CHANNEL SELECTOR MAGNAVOX 27TS73 C102
TRIED TO USE CABLE CHANNEL SELECTOR AND NOW IT TELLS ME NO CABLE CHANNELS ARE AVAILABLE HAVE LOST ALL BUT 2-13
    Brigadier General:
  • 6,966 Answers
I am assuming that your cable is directly connected to the rear of the Magnavox C102 and you are not using any Cable Receiver or Decoder.
If that is how your system is hooked up, then what needs to be done is to enter your menu/setup and select CABLE instead of AIR or STD. Thereafter, channels maybe scanned and saved to the memory.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 19, 2008
  • Louie  Role
    Louie Role Mar 19, 2008
    Hi again,
    I was made to understand additionally that your particular model has a "...EASY FIRST TIME SET-UP This friendly, useful,
    smart, and easy feature is available the first time this
    TV is turned on with a signal connected. SETUP is
    highlighted in the main on-screen menu offering
    language selection (English, Spanish, or French), auto
    cable select (choice of CATV or ANTENNA), auto
    program (automatically storing all available channels
    in the tuner memory), and VCR/PIP setup
    Cheers.
  • Louie  Role
    Louie Role Mar 22, 2008
    Hi gtwii,
    Any new development(s) with your Magnavox C102?
    Cheers.
SOURCE:
Channels
Check your cables and then move the channel selector through all settings a couple of times. This will give some indication of the real problem. If the channel comes back after exercising the channel selector, then you have a "Furred up" selector. If the channel doesn't come back then you may have a failed amplifier in the amp.
Jul 21, 2013 | Panasonic SA-HE7 Receiver
Have cable....need tv to come on channel 3, but comes on to channel 9...turned off tv on channel 3, but no change when turning back on.....mod # tp2384 c102...do not have original remote
Not having the original remote may be your problem or not, if you can direct enter a channel it should stay there if nothing is connected--then go into menu and manually add it, if it does not something is wrong with the set.
Dec 16, 2012 | Televison & Video
I have a 19" magnavox
Do you have a digital converter box. If not, you need to get one to receive the analog channels.
Feb 06, 2011 | Televison & Video
I need this older magnavox tv I bought to go to channel 73, at this time I can only go to 69. It is model # 27TS73-C104. I have sat. reception and need the channel 73. Thanks!
I am assuming you have a dish network duel tuner. You can actually use any channel under 60 for the second t.v.. You can find all that information in that big pamphlet that your remote comes in. It also sounds like your in antenna mode, (please make sure your tv2 side is on before you do this) go to the second tv go to menu system set up scroll through until you see input type or something along those lines, make sure you select cable, then do a channel scan/ setup it should pick it up.
Sep 04, 2010 | Philips Magnavox 27MS343S 27" TV
Channel tuning 1994 Magnavox 27'' TV
U the remote to turn to the channel 3.
Nov 18, 2009 | Philips Magnavox 27MS343S 27" TV
New TV won't ''talk to'' old VCR
using the magnovox remote, reprogram the vcr's channels. set it up to use cable not air. when the vcr was unlugged it lost it's channel memory. don't buy new cables, you're getting a picture and sound so that means your rca cables are ok.
Jan 20, 2009 | Sharp Aquos LC-32D40U Television
Please explain the working of this code
It's a Java http server (webserver) that serves random "prices" if they match a search string.
Well here is an explaination:
private static String[] symbols = {"DELL", "INTC", "MSFT", "ORCL", "SUNW"};
These are search strings
private static Random rnd = new Random();
This generates a random number
private static Charset cs = Charset.forName("UTF-8");
This is the charset that the http server uses
ServerSocketChannel server = ServerSocketChannel.open();
Create a new server
server.socket().bind(new InetSocketAddress(8055));
Bind the http server to port 8055
The rest is handling the request and processing it
But here:
if(Arrays.binarySearch(symbols, symbol) >= 0)
response = "Price is " + (1000 + rnd.nextInt(9000)) / 100.0;
else
response = "Price not available";
channel.write(cs.encode("HTTP/1.0 200 OK "));
channel.write(cs.encode("Content-type: text/plain "));
channel.write(cs.encode(response));
channel.close();
It sees if the string input matchs: DELL INTC MSFT ORCL SUNW.
(private static String[] symbols = {"DELL", "INTC", "MSFT", "ORCL", "SUNW"};)
If so, it gives a price based on a random number.
response = "Price is " + (1000 + rnd.nextInt(9000)) / 100.0;)
Or else
It says "price not available"
then it gives a html header to end the error message.
Hope I helped you :)
Gook luck
Nov 26, 2008 | Computers & Internet
Some channels have no color or sound
once a signal falls below a certain threshold the color will be lost.
some sets are more sensitive to this loss.
if you see static in the picture on any of the channels then the cable is leaking and needs replaced /tightened.
if a local air broadcast is leaking into a same cable channel on the cable you will get poor to no reception on that channel.
for example : he we have a local channel 7 on the air.
if i tune to cable 7 and see a weak or distorted pic then the cable is leaking and needs replaced.
May 04, 2007 | Philips Magnavox 15MF400T 15 in. LCD...
Televison & Video Logo
218 people viewed this question
Top Televison & Video Experts
Ekse
