Question about Canon PIXMA iP4200 InkJet Photo Printer
Poor print colour
I have been using ink cartridges for my Canon Pixma ip4200 that require reusing the chip each time. Do they wear out? The yellow and pink are now very pale, but do not seem to be clogged. Or would it be the printer heads instead? If I buy new cartridges (with new chip) would it solve the problem? Thanks
    Problem Solver:
  • 15 Answers
Use new cartridge for your printer
Posted on Apr 29, 2008
SOURCE:
Printer is saying more then one ink tanks of the same colour is installed. Yellow. Then it is saying it isn't recognising the yellow ink
Do you have all Genuine Canon Ink Jet Cartridges?
If you don't then that could be the problem.
Otherwise, if you do, then I would try another yellow ink jet cartridge from Canon.
Aug 20, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Canon iP4200 thinks it has two yellow ink catridges installed
I have had this happen a couple of times to me with a few cartridges so if you can be sure it's just the black that has changed then I'd contact your retailer and request a replacement under warranty.
The only other way to solve this is by process of elimination using some other cartridges. If you know of someone else with a similar printer model that uses the same cartridges then perhaps ask nicely :)
Feb 13, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP4200 won't print
I solved the problem (I hope more than temporarily) by going out and buying a new yellow ink cartridge. The new one seems to be working, but the cartridge that generated the error message was brand new, too - hardly a satisfactory outcome. I worked out that buying a new cartridge would be slightly cheaper than signing up for one of the Canon support plans. As you can guess, this experience does not augur well for me buying more Canon products in future.
Roslyn
Aug 20, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon pixma ip 4200 printer problems
in the printer driver there is a option that whenever you install a new cartridge it has to be reset otherwise it shows the message the above you quoted. one more option is there that is change the chip of yellow cartridge and black, after doing this please whip circuits of the cartridge and printer carriage block before installing the cartridge
Apr 15, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Ink light flashing
whip the cartridge circuits with the tissue paper, if the problem occurs the same thing than this is the service station error mean s the software has to be installed again
Mar 29, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Compatable tanks for my pixma iP4200
Guys...try to save a few bucks on crappy cartridges...
The chips are not read by lasers. That was a load. There are contacts in the carriage assembly for thses chips.
First, if you put a chip that says empty onto a new cartridge, what do you get? A new cartridge that still says empty. The chip has to be reset, if it can be. Some internet sites sell "Kits" for resetting the chips.
If the reset doesn't work, and just buggers up the chip, you'll get results much like what you are describing.
Also, if the chip is damaged in some way during transfer or resetting, you'll also get mixed results much like what you are describing.
You get what you pay for. If you want to use crap cartridges or crap ink, buy a crap generic machine. If you're buying a decent machine like a Canon, spend the extra couple of bucks for the OEM ink, it's worth it.
Oct 19, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Pixma iP4200
You either have bought a bad cartridge, or are using a generic or refilled cartridge, or have damaged the contacts in the carriage assembly.
Replace the same cartridge again only make sure you use a new Canon cartridge. If this does not help, either the contacts in the carriage assembly are bad or the main board has bit the dust.
Repairing the contacts would require you to remove the upper case so you can access the contacts, remove the ink cartridge and streighten out the contacts before reinstallig the cartridge.
The contacts are located at the front of the carriage assembly under the ink cartridge.
Oct 06, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
Clive
Clive
old marine
old marine
Ekse
