Question about HP Photosmart 2610 All-In-One InkJet Printer
HP Photosmart 2610 error message
I get an error that comes on intermittently. I usually have to turn the printer on and off to get it to work again. The error reads like this: error:0x887dd03a. Then below that I get this: 1: ?? Can anyone help me with this?
  • 1 more comment
  • Anonymous Apr 01, 2008
    0x887dd03a
    1:??
    Here also.
  • ThunderHull Oct 07, 2008
    It started happening after I installed HP All-In-One drivers for VIsta home 64-bit network printer
  • godfrey_port Nov 24, 2008
    I get the same error on my hp photosmart 2610:
    error 0x887dd03a
    1:??
    The error occurs overnight with no computers powered on and no printing taking place. Only the wired router (Linksys BEFSR81) and printer remain on overnight. I reset the printer in the morning but overnight the error reappears. This error occurs on a home network with win XP, win 98, and mac OS 10.4 computers and never during printing.
    Problem Solver:
  • 11 Answers
Turn off your printer. Look in My Computer for any HP Memory card icons. Right-click on them and disconnect all that you see.
Posted on Mar 19, 2008
You don't know how much time I wasted trying to figure out what the answer to this problem was. Wadhah solution worked like a charm. Question is how do these HP memory card icons get there in the first place?? This was crashing the printer and freezing any application that tried to monitor system servics - like HP diagnostics, Intel D975XBX2 system board utilities, COMODO firewall and two virus checkers. Thanks a million!
Posted on Jan 07, 2009
This solution fixed the problem - Thanks !
Posted on Jul 11, 2008
    New Friend:
Hp error 0x887dd03a:
easy fixed ! - use an old+cheap SD-card in one of the 2610 slot´s and restart again - done ; )
worked well for my 2610 printer
Posted on May 09, 2016
If the HP SD Card solution didn't help you, or you didn't find any, then goto Start -> search for "hp update." Click it, then wait for it to update. While doing this, you may want to change the installation directory to a permanent directory. (see the last answer on http://h30434.www3.hp.com/t5/Printer-All-in-One-Software/HPPhotosmartEssential-msi/td-p/36303/page/4 ).
Posted on Feb 05, 2012
  • Sauj123 Feb 16, 2012
    If that solution didn't work, and you often switch off your printer to save energy, then try this:
    1. Turn off your HP printer.
    2. Cancel all of the documents linking to that HP printer.
    3. Turn on the HP printer and then wait for it to boot.
    4. Print your documents.
I eventually had to adopt an alternative solution I'd read about - put an SD card into the slot. Then, under My Computer, disconnect the (typically Z) drive with the printer attached.You can remove the SD card once the drive has been disconnected.
Posted on Nov 20, 2009
My HP Photosmart 2610 won't recognise compatible cartridges, help
You can try buffing the contacts gently but this happens quite often with generic cartriges sometimes they just don't work. Contact the vendor and explain the issue, I reckon you'll find that they're fairly used to this problem and will request a return for a refund.
May 31, 2010 | HP Photosmart 2610 All-In-One InkJet...
Scanner does not work- photosmart 2610
You can obtain the drivers from the following link
ftp://ftp.hp.com/pub/softlib/software10/COL18476/mp-47754-2/AIO_CDB_Full_Network_enu_NB.exe
Happy to help
Nov 29, 2009 | HP Photosmart 2610 All-In-One InkJet...
I can copy a paper, but then the message comes on saying scanner failure, turn off and back on
HP Photosmart 2610 All in one Ink Jet Printer
I can only print, message says scanner failure turn powere off and on , I do this and it does does not reset
Nov 16, 2009 | HP Photosmart 2610 All-In-One InkJet...
Photosmart 2610 with power on get Error 0x886a6916
0x error codes indicate that the product has an internal error. Try to reset the printer:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button
7. Reinsert the cartridges, and then close any open doors on the product
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Jun 23, 2009 | HP Photosmart 2610 All-In-One InkJet...
Photo smart 2610 all in one scanner will not scan
hey i also had this type of problem. but i solved it and hope it will solve yours too.
first of all uninstall all ur hp drivers and softwares related to the hp printer. then restart your pc. now disconnect ur printer with ur computer and turn it off and again on after 15 secs.
now insert the cd which i have got with the hp printer in the cd-driver of ur pc and install the driver.
after the installation is complete, connect ur printer, but do not remove ur cd.
then start scanning, and if it will again ask for installing driver, u dont have to worry it will install it from the cd.
this would surely help u, if problem persists, please tell me.
Jan 03, 2009 | HP Photosmart 2610 All-In-One InkJet...
Error Message Error 0x886a6b72
I contacted www.hp.com and after a while we decided it is fried.
Lightening had hit my cable box and must have got the printer too.
All it will do is flash even after trying to reset to factory settings.
Thanks for the offer
Jun 25, 2008 | HP Photosmart 2610 All-In-One InkJet...
Printer HP Photosmart 2610 all-in-one
I found this link, which i think may help you out.
http://en.allexperts.com/q/Printers-1512/error-message-HP-printer.htm
Copy&paste it in a browser!
May 30, 2008 | HP Photosmart 2610 All-In-One InkJet...
Error Message
I changed the black ink cartridge in my printer with an appropriate hp product. I am not able to insert the cartridge correctly in the system. It constantly reads, remove and receck cartridge on right. I have purchased two ink cartridges at this time. Do you think the printer is broken? Please respond.
Mar 06, 2008 | HP Photosmart 2610 All-In-One InkJet...
HP Photosmart 2610 All-In-One InkJet Printer Logo
3,764 people viewed this question
Clive
Clive
