My computer turn on but no video comes up - Computers & Internet
  • Anonymous Oct 31, 2008
    My hp pavillion 705w just stopped showing video, I recently upgraded the memory. I tried taking off the memory there is no beeping with or without.
    Genius:
  • 1,226 Answers
Hello!
Did your hear beeping ? if not then. verify the memory reinsert it in the slot and refix some cable connection, the VGA-card if it is an add on card.
you can test also if the board and processor is working. you boot your system with out the memory the system beeps, create long beeps.
Just do the troublshooting of the system. and tell me soon after trying my soltuion. best regards, melnavz
Posted on Mar 19, 2008
No display but the computer turns on.
could be an issue with the graphics controller or with the monitor. first, verify if the monitor is actually working. try it on another computer or video source. if it works, make sure that you have a working video cable and check to make sure the video input source (dvi, vga, rgb, hdmi.. etc) selected on your monitor is the correct one that you are using. if you have ruled out the monitor, video source and cables, you can then test if another monitor will work with the computer. if same thing happens, meaning nothing on display even the manufacturer or BIOS screen does not show up when you turn on the computer, it is most likely the video controller. you may either get the motherboard replaced or install an add-in video card if the integrated video controller only has one video connector.
Jul 17, 2013 | eMachines MS-7145 Motherboard 103777
My acer monitor p191w will turn on acer logo comes on goes black then a screen comes out saying no signal then turns of light turns yellow ...tried restarting monitor nothing
Connect the monitor to a different computer, to see if the monitor works at all.
Connect a different monitor to your computer, to see if your computer really is "sending" a video-signal through the "data" cable. If not, then either the data-cable or the video-card inside the computer is faulty.
Jul 13, 2011 | Acer P191WBD LCD Monitor
I have an AOpen vKM400Am-S Motherboard, when i turn it on a red light and cpu fan turns on but no video to my monitor,i checked if my video card works on a difrent pc and it did, my pc wont turn on
this caused by RAM error, open your computer, disconnect ram, turn on your computer?is computer beeping, 1 long and 2 short beep??if yes the problem is come from your ram, clean your ram connection then connect ram to mother board, turn on your computer, is the video come to screen??if no, try to connect another ram to your computer, for sure use new ram
i hope this helpful
thank you for using fixya
Feb 05, 2011 | AOpen MX4LR (91.89Y10.002) Motherboard
Its in hibernate mode doesnt wnt to get out of it
Turn your computer off and turn it back on. See if the video comes back. If it doesn't then try another known working monitor on the computer. If you get video with the 2nd monitor then that means the original monitor is bad. If you still don't get video with the 2nd monitor then that means there is an issue with the CPU because you have no video output.
Nov 03, 2010 | Samsung Computers & Internet
Monitor does not turn on after the computer is turned on. Just like there is no input coming from the computer.
Take this monitor and attach it to another computer... if it works then the problem is with your video card. Change the video card.
Mar 15, 2010 | HP 2009M Monitor
Dell computer monitor wont come on when I turn
When you turn on most dell monitors they come on with a yellow light, then turn green when the monitor and video source synch. If your light is not turning from yellow to green, your monitor is either dead or not getting a signal from the video source it's plugged into. Verify in your BIOS settings that you have selected to output video through an installed card and not from the motherboard source. If the BIOS settings are correct, your monitor has died. If the light is turning green after you turn the computer on, press the menu button on the monitor and adjust the brightness/contrast until you have a picture. If you don't see anything when the menu button is pressed, then again your monitor is likely dead.
Jan 04, 2010 | Computers & Internet
No signal to monitor. Cable is fine and so is the Video Card -
your motherboard may be going out is your keyboard also acting crazy
Aug 15, 2009 | Impression Products Impression 7LSP 17"...
Can't switch on comp..amber light flashing?
That usually means no video signal is coming out of the computer.
Try another known working monitor on the computer and then turn on the computer and see if you still get no video on the screen.
If that doesn't work then with the computer turned off, reseat each stick of memory one stick at a time in each slot one at a time. After each reseat, try turning on the computer and see if you get video on the monitor. If you have another stick of known good working memory you may want to try it in your computer.
If that doesn't work then turn off the monitor and go ahead and reseat the processor as well then turn on the computer and see if you get video.
If that doesn't work then go ahead and make sure only the power connectors are hooked up to the motherboard and then turn on the comoputer. If you still don't get video then you know sure at this point that the motherboard is bad in your computer.
Aug 05, 2009 | Dell Computers & Internet
No display (black) - power light is amber color
The video signal is not reaching your monitor, check the pins on the connector from the monitor to the computer, then check the video card:
Turn off your computer, unplg the power, and then take out the video card. Wait 5 minutes and then put the card back into the computer and turn it on. For onboard video; turn off the computer, unplug the power, then hold down the power button on the front for 5-10 seconds, then plug back in and turn on.
Make sure the video card is snug in the AGP/PCI slot. If this is built-in video, try borrowing a video card from another computer and install it in this one. If the borrowed card works, then replace you card. If video is built in, then you can disble the onboard video and use the new card without having to replace your motherboard.
Jul 14, 2008 | ViewSonic VX910 19" LCD Monitor
Black screen
How old is the computer? Make sure that the power light comes onto the monitor when you plug it in, should be orange and then turn green when video card syncs with it when PC is turned on. If you are getting black screen when PC is powered on:
1. Bad video card
2. Bad video cable
3. Bad monitor
1Solution: Try using a different monitor attached to this same PC and see if it works. If it does, then its the monitor, its cable, or its power supply. If it doesn't work, then its the video card or the video cable coming from monitor.
Nov 24, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Computers & Internet Logo
269 people viewed this question
David Payne
David Payne
