Question about Kenmore 11206 / 11306 / 11506 / 11606
How to thread upper bobbin on Kenmore 11206
I have a manual, and the right size bobbin a 15k; but I cannot get the thread to wind around the bobbin. What am I doing wrong, its not even pulling from the thread, could it be that the tenion is not tight enought or maybe too tight?
  • 1 more comment
  • Anonymous May 02, 2008
    Even though I am pulling out the large knob on the side of my old Kenmore machine, the bobbin will not wind
  • daira
    daira Aug 24, 2014
    Hi, I'm having a hard time trying to thread the Barbie sawing maching 11301, would you be able to send it to us by email?
  • daira
    daira Aug 24, 2014
    I'm sorry we would like to get a copy of the Barbie sawing maching manuel. Thanks,
    New Friend:
  • 46 Answers
WAY OLD BUT .....slide the bobbin spindle from the left to the right and pull the handwheel out. YOU NEED TO DO BOTH. I never saw this til today hope its not too late!
Bonnie
Posted on Nov 06, 2008
SOURCE:
I am having problems with the bobbin its not picking up the bobbin thread through the needle
thread the upper part and the needle put presser foot down hold loose end of thread with felt hand and turn the wheel with right . the needle goes down shuttle wraps the bobbin thread around the upper and when needle comes up the bobbin thread will be with it . OR have yo MOMMA SHOW U HOW
Feb 18, 2015 | Sewing Machines
My kenmore sewing machine model 11607090 won't pickup the bobbin thread
try changing the needle
try rethreading the machine top & make sure to use
every thread guide
make sure the bobbin is turned the right way in the bobbin case
it's also possible that the machine may need to be checked to see
if there is a timing problem
Oct 15, 2012 | Kenmore 11206 / 11306 / 11506 / 11606
I need a manuel for 11206609 I am trouble with the bobbin catching and the thread is bunching. I also need to a manuel to see how to properly thread the machine.
I can't find a manual for that exact model, but I found a service manual and instruction manual for a 11206630. They will, hopefully, be close to your machine. Normanlly, when the model numbers are that close, the manuals are very close as well.
The links are http://www.managemylife.com/mmh/owner_manuals/133369/KENMORE-Mechanical-Sewing-1008846L?brand_name_search=Kenmore+11206+Sewing+Machine and
http://www.managemylife.com/mmh/owner_manuals/20676/KENMORE-Mechanical-Sewing-L0305018?brand_name_search=Kenmore+11206+Sewing+Machine
I hope these are helpful!
May 30, 2011 | Kenmore 11206 / 11306 / 11506 / 11606
How do I thread the bobbin in a kenmore 17628
you shoul check your manual.
If you don't have one,
I'am not sure what this machine looks like,
On the top part of the machine, put your thread on the thread spool,(on the right) the thread should be brought over to the left side and wraped around a small button looking piece. then brought back towards the spool of thread, bring the thread through a small hole in the bobbin, pul 2-3inch out, place the bobbin on the small metal bobbin holder and push to the right,
make sure pressure foot is up. you will need to loosen the hand wheel, hold the hand wheel with the left and and with the right hand turn the center circle back to it loosend (counter clockwise)
make sure the bobbin wind evenly
Aug 27, 2009 | Kenmore 17628
How do you thread a kenmore sewing machine I can't figure out how to thread the bobbin for kenmore machine 1385.15343600.  I am a beginner, so I will need pretty detailed instructions. Thanks! Jenny
Put the bobbin on the short metal stick on top of the machine. Unthread the machine. Put the spool of thread on the tall, left side stick on top of the machine. Take the thread and wrap it counter clockwise around the circular, short, metal thing on the left side of the top of the machine, only 180 degrees. Thread the thread through the hole in the bobbin (which should be on top). Press the bobbin to the right, into the little white thing. Pull the turning wheel on the right side of the machine out. While holding the end of the thread, softly press the presser foot so that the thread goes around the bobbin a few times. After that, cut the end down to the bobbin. Now, press the presser foot down and wind the bobbin until it stops on it's own.
Mar 05, 2009 | Kenmore 15343
Manual for older kenmore sewing machine
Manual Here: http://www.managemylife.com/mmh/lis_pdf/OWNM/1006108L.pdf
Oct 25, 2008 | Kenmore 11206 / 11306 / 11506 / 11606
Instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Jun 05, 2008 | Kenmore Sewing Machines
Threading the Bobbin
Winding. But I've got it now. Thank you.
Dec 02, 2007 | Kenmore 11206 / 11306 / 11506 / 11606
Kenmore Sewing Machine model # c877.15
I have a Kenmore as well ,I hope that this will work for you ,too bad that I don't live close to you otherwise I would give a hand. This is the way I fill the bobbin on mine. Mine is located on the top right ,I put the thread into the bobbin hole leaving a small piece of thread hanging for me to hold when I begin the winding, I pull the wheele out to stop the needle from moving while winding, when I am done just push it back in .I run the thread from the spool into the top left it looks like a U turn with a screw go around that without winding just pull it into the bobbin hole. press the foot control and it will begin winding .
Jul 17, 2007 | Kenmore 15208 Mechanical Sewing Machine
Kenmore 11206 / 11306 / 11506 / 11606 Logo
164 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Kelley Buchanan
Kelley Buchanan
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
