Question about Wave Industries OLY-OL3000 Globe Phone
Wrong message in display
The infoglobe shows special characters and mis-spelled names in display.
Press f1 f2 continue
For what purpose are you pressing the F1 key. The function keys may have different uses depending on the computer. When combined with the Fn key of a laptop they may also do certain actions. You should read the manual of your laptop to find out about the function keys.
Oct 08, 2013 | Toshiba Satellite A205-S4639 Notebook
Change display names
A problem with answering this question is first that the main SYSTEM keeps this info not the handset, so for the 3x8, 6x16, and 8x24 systems you can do the following (PROVIDED, the installer did not change the passwords to access).
Press FEATURE * * 2 6 6 3 4 4
Enter Password: 2 6 6 3 4 4 Display will read: " A. Configuration"
Press: NEXT Display will read: "B. General Admin"
(NEXT is always the button on the right of your lines/extension list, 2nd button down from top.)
4. Press: SHOW Display will read: "1. Sys speed dial" (SHOW is one key up from NEXT)
5. Press: NEXT Display will read: "2. Names"
6. Press the SHOW Display will read: "Set names"
7. Press: SHOW Display will read: "Show set:__"
8. Enter the extension number of which you wish to change the name Display will read: "<##:name>"
9. Press the CHANGE softkey
10. Using the dial pad spell out the name Ex: If you need the letter K press the 5 key twice and then press # to confirm the letter. Continue until the entire first name is spelled. (note: you are limited to 7 characters)
11. Press: NEXT (if you fail to do this step, the name will not be saved!!!)
12. Press the RLS key
I may be mistaken however I think you have to be on a model M7310, T7316, or M7324 phone (there should be at least one usually at the main desk) in order to program I don't think you can directly do it from the T7208.
Hope this helps.
May 04, 2010 | Nortel Business Series Terminal T7208 -...
Spelled my name wrong on my account
go to ur mailid. at the top click " from connection". it shows the option "get update'. u will update ur name by using this option.
Mar 28, 2010 | Yahoo Mail
I am trying to install QuickBooks Pro 2007 on a new computer that has Windows Vista Business with SP1, and I had updated Windows, then installed QB but when I imported the company file, QB gave me a...
Why is this happening This issue can occur as a result of uninstalling the Google Desktop installed by Quickbooks on a computer running Microsoft Windows Vista. Launching QuickBooks after uninstalling Google will cause the error message.
Note: This issue is also known to occur with computers that have been upgraded from Windows XP to Windows Vista, where Google Desktop was uninstalled under Windows XP. Both cases would yield the same error message.
How to fix the problem This issue was resolved in the latest release for your version of QuickBooks.
Detailed Instructions Please update your program to the most current release.
just click on that link above then click on the 909ffb0.jpg(update) image on that page.
Oct 27, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Change name that comes up on display phoned
Name programming requires access to system programming. If you go to the main phone and, without picking up the handset, press PROG and dial **1234 and ENTER, it will go into programming mode. Dial 004 and you are looking at the Ext Name screen. An ENTER at this point starts at 101 OPERATOR (default). Now just start pressing the letter keys and the right arrow to spell out the names. The keys press 7 times for ABCabc2. Punctuation and special characters are under the 1 and 0 keys and STORE or ENTER saves your work.
When I install my systems, I let everybody have access to the programming by class of service. You may be able to program from any phone in your system, it depends on the installer. The phone that rings when you dial "0" is probably the main phone if you can't program this from your own phone.
PROG exits programming.
Carl
Mar 11, 2009 | Panasonic KX-T7630 Corded Phone
Open Office Writer spell check problem
Make sure it is the correct language: select the text, go to "format" > "character", select the "font" tab, and change the language appropriately.
Dec 31, 2008 | Computers & Internet
Display interrupted
Just fixed mine tonight. Follow instructions on http://www.linux-hacker.net/InfoGlobe/ for globe removal. I used a .020" feeler guage. The solder joints on the small circuit board at the end of the arm are subject to vibration from operation and about a bazillion revolutions before failing. You'll need a good quality soldering iron with a fine tip, some solder wick, a bit of patience and a bright light and some reading glasses will not hurt. I removed the solder and then the small board. I'm using an 800 degree tip, so with something like that you want to get on/off the pads as fast as reasonably possible so you don't cook it. Then I re-tinned the traces and re-soldered the small board onto the end of the arm. At first it didn't want to light up, but on depressing the "Select" button, all was good. Happy to have ol' blue back up and running again :~)
Jul 06, 2008 | Olympia InfoGlobe Caller ID
NORSTAR m7310
To Log Into System Programming:
Using the navigation keys, as displayed below, follow the next simple steps:
Press the RLS key
Hope this helps!
Jun 17, 2008 | NorStar Meridian M7310 Phone
Initialising Mailbox
To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
To Create a New Mailbox:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "ADD"
4. Enter the mailbox number (extension. you want to add
5. Mailbox type: Subscriber and then select "OK"
6. Extension: Usually the same as the mailbox number
7. Service Class: Enter 1
8. Name: Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma, and then enter the first name. When spelling the name, press # to move to the next character
9. Directory: Y (Yes.
10. Message Waiting: Y (Yes.
11. Out dial: Pool, enter 1 and then OK
12. Accept: 1, select OK
To Delete a Mailbox:
1. Log into the system administration
3. Select the softkey under "DEL"
4. Enter the mailbox number (extension. you want to delete
5. Select the softkey under "Delete"
To Reset a Mailbox Password:
3. Select the softkey under "Chng"
4. Enter the mailbox number you want to reset the password for
5. The display shows "Reset Password"
6. Select the softkey under "RESET"
7. Press the release key
*The new password will be "0000", the system will ask the user to change this the first time they log into their mailbox using this password.
To Change the Name on a Mailbox:
4. Enter the mailbox number (extension. you want to change the name on
6. Select the softkey under "Next", keep hitting "Next" until the display shows the name
7. Select the softkey under "Chng" to enter a new name
8. Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma and then enter the first name. When spelling the name, press "#" to move to the next character
9. Select the softkey under "Next" to save the change
10. Hit the release button
To Change the "Recorded" Name for the Company Directory:
1. Have the Voicemail User log into their mailbox, after putting in their password, press the button under "Admin" (or press the number 8 key., and then press the number 1 key.
2. You will hear the old recorded name and then the system will "beep", prompting you to record a new name (name only here, not greeting..
3. Press "Ok" in the window when you are done recording and then "Ok" again to accept the recording
Apr 23, 2008 | NorStar M7310 Corded Phone
Olympia, and/or Sharper Image infoglobe. Need fix.
It appears that you have already removed the 4 screws. The globe will not just fall off, it has to be pried. Take a small- bladed screwdriver or a small-bladed pocket knife and gently pry from any small opening you see between the globe and its base. Work the blade around the globe and it will come off. I just did it and now I'm trying to figure out how to get inside the "guts" of the globe. Will keep you advised.
Dec 27, 2007 | Olympia InfoGlobe Cordless Phone ol3020
Wave Industries OLY-OL3000 Globe Phone Logo
137 people viewed this question
Top Wave Industries Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Wave Industries Lands Phone Expert? Answer questions, earn points and help others
