Paperport 10.0 deleted by repairman.Lost discs and access to data. Cannot reinstall.program.
I have used PaperPort 10.0 happily for a while.
I had my PC repaired and they deleted the program from my PC ( & two others I used a lot. )
I cannot for the life of me find the installation discs. How can I reinstall this great program???
They say the info is still retrievable from the PC but not without the program reinstalled.
Thanks for your help.
Jeri Brofman
    Sergeant:
  • 349 Answers
My only suggestion is to download and install a trial copy then retrieve your data that may have the serial number for you to register again.
good luck
Terry
Posted on Mar 19, 2008
Paperport wont launch
Problems such as this really make you mad, don't they. I would uninstall the driver and other software for the Xerox and reinstall it. Files get corrupt or updated and reloading fixes a multitude of problems.
Oct 02, 2017 | ScanSoft Nuance PaperPort 11 for PC
Have an older Visioneer 7100 USB Scanner, Has worked fine for more than 10 years, Now I can't get any scanned objects to appear on my Paperport Desktop. Have no problem using scanner with all other...
Have you upgraded to newer version of windows? Have you tried reinstalling Paperport? (back up max files 1st) I have had a visioneer and still use Paperport 8. Often I have problems with Windows 8 and reinstall paperport now and then.
Mar 07, 2014 | Visioneer Office Equipment & Supplies
Scansoft paperport 11 msi
You must contact Nuance Customer Support for assistance. If you are unable prove/document PaperPort ownership, you will need to purchase the program.
PaperPort Nuance
Feb 07, 2014 | Computers & Internet
I have installed PaperPort 11 some time ago and it all worked fine. Recently Paperport started installing after every reboot. The installation fails with the error: 1: The engine of the installscript is...
  1. Open the folder C:\Program Files\Common Files\InstallShield\Driver\ from the machine.
  2. There should be folders with numbers in this Driver folder, for example 6, 7, 8, 9, 10, 1050, 11. Delete these folders.
  3. Download ISScript11.zip.
  4. Unzip this file. For more information on unzipping files, see How Do I Unzip a File in Windows XP? or How Do I Use the WinZip Utility in Windows 2000 or Earlier?.
  5. Double-click the IsScript.msi file. This installs the IsScript engine for this version of the installation.
  6. Now try running PaperPort 11 again. If it still has problems opening, try reinstalling PaperPort 11.
Jan 23, 2011 | ScanSoft Nuance ® PaperPort® 11 Full...
I operate Windows 7 and installed Paperport 11. I want to scan documents from another program, like WORD. In the printer drop down you are supposed to see: Paperport Black & White as well as Paperport...
This type of information (different ways to scan) come through the software. I'm pretty sure you will not be able to do this by the (add printer) method. I would uninstall the Paperport driver from your computer, then reinstall, and try to use the "advanced" method to see if it will allow you to add those two. I have found if scanning ability shows up in one Microsoft Office product, it will show up in another. Plus, my photo processing program will show the same ability.
Nov 30, 2017 | ScanSoft Nuance PaperPort 11 for PC
Scansoft paperport 10 keeps loading every time i switch on
Check the Startup folder in the Start menu. If it is there, simply delete the entry there. Otherwise you can use "msconfig" from the Start Run menu to control the startup programs and disable paperport.
Dec 22, 2009 | ScanSoft PaperPort 10 (1313547SF)
Problem with paperport scanning
don't put paper it cause a paper jam use 10 sheets only
Mar 17, 2009 | ScanSoft Nuance PaperPort 11 for PC
Paperport selection on printer, but item does not print to paperport
Hi Try this solution: Go to your printers and faxes control panel and right mouse on say the paperport colour image printer. Now select the Paperport tab and you will find where the images are being sent! Probably in the bowls of documents and settings; all users bla bla. Change this to where you want them to go. I changed mine to drop into the MyPaperPort Documents folder for ease of use.Do the same for the black and white printer if you like.
Jul 09, 2008 | ScanSoft PaperPort Deluxe 8.0...
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
