Question about Apple iPod MA446LL/A MP3 Player
Apple Ipod 30 GB
My ipod operates completely normally until I unpug it from power when it dies.
I have tried different batteries but no luck.
Thanks for your help,
Murray Kucherawy.
This sounds like your battery connector may have a bad contact.
new ipod battery
http://www.ipodrefresh.com
Posted on Aug 13, 2008
  • Apple Master
  • 13,433 Answers
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
If that is no use, you might want to contact apple or your dealer for more assistance or repairs.
If you need more asistance, let me know.
Posted on Mar 23, 2008
Ipod will not turn on
Check to see if the Hold switch is on. It's located on the top or the bottom of iPod.
When it's in the on position, you'll see an orange patch.
To turn the hold switch off, slide it until you no longer see the orange patch.
Press any button to turn on iPod.
Make sure the battery is charged
iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod
Power Adapter and plug the power adapter into an electrical outlet.
Note: iPod models without a Click Wheel cannot be charged via
USB. iPod shuffle requires a high-power USB port to charge.
iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes.
If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information.
Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost.
Let the iPod battery drain
In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
Disconnect iPod from all power sources and leave it disconnected for about 24 hours.
Reconnect iPod to the Apple iPod Power Adapter or computer and reset it.
Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod.
Sep 08, 2013 | Apple iPod Audio Players & Recorders
Ipod wont turn on
Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
To turn the hold switch off, slide it until you no longer see the orange patch. Press any button to turn on iPod. Make sure the battery is charged iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via
USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information. Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost. Let the iPod battery drain
Disconnect iPod from all power sources and leave it disconnected for about 24 hours. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it. Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod. b>
Apr 16, 2013 | Apple iPod touch
Ipod 6 on and off botton dont work
is the hold key engaged?is the device charged?is the device normally operable?is the screen operable?does the device illuminate when plugged to power.Try this if all else fails:
Press and hold the Sleep/Wake button and Volume Down button simultaneously for at least eight seconds or until the Apple logo appears. You may need to repeat this step.
If the above step did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try resetting the iPod while it is connected to power.
good luck... questions ask
Mar 30, 2013 | Apple iPod nano
Will not charge or turn on
Plug your Ipod into your computer. Hold down both the Menu Button (on/off button) and the center button( just below the screen) for 15-30 seconds. You should see the Apple sign after that time. Mine died and was revived this way.
Apr 04, 2010 | Apple iPod classic MP3 Player
My ipod touch 2nd gen ran out of bettery whilst watching a film. i went to charge it and it shows the apple logo for about 20 seconds, but then turns off. how do i solve this please!!!
Hello edwardross, I'd be happy to help! Unfortunately, it seems like the battery of your iPod has permanently died. This is completely normal, and all you have to do is go to a local apple store, purchase a new iPod battery and have them install it for you! There are many possible causes for this issue besides the normal (that an iPod battery can only take up to a certain amount of charges), such as the usb cord or computer having a hardware issue that might have caused damage to your iPod battery. But, fortunately, if you do take it to the Apple store and they do a thorough check, they might even discover the true cause of your battery's death and not even charge you a cent! I hope this helps!
Jan 16, 2010 | Apple iPod touch Second Gen (8 GB,...
Battery on my Ipod classic completely died and now wont work
The first thing to try is an ipod reset. Here are the instructions from apple on how to do this: http://support.apple.com/kb/HT1320
If the battery is truly dead, they are pretty easy to replace. Same with the hard drive. Batteries go for about $8 including shipping on ebay, and in most cases come with instructions on replacing. One word of caution, when you pry the 2 halves of your ipod apart, there is a small ribbon cable on the top side. Try not to damage that :D
Jan 02, 2010 | Apple iPod classic MP3 Player
My Ipod Video 30 GB shows a sad face. What do i do?
It looks like there is some kind of software problem with your iPod.
First, power up your iPod (showing the sad face). Try pressing the center and menu buttons at the same time, and holding it like this until the iPod shuts off (after about 5 seconds). This should 'force-restart' the iPod.
If this doesn't work, plug your iPod into your computer, open iTunes, select your iPod in the left-hand menu and click Restore. Note that all songs/photos/videos will be erased by this procedure.
Should this also fail, you can try leaving your iPod turned on (with the sad face), and wait for the battery to completely run out (the iPod should not turn on at all anymore). Leave the iPod unpowered for about an hour, recharge it, and retry the above steps.
Hope this helped,
tS
Dec 10, 2009 | Apple iPod MA446LL/A MP3 Player
I have 30 gb ipod when my ipod is completly down i cant charge my ipod it show low battery i keep for charge for 2 hours still it does not get charge
The 5th Generation iPod (iPod video) were made and sold in 2005. Batteries inside iPods tend to last 2 to 3 years (4 if you hardly use them). It could be time to replace the battery inside your iPod.
Apr 13, 2009 | Apple iPod MA446LL/A MP3 Player
Apple iPod video 30 gb black will not start
Yes, this happens to me as well. However, it's only when the ipod has no battery life left at all. The only solution I have for myself is that I cannot plug it into the wall when it has completely died. It HAS to be plugged into the computer, that's the only way it will charge when it has reached that point. I'm pretty sure, but not completely sure, that it has to do with the battery. I'm planning on buying a new battery off ebay and installing it, just to see if this fixes anything. Hope this helps!
--Sarah :]
Jan 04, 2009 | Apple iPod MA446LL/A MP3 Player
30 gb apple ipod...
try to access the Settings on the iPod menu and locate the section where you tell it to charge.
Jun 10, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
42 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
