Question about Gateway FPD2275W LCD Monitor
Lcd doent come on
I have a septre 19 in. works on one comp. but not on the other one. just booted p one day and it wouldn't com on. the light just blinks green. no picture.
  • 1 more comment
  • okiecoyote Mar 19, 2008
    can hook it to a emachine and it works, was working good on mine like i said then it stated not coming on after it went into hibernation. the light woud go from yellow to green . but would blink, and not come on.
    thanks
    will check out some of the responses.
    hooked a dell 18 to it and a dell 20 toit and they worked great.
  • se2000 May 11, 2010
    Did you check to see if you set the video resolution too high? Does it work in bios screen?
  • Frank  Fernandez
    Frank Fernandez May 11, 2010
    Does the computer that the 19" monitor doesn't display on work when another monitor is connected to it? It could be the Vid. card on the PC.
Best solution my A$$, I have the same problem - It is not PC, it is monitor related. Can't get to the bottom of it, but opening and closing it seemed to make it turn on - but the screen was all white.
I realized I did not secure that tiny b*tch of a ribbon that feeds the picture... When I put it back in, I'm back to blinking LED, a faint image TRYING to initialize that you can miss if you don't watch close.
The monitor is trying to turn on, over and over. It is sending the signal 'I'm receiving a message, turn on' and yet it is not firing up.
Waiting game... Plugged in and on for days, it will come on...
Posted on Jun 21, 2008
    Problem Solver:
  • 18 Answers
Hi, This has happened to me a few times. I found few thing that it can be,
1. The motherboard has a fault so will need replacing
2. Cpu is burnt out or faulty so will need replacing
3.Problem with graphics card
start from bottom, what you can try first is reseting bios by locating the jumper swith keep mains plug out . If you need help with this let me know. Also can try battery take out but doest always work properly. Hope this has helped. Thanks
Onlinepc-Fix
lee
Posted on Mar 19, 2008
I have a large screen Septre t.v. I've only used about ten times. However, it's about 4 years old. Now I finally got cable again and all blue lines down the screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 15, 2015 | Televison & Video
I have ac Acer S202HL LCd monitor. When I booted up one day it didnt come on.
first check with your both power supply out put is coming 19 Volts dc.
if its not coming check with multi meter primary and secondary of your adopter continuity.if no continuity replace with proper working adopter.
Nov 07, 2013 | Acer S202HL LCD Monitor
It wouldn?t turn on...it would initially show the computer?s contents, then after half a second, it would simply go black...operation light is turned on (green) as if everything works!
Does your computer has multiple monitor support? Please check the slots. If there are 2 monitor attachment slot on your computer try connecting monitor to other slot.
Hope this helps.
Aug 17, 2010 | LG L1915S 19" LCD Monitor
Warning "not optimum settings"
Press F8 as the computer boots up and the Windows Advance Options Menu will be displayed. Then select Safe Mode to boot up the computer.
When Windows finishes booting up, then open Control Panel - select Display - Settings, then change the screen resolution to a lower setting.
Apply and shut down and reboot computer.
Dec 19, 2009 | Samsung SyncMaster 912N 19" Flat Panel LCD...
Monitor boots ok, then "Analog" appears/monitor shuts off
Does it have a digital port being used? If you are using the DVI port, it is probably digital. Try using the menu to selct the port. If it doesn't work, not sure from here. What is the model number?
Aug 01, 2009 | E-Machines 19" Widescreen Flat Panel TFT...
Hanns g JC199D will not turn on, comp is on, try to turn monitor
no signal indicates a couple things... i suspect your computer isn't even booting up. reboot the computer while tapping the F8 key.... you should see writing on the screen... boot to safe mode. after it sucessfully boots up... reboot again... should be fine.
Robert
also is that an add on video card ?
Dec 18, 2008 | Hanns.G Corporation JW-199DPB 19" LCD...
Monitor takes up to and over an hour to boot up !
Sooner or later it will not work at all. Time to go shopping - not worth fixing. Go ebay for great prices on used/new units. eBayeBay
Sep 15, 2017 | Hanns.G Corporation JW-199DPB 19" LCD...
CM2019 LCD MONITOR NO PICTURE
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 17, 2008 | Balance CM2019 19" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
35 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
