Question about GE WSXH208A Front Load Washer
Ge front load washer
Why do we need to use he laundry soap instead of the regular soap
  • 487 Answers
Because the frontloaders are set up differently and use less water. The regular soap sudds to much and can cause a number of problems in front loaders.
which can be but not limmited to burned out pump, motor etc.
Posted on Apr 15, 2008
What type of laundry soap does it use and how much per load?
You did not post any info on the make and model. The front loading type of washing machines MUST use "HE" types of detergent. This is because a front loading machine causes suds and regular detergent is not made for reduced suds. The best laundry soap according to consumer reports is Persil. You don't need very much either. Most people use way too much detergent.
Jan 12, 2017 | Washing Machines
I have a frontload he washer. My question is, will using a regular laundry detergent instead of he laundry detergent cause problems with the washer.
top load detergent will suds a lot and detergents made for from load washers wont suds very much at all, suds ina front loader will cause it to not spin or drain very well while i know it is more expensive you should always use detergents with the HE logo on the package
Jul 25, 2011 | Washing Machines
My 3 month old washer suddenly started leaking from underneath. There was a code displayed of a 5d, but the washer drains into a laundry sink, there are no kinks in the input line.
The washer is detecting too much soap. Make sure that you are using HE (high efficiency) soap Do a clean washer or hot cycle once a month with bleach or white vinegar with no clothes in it. Your washer only uses half the water that a regular machine does. The HE is specially designed for front loaders and these types of machines
Jul 11, 2011 | Maytag Bravos MTW6600T Top Load Washer
Does the Neptune have to have HE laundry detergent?
Yes you need to use HE detergent is this machine.1st reason is regular soap will suds to much and make the unit go into suds lock. 2nd HE soap will not damage the bearings and seals like regular soap could. 3rd He will clean better and you will be using less product...
Sep 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Hi We Have a ge front load washer and dryer and it seems that our clothes smell musty at times. I've tried leaving the door open on the washer when not in use. Could there be another prooblem??
Try using vinegar, baking soda, or bleach in an empty load to counteract any residues left in onboard water. Also check for debris stuck in door baffle(rubber sleeve between door and tub).
Nov 17, 2009 | GE WSXH208A Front Load Washer
My washer smells really bad
your smell is comming from over soaping
a front load machine only needs 1 Tblsp of soap
any thing it builds up and rots thus the smell
get a crystal dish soap
1 cup run the machine empty a full cycle
now use trhe proper soap it will clean away
Oct 03, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Mildrew, stale water smell in laundry
Run a very hot wash on your machine with no load
Fill a bucket with a strong solution of soda crystals and pour it into the machine first
Add some more crystals to the soap dispenser
Use an old fashioned soap powder for a couple of washes as well and reduce the load slightly
Modern soap powders do not contain certain bleaches and soda and the 40 degree wash leaves body fats and oils inside which cause odours
Jul 03, 2009 | Frigidaire ATF6000ES Front Load Washer
GE Front Load Washer Model WBVH5100HWW - door lock light is on
I queryed another site; justanswer.com with technician Larry, who provided the solution. Replace the door latch assenbly part # WH10X1006 $146.99 from GE. A local parts house had the identical under a Whirlpool # WP8182634 for 59.46. Install the new assemble and all is well.
Nov 12, 2008 | GE WBVH6240F Front Load Washer
Whirlpool Duet Front Load Washer WFW8300SW00 Problem: I am using HE detergent and using less than the recommended amount; however, there is always a small ***** of suds sitting on the seal when I open the...
If you have a water softener or very soft water, soap will suds up more than if your water is normal or hard, so you'll need to use less than recommended. Obviously soap breaks down the dirt, but the dirt also breaks down the soap, so if your clothes are not very dirty to start with, you'll need less soap than if they were more dirty. Soap can also be stored in laundry like towels and cleaning rags and when combined with the laundry soap will suds more. You can try raising the leveling legs in the front to tip the washer back. This will help the water drain back into the tub instead of pooling on the boot. You can also try using the 'extra rinse' option. Keep cutting back on how much soap you use until your laundry is not as clean as it should be. You might be surprised how little soap you can use!
Jul 21, 2008 | Whirlpool Washing Machines
LAUNDRY DETERGENT
Greetings MOMMA2,
Typically it is recommended to use only HE (High Efficiency) in your front loading units. The difference between HE soaps and normal detergents is that they are low sudsing soaps. HE Machines need low sudsing detergents and if regular detergent is used, the excess suds could lead to washer problems. Unfortunately just using a smaller amount of regular detergent does not fix the issue. Only the use of HE detergent assures the proper performance of your unit.
Due to this, it is NOT recommended using Dreft in HE machines.
One recommendation out there is to look for 2x Ultra Tide HE Free, which is made without dyes or perfumes.
Thank you,
Dorothy
Go Ahead. Use Us.
May 24, 2008 | LG WM-2277HW Front Load Washer
GE WSXH208A Front Load Washer Logo
93 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
