Question about Nikon N2000 35mm SLR Camera
Help I just found a Nikon N2000, but I don't know how to turn it on.
  • 667 Answers
There is a collar that is around the shutter release button. You lift the collar and turn it.
Posted on Mar 19, 2008
I have a N2000 how do I open it to put film in ?
Posted on Aug 22, 2009
SOURCE:
Will a nikon n2000 turn on without a lens and film?
The camera should operate perfectly fine without a lens. It should also operate perfectly fine without film (other than for not taking any pictures, of course).
I know this is stupid, but make sure the batteries are inserted in the proper direction. Then make sure the film advance mode selector around the shutter release button is not in the "L" position. L is for Lock, S is for single-frame, and C is for continuous.
If you need a manual you may download a copy here.
Apr 27, 2012 | Nikon N2000 35mm SLR Camera
Im not sure how to load and rewind film into my Nikon N2000 camera. Can someone help?
Rather than try to describe the process, I'll refer you to the illustrated instructions in the manual you can download from
http://butkus.org/chinon/nikon/nikon_n2000/nikon_n2000.htm
Feb 15, 2011 | Nikon N2000 35mm SLR Camera
How do i turn off my Nikon N2000
See my answer to your other post. Or just let the camera time out.
May 10, 2010 | Nikon N2000 35mm SLR Camera
How do i turn on my nikon n2000
A real stumper, isn't it? The reason you can't find a on/off switch is that there isn't one. You turn the camera on by lightly pressing the shutter button, and it will turn off when it times out.
You can download a manual from http://www.butkus.org/chinon/nikon.htm
Nikon N2000 will not turn on to advance film. batteries ok
Make sure there is no corrosion on the battery contacts. If a battery corroded only a little it can foul the contacts enough so no power gets to the camera. Use a pencil eraser and scrub the contacts until shiney. This is the most common problem I have with it.
Feb 17, 2010 | Nikon N2000 35mm SLR Camera
N2000 will not Turn ON
Hi Oskarr900, The corrosion may have eaten away at small wires that are on the springs that hold the battery holder in the camera. Notice those wires go into the plastic camera body. If that has happened the camera will need to go in to Nikon. These cameras are only worth $90 or less so you may want to look into purchasing a used N2000.
Jan 10, 2009 | Nikon N2000 35mm SLR Camera
Nikon N2000 35mm SLR Camera Logo
221 people viewed this question
Top Nikon Photography Experts
Ric Donato
pictureman4u
Jeff
Jeff
Are you a Nikon Photography Expert? Answer questions, earn points and help others
