Question about Acer TravelMate 4200 Notebook
One third of my monitor has blaned out
One third of the display is lost. Earlier, pressing ******* the top of the display seemed to help, but now even this does not help.
  • tomastr Aug 17, 2008
    the right side of the screen have a black fringe and same below, but every content of windows and moreover information is diplayed perfectly. How can I do to restore the default size.
    Genius:
  • 3,587 Answers
Ahh..you are experiencing the early vestiges of lcd failure..that usually is caused by the ribbon cable/board combination inside the lcd case..
you under warranty? if not, then it's not too tough to change..just be careful when taking the plastic bezel off the lcd..
check your computers warranty here 4 FREE
Posted on Mar 19, 2008
The world is upside down, the king has lost his crown, don't laugh please, my monitor screen suddenly got upside down.
Rotating the screen image is a feature of the graphics card and is normally caused by accidentally pressing a combination of keys. To correct it, hold down Ctrl and Alt and press one of the four arrow keys (up, down, left or right) until you have it the correct way up.
As your screen is completely upside down, hold down Ctrl and Alt and press the Up arrow key.
Alternatively, you probably have a Rotation setting in the display properties of the graphics card. You should be able to reach your graphic card settings, but reading and setting them properly may be difficult since everything you see on the screen is upside down until it's fixed.
If all else fails, try restoring the system to an earlier date when the display was right. This will reset the driver to its proper orientation.
Nov 27, 2014 | Samsung SyncMaster 913N 19" LCD Monitor
The top part (about one third) of my SyncMaster 920LM screen is brighter than the rest and seems to retain simultaneously the new and the previous picture for 2 to 3 seconds before it gradually fades out...
This is usually do to a section of your controller chips dying. This is not fixable by the end user, the only thing I could say to try is to try different resolutions to see if you can reduce the issue.
Mar 15, 2011 | Samsung SyncMaster 920LM 19" LCD Monitor
I have a gateway FPD1975W monitor with a Gateway GT5482E computer. The monitor does not display the computer output - the blue power light blinks off and on steadily and every so often the monitor says...
From your description you have a power supply problem, usually caused by defective capacitors, sometimes they will bulge at the top indicating an open condition. If you decide to repair check the inverter board that powers the back lights behind the screen, because they are also prone to bad caps.
Feb 17, 2011 | Gateway FPD1975 19" LCD Monitor
My dell 1525 has a blank screen it has happened before I had to take out the battery, then replace and hold down either fn key and a letter or the shift key and a letter. Can you help?
Press the "FN" and "F8" keys at the same time.
Pressing the keys each time has a diferent result.
One time- display is on external monitor
second time: display is on both laptop and ext. monitor.
third time - back to laptop.
Note::
Check for cracks along the LCD screen.the 1525 top is too soft, and flexible. The rubber bumpers are spaced too far apart, causing the lid to flex when closed ...cracking the edge of the LED board. Even with lightest pressure it would be possible for this to happen.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 10, 2011 | Dell Inspiron 1525 Laptop
My laptop is installed in my port replicator; I also have a Dell monitor plugged in to the port replicator. For some reason, after having to re-boot my computer, the output is appearing on my laptop screen...
Press Fn+F10 to toggle the display back and forth on the laptop screen and external monitor. Pressing the keys a third time would close the display on both displays. Thanks, Abhishek.
Mar 09, 2010 | Toshiba Advanced Port Replicator III...
Acer aspire 5315 with no display
If you are connecting with external monitor, then you have to toggle the display Fn+F5 together, still not getting the display then,
Unplug battery and adapter,
Press and hold the power button for 20 sec
then try to turn on the computer
Nov 26, 2009 | Acer Aspire 5315 Notebook
Volume Menu appears randomly; buttons 2-4 don't work reliably
Once you can try providing "reset" option from the menu .... This will solve most of your problems ..
Jul 25, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Hp F 2105 MONITOR volume and sleep problem
this is not HP.com sorry, its a BULLsession blog, mostly guessing
QUESTION TO YOU.
no computer stated, 10000s exist, 1981 to now, endlessl....
we get you have a display connected to what>? who knows.
I hate guessing
but is display connected to a desk top PC?
that it.
so if you barrow and other display does it work ok?
it has 2 cable (not power) one is DVI other is VGA
which one are you using.
ok i see your confusiong
yes, the monitor has its one menu's and the bad designers
dont tell you that, all pop up windows need to say who is talking to you in this case "F2105" is not in the window.
geeks design it and this is what you get.
even windows 10 does this inane acts,, it pops up
and forget to say , I'm W10, only the blue color dark is the clue)
so dont feel bad, its the lame geek disease there.
what does this mean
that you need o learn the buttons on your monitor
one is to clear those screens its in the manual.
best is dont use those buttons. if possible. on side of monitor
the monitor has its own tiny computer brain that is helping you.
avoid it.
the button on most monitors (mine has 5)
menu button,. press one to get menu press again to exit
some have an exit button push it.
lost your manuals>? hp.com has them, ask.
http://support.hp.com/us-en
your monitor has speakers, those need to be connected. to the PC.
http://support.hp.com/us-en/product/HP-Pavilion-21-inch-Monitors/81806/model/461641/document/c00665777/
the screen box is called, clear it now using manuals above.
On-screen display (OSD)
Feb 27, 2017 | HP f2105 21" LCD Monitor
OSD main menu pop-up will not go away
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu and remove that message from your screen. best regards
May 19, 2009 | HP Pavilion F1703 17" LCD Monitor
Switch from Analog to Digital
To move to Digital (you need to have a DVI cable for this)
I'm using the monitor now and typing these instructions Mine is a HW191D Silver:
Button Layout:
(1) Menu
(2) Auto Adjust (does nothing when in digital mode)
(3) Move up in menus
(4) Move down in menus
(5) Power
Press the Top (1) button to display the OSD Main Menu
The Press the button Next to the Bottom (4) twice (Input Setting should be highlighted)
Press the Top button (1) once to allow you to select between Analog and Digital (use the button next to the bottom (4) to select between the two)
Press the Top button (1) and it will change to the input that you selected.
If you selected Digital and you don't have a DVI cable connected, the display will go black and then return to Analog (VGA)
(1)(4)(4)(1)(4)(1)
I hope that helps
toypaj
Mar 18, 2007 | Matrix HANNSFREE 19 Analog and Digital...
Acer TravelMate 4200 Notebook Logo
43 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
