Question about LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
Intermittent buzzing noise
My drive has buzzed loudly since I took it out of the box. Recently it's gotten much louder. I suspect it's the cooling fan, has anyone else experience this? It's under warranty, but I'll have to ship it cross-country, they won't return my data, and I don't have an extra 500gb laying around.
    Genius:
  • 3,587 Answers
Hmm..well..buzzing external drives are an accident waiting to happen. I'd get that puppy on the first jet across country..
you may want to back up your ext drive through this link
Posted on Mar 19, 2008
SOURCE:
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
BUZZING NOISE FROM MY HEAT PUMP
Take a look at this YouTube page that explains with good videos what are some of the common problems with heat pump noise. The one that seems dominant is the defrost cycle a heat pump goes thru when it melts ice off the evaporative coils. In defrost cycle, The compressor runs but the cooling fan does not, so you will hear a loud buzzing sound and the unit sounds like it is stalled...because only the compressor is running to generate heat to melt coil ice.
https://www.youtube.com/results?search_query=American+Standard+5000+Heat+Pump+makes+a+buzzing+noise
Defrost cycle noise video:
https://www.youtube.com/watch?v=wudLk0WoIVo
Mar 06, 2015 | American Standard 5000 Heat Pump Unit
LOUD BUZZING NOISE AND THE ANSWER I RECEIVED WAS FOR A DIFFERENT MODEL. CAN I FIX IT MYSELF?
If the loud buzzing noise is present when cooking food, the magnetron is the likely cause, some models are louder than others. But if the buzzing noise is there without the microwave running it should be checked. No! this something that should be checked by a professional for safety.
Mar 17, 2012 | GE Monogram ZEM200SF Microwave Oven
Buzz sound when tv is on constant
Hello; If you have a plasma TV, is fairly common to hear buzz noises. They can be always there or intermittent. They can get louder as the screen gets brightest. If the buzz is noticeable when you are at normal volume setting, the buzz is excessive and a PCB probably needs replacing. These buzz noises are almost never a sign of failure or safety. LCD TV's can also buzz, but the same applies. John
Jan 27, 2011 | Televison & Video
Loud Intermittent Buzzing Noise Jeep Cherokee Sport 2.8 CRD 2005
I would need to hear this noise to help, sorry, but you need a shop to look into this.
Feb 07, 2018 | 2001 Jeep Cherokee
Loud buzzing noise
Mine is loud also when playing games. When playing DVD's it is not. I think it is a factory defect on some of the systems. I would not attempt to pull apart the DVD drive and try and fix it. It is working and on an XBOX 360 you should feel lucky that it is.
Aug 18, 2009 | Microsoft Xbox 360 Console
Loud humming or buzzing when set is in operation
Does the picture gets distorted in any way when you hear the buzzing noise?
I would suggest to check all the cooling fans for proper operation.
Jul 16, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive Logo
227 people viewed this question
Top LaCie Computers & Internet Experts
Ekse
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
