two cartridges at the same time - yellow and light magenta - with genuine Epson cartridges. The printer recognizes the yellow, but refuses to recognize the light magenta. I don't have another one to replace it and must order it. What can I do to get this one to work?
AAArrrgh. yep same problem for me only it's the yellow. I just want to print something with black ink which I have plenty of.
I have an epson rx620 and am using epson ink.
I tried cleaning the contacts and powering down.... no luck.
5 Suggested Answers
tom19511
  • 1601 Answers
SOURCE: Epson R260 ink cartridge problem (yes, with the genuine Epson ink)
Try this:
http://er.epson.com:8001/start
Posted on Feb 20, 2008
Basti
  • 1447 Answers
SOURCE: HELP !!!! Instantly empty INK CARTRIDGES Epson Stylus Photo R1800
Hi
What i can recommend is call epson and tell them about this issue and for sure they are going to replace the ink and will run diagnostic test on your printer- here is there support line number 562-276-1300
Posted on Apr 02, 2008
SOURCE: Epson R1800 printer won't recognize new ink cartridge
ughhhh I'm having the same problem... STUPID MAGENTA
Posted on Oct 13, 2008
Basti
  • 1447 Answers
SOURCE: Epson R1800 with magenta blinking ,and wont recognize the said ink
Hi-
Try reseating all the ink cartridge, make sure you have the right cartridge for each slot and make sure all are genuine epson in. try another magenta ink as well if you have a spare. if all fails call epson at 5622761300.
Hope this helps
Posted on Nov 08, 2008
Epson 1400 not recognizing an epson ink cartridge
not necessarily faulty cartridge - had same problem went thru various cartridges some worked some didn't - in fact they weren't epson - so bought epson from office depot and that would not work, so not an issue of ink dried up - if yr printer is fairly old may be easier just to replace rather than waste time and money on trying to figure out problem
Sep 13, 2013 | Epson Stylus Office Equipment & Supplies
Epson Stylus Photo R220 Ink Jet Printer won't print with new ink cartridges
Silly question: Did you remove the plastic tape from the bottom of the cartridges when you installed them?
Apr 30, 2012 | Epson Stylus Photo R220 InkJet Printer
Hi. My printer will not recognize the magenta ink. I tried replacing it with 3 different new ink cartridges, but when I try to make the printer charge the new ink, it does nothing and says I'm out of...
Hi
Some ink printer had ink resetter and just go to ink set up.
If your printer have ink resetter, do it otherwise it will not recognized new ink installed.
If not, some new ink cartridge when the tape is remove, there are cases that the sticky leaf on the ink cartridge, just rinse it with warm water or alcohol to detect the ink cartridge. Turn off your printer and your computer. Then return the ink and open your printer and computer to print again.
Note : Use only ink that is compatible with your printer because it you use other cartridge it will damage the chip set of your printer and it will not recognized any cartridge at all. SO beware.
I hope it helps you.
Jan 12, 2011 | Epson Stylus Photo R1800 InkJet Printer
1400 deos not recognize my light magenta ink cartridge. I have installed two brand new cartridges and neither is recognized. What can I do?
Are you using Genunine Cartridges!!!!
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 31, 2010 | Epson Office Equipment & Supplies
My printer has a new ink cartridge but does not recognize the ink
What model printer do you have and can you list the print cartridge?
Also have you selected on the onboard printer menu that you have inserted a new cartridge?
Jul 28, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Hi-
Hope this helps
Nov 08, 2008 | Epson Stylus Photo R1800 InkJet Printer
Hi
Apr 01, 2008 | Epson Stylus Photo R1800 InkJet Printer
You can remove magenta & double check that some tape was not left behind on the contacts. Take a clean ragg & dampen it with alcohol. Clean the ink cartridge's (copper contacts & inside the the ink carrige). Re-install the magenta, (tight fit). Power off the printer. Wait a few seconds & power it back up. If it fails a second time with no other errors. Like the above. Than the magenta may be defective. Have a recipt? Return it for a replacment.
Feb 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson RX620 All-In-One InkJet Photo Printer Logo
115 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
