HITACHI ULTRASCAN 53FDX01B TV- do I need analog to digital conversion box ?
I HAVE HITACHI ULTRASCAN 53FDX01B TV
DO I NEED DIGITAL CONVERSION BOX FROM ANALOG TO DIGITAL ?
I HAVE BIG TV ANTENA IN MY ATTIC; I WANT TO KEEP IT
thanks, Vic
  • Anonymous Apr 14, 2008
    what hd converter do i need?
You do not have a digital tuner if that is what you mean. if you have a cable box you do not need to worry about this stuff but if you want to pick up over the air signals sometime next year you will need some type of hd to sd converter
Posted on Mar 19, 2008
SOURCE:
How do I connect a high definition digital set top box to an analog tv
Connect it with any inputs that your TV supports. The box should do the digital to analog conversion for you
Sep 11, 2013 | Video Game Consoles & Games
Is Orion TV model 1929 ready for Feburary 17, 2009 Digtal conversion without the converter box ?
is the model number correct? Can't find the details of your television.
Does your tv use digital input? or analog if its analog then you need the box.
May 04, 2008 | Televison & Video
Comcast Digital Conversion box (cable TV)
You will have to split the signal before it goes into the digital box. The digital box is not allowing the analog signal to go to your vcr so you will only be able to record what you are watching on the cable box (on channel 4). If you split it, you will get all your analog channels back on your VCR (the way it was before the box was added).
Jun 29, 2009 | Allegro DVD/VCR ABV511
How can i tell if my advent tv manufactured in 2003 model #q2035a is hdtv ready or if i need to purchase a digital converter box?
The first question to ask is how do you get your tv signal. If you have either cable, or satellite TV then you don't need a converter box, as those companies do the conversion for you.
If you have an antenna, you will need a converter box if yout TV is an older model which is analog and not digital. If your tv is a 2003, it is analog.
Jun 13, 2009 | Televison & Video
Is the Hitachi TV Model CT1955 digital?
Sorry, but no. That is an analog TV. You will need a digital conversion box for it to pick up digital channels in the US in June
May 29, 2009 | Televison & Video
Is My TV ATSC or NTSC?
Yes, you will need a converter box if you are currently getting TV off-the-air with a rooftop or indoor antenna. This TV does not have a digital tuner. You don't need a box if this set is being used on a cable or satellite system (unless your service provider tells you otherwise).
Dec 10, 2008 | Philips TV Tuner Video Capture PCI Card -...
Digital converter box
A digital converter box will only allow an analog TV to to operate in analog when using a stick antenna... If you have cable or sat Tv then you won't need the converter because those companies already do the conversion for you.
If you have a HD Tv than by all means it will get HD without a converter using a stick antenna and several stations are available or will be available on cable and sat with extra fees...
Hope this helps!
Bill
Dec 02, 2008 | Philips Magnavox 20MS3442 20" TV
Conversion box
this set is a standard 4:3 projection, so yes, to receive digital, you will need a converter.
Jun 19, 2008 | Philips 60P8341 60" Rear Projection...
Televison & Video Logo
373 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
