Question about Vacuums
Does not **** properly - Vacuums
  • 168 Answers
Check all filters. Some of the newer vacuum cleaners have up to 3 filters that need to be cleaned and or replaced. Motor filter, Hepa Filter, and or Air Filter.
Make sure there isn't any clogs in any part of the hoses and or tubes.
Other than that... pretty basic. Motor sucks air through the filter, then through the hoses.
Good luck.
Hope this helps.
Mac
If this has helped, please rate my answer.
Posted on Mar 19, 2008
Kirby won't power on
Make sure the bag emptor is on all the way, it pushes on a lever on the switch that must be engaged. The hose or nozzle housing also pushes in on the switch that must be engaged properly. Make sure the cord is carrying proper voltage and cord inserted into vacuum properly.
Feb 12, 2017 | Kirby Vacuums
I have a Kirby Ultimate G Diamond Series upright. When I plug it in it will not come on. Bought new in 2004.
First make sure the hose or nozzle is installed properly so the switch lever is pushed in all the way. Then check the bag emptor to make sure it is pushed all the way in to engage the switch lever. Both of those are safety features so your machine will not run if they are not properly engaged. If they are correct then check your power cord to make sure it is working properly.
Dec 29, 2014 | Vacuums
Electrolux 2100 vacuum
Electrolux has had this issue across all tank machines for years and it has to do with the orientation of the bag. The bags are model specific and must be installed properly. Consult your manual for the proper filter bags and how to install them. The door on the bag will pop open and shut down the machine if the bags are not the proper ones and don't fit precisely. It is supposed to be a safety feature but it annoys the devil out of people and has for years. Their machines are very powerful and well made, but if the bag does not seal properly around the hose inlet or the gasket around the door and bag chamber leak, then you will have this happen.
Nov 20, 2017 | Vacuums
Roller assembly will not go back together
Usually belts do not come off unless something is worn. If your
Riccar is used heavily or is over 5-10 old (depending on use) it may have a worn pivot point or motor mount. Both are inexpensive parts that will wear after years of use. If your belt is over 6-12 months old it may have lost elasticity. The brush roll end cap must be installed in the proper position and the clutch activation lever must be installed properly to work properly. You have a very durable long lasting vacuum but it does need occasional service to work properly. It may save money in the long run to have it serviced by your dealer if it's been a while.
Dec 21, 2013 | Riccar 8000 8900 Series Metal Agitator...
When the brush is on it won't **** properly
Look for blockage carefully as the unit does not know which you have attached.
Dec 05, 2012 | Miele S7210 Bagged Upright Vacuum
My dyson dc animal's brush is not spinning. The machine smells like burning rubber. I believe the clutch has gone out but the machine also only sucks from the top of the hose in the handle. I am...
Replace the belts in the clutch or replace the entire clutch assembly. Burning rubber smell usually indicates a stretched out belt.
I don't understand what you mean by it's not locking properly. The brush will not spin unless you have the clutch lever in the proper position and then recline the handle into the vacuuming mode.
You may have something restricting the changeover valve from operation properly. Your model is not easy to diagnose problems without being able to inspect and analyze it thoroughly.
Oct 19, 2017 | Dyson DC14 Animal Bagless Upright Cyclonic...
Our vacuum cleaner is not getting proper suction and not collecting anything in the proper place. Why am I having this problem?
Have you checked to see if the belt is broken, or perhaps just stretched out to the point its not properly spinning the brushroller underneath the head of the unit?
Jan 15, 2011 | Eureka Altima Upright Vacuum Model 2996AVS...
Hello, we have a Miele cat and dog turbo 5000 vacuum cleaner which we bought in December. It has just started blowing air out of the grid on the top of the cleaner instead of sucking from the tube. The...
The lid not closing properly is almost certainly the cause of your problem. Without that lid sealed tight to the body you will get no suction through the hose. So, the question is: why isn't the lid clipping down properly? Did you just change the bag? You need to check that the bag is properly located and that there's nothing getting caught where it shouldn't be. Get the lid closing properly and your problem should be solved. Good luck!
Dec 29, 2009 | Vacuums
Not working on the carpet
did u clean the filter above the dirt cup?
Sep 16, 2008 | Bissell 6590 CleanView Bagless Upright...
Vacuums Logo
69 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
