Question about RCA 15L500TD 15 in. TV/DVD Combo
Stuck DVD DVD stuck in RCA 15L500TD, no picture in DVD mode only fine green lines
RCA D56W20, Works OK, so long as the "black level"
The green CRT has an issue and will need to be replaced. It could be the Green CRT drive board but doubtful as your describing the classic sign of a CRT thats developing a Short . You can get replacement green CRTs and CRT drive boards from www.tvrepairworld.com
Oct 14, 2011 | RCA D56W20 56" Rear Projection Television
Problem with my Magnavox DVD player, DP100MW8, picture dark and lines across the screen
Hi, if the lines are diagonal sounds like it is set to progressive scan mode-which means if there is not a switch on back saying P/S and interlaced then you need to connect to T.V. with component video inputs ( indicated by red,green,and blue colored R.C.A. plug inputs) and Pan and Scan capable-then in menu setting select interlaced picture output. hope this was of use, good luck prodzilla
Mar 30, 2011 | Televison & Video
Green Lines with Picture behind
Could be serious...but first check the screen modes (for split screen, format, etc) to be sure the tv is set up properly for the picture you are trying to watch. Switch the input to a DVD or something similar. Is it the same? If not, you have a mode/resolution problem with the tuner and perhaps some other device.
Jun 28, 2009 | Mitsubishi WD-52525 52" Rear Projection...
17 yr. old 35" RCA loses color intermittently. Picture & sound ok
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
Jan 12, 2009 | RCA 15L500TD 15 in. TV/DVD Combo
I have a 32 inch sharp tv and it has been working fine, but i just went to watch a dvd and got sound from the dvd but a green, disjointed pattern instead of pictures. i switched dvds and it was the same...
there is a possibility that you have switched the RCA cables for the right port, the color patterns happen if your plug the component RCA ( Y Pb Pr) on a diff port. their usually color coded so please double check that to.
e733778.jpg if not, please let us know what is the model number of the TV and we will find what can be done in the TV.
Aug 10, 2008 | Televison & Video
Vizio liquid crystal tv l32hdtv
Check the cable connections and/or replace the cables to the AV2 input.
If replacing the cable doesn't provide a solution, try running your DVD through the input. Since it works fine now, you would be checking the input AV2 by putting your working DVD. If the DVD plays with no problems, the input is fine.
Also try the VCR using coax into the TV instead of RCA into AV2. This will give you some idea about the condition of the VCR.
I suspect either the VCR or the cables.
Apr 22, 2008 | Vizio L32 32 in. LCD HDTV
Dvd stuck in dvd
Lay the TV, face down on a folded towel. Remove all the screws. Note: there is one perimeter screw with machine threads; all the others are the same.
Remove the four black screws from this area:
Then you can pop the back loose and slide it towards the end where the black screws were. It just lifts off and there are no wires attached.
Now you can see the DVD player. I used the end of a plastic pen to shove against the edge of the DVD that you can see through this slot.
Press on the DVD's edge until you see it come out the entry slot.
You can see the DVD slide out the entry slot as you are pushing.
When done, slide the back into place and replace the screws.
Dec 31, 2007 | RCA 15L500TD 15 in. TV/DVD Combo
RCA 15L500TD 15 in. TV/DVD Combo Logo
189 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
