Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Unit locked somehow the dishwasher is locked, didn't know i had this feature, but i know i don't like it since i can't get the dw to respond to any of the controls now
  • ljo_dbar Sep 25, 2008
    lockout keeps coming on by itself...will not turn off NO matter what I try...HELP!!!!!!!
I believe if you hold the lock button for more than 3 seconds it will unlock. This is a feature to prevent toddlers from turning the dishwasher on or changing settings.
Posted on Apr 11, 2008
Why does the lower spray arm keep coming loose on a Kenmore 587.15189402
Is this one of those drawer-style dishwashers, or a regular DW? I can't seem to find that model number in my search. If it's a regular (door-opens-downward) DW, then you probably don't have the lower wash arm attached properly. On some DW's you turn the hold-down "screw" in the reverse direction to tighten it. If it's a new Kenmore Elite DW, then you turn the lower square or geared section 1/8th turn clockwise to lock it. Of course, you may have a damaged or stripped plastic part that just won't stay....
Oct 20, 2014 | Kenmore Dishwashers
Samsung DMT400RHS Leakage error
check you house circuit breakers if you have no lights and the DW is plugged in next check to see that the door switch still locks the DW shut otherwise;call a serviceman
Nov 18, 2013 | Samsung DMR78AHS Builtin Dishwasher
Bosch dishwasher model SHX46A why does the on/off switch and lights stay on while the dw stopped running?
The dw was not quite running. It does pause between cycles. The power scrub cycle means that you had the machine on the longest of all cycle choices. There's almost always a light and a normal cycle. The pots and pans cycle is a power scrub option. Yes all the lights would be on until they switched to a different part of the cycle. Do you have a DRYING light? That would be the one to look for as far as the dw being finished. :)
Nov 20, 2011 | Bosch 24 in. SHX46A05 Stainless Steel...
I have a Kitchenaid dishwasher model KUDS01FLSS2. I finished replacing the door balancer cord and started the dw up and it started leaking underneath from the bottom somewhere around the middle of the...
In this Kitchenaid dishwasher model KUDS01FLSS2, the whole motor and water pump assembly simply sits (I think loose) in the bottom of the DW. From the inside, it is the round mechanism where the sprayer is mounted above the chopper, all one piece sitting in (or mounted with) a large rubber washer around it. Somehow this assembly had lifted up slightly on one side which allowed the water to just poor through the bottom floor of the DW. I simply pressed down on the whole mechanism positioning back in its proper place. It did not take much pressure at all to position it back into its place. This stopped the leak and is working like a charm.
Nov 13, 2009 | KitchenAid Dishwashers
How do i get the lock off my dishwasher
Hi
If you are referring to the Child-lock feature which deactivates the buttons from use then usually on Kenmore dishwashers you can deactivate this child lock by holding the "No Heat Dry" button for 4 or more seconds. This should get the panel to respond again.
Hope this helps. Please do rate my answer. Many Thanks.
Aug 16, 2009 | Kenmore 15762 Dishwasher
I have a Zanussi Fitted dishwasher and I notice that the board under my kitchen seems to be getting black,I think it is the dishwasher leaking water from underneath.. Is there any common problems with this...
Yes sounds like some kind of water leak. Take of the front plinth and check underneath the units and DW. I presume you DW is adjacent to the sink so please cheak all pipes including waste asap. Also opening the DW door whilst it is running can splash water, over a period of time this could effect wood material and cause your problem.
Mar 09, 2009 | Zanussi ZT485 Built-in Dishwasher
Door doesnot close
The LG LDS 5811 and all models that start with 'LDF" do not have a door latch. They do have a child lock _but_ that feature does not lock the door closed or open, it just locks the controls so the DW can not be turned on or settings changed.
So, please look at the right side edge of the opened door and post the model # back here.
Thanks!
Aug 14, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
Dishwasher has lock set on it
to be spefic i need the brand and model but look for a lock symbel on the control and hold it down for three to five seconds
if you dont see a symbel then send me the moder or consult your owners under control lock
Jul 22, 2008 | Dishwashers
Water won't fill
when facing the dw pull it out from under counter and on the left side there is a panel held on with 2 screws. take that off and under there are the float switches for the overflow. those switches is what causes the pump to run all the time but do nothing else.
Oct 30, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
95 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
