Question about Samsung UpStage SPH-m620 Cellular Phone
Phone Will Not Turn On
My phone started saying "Call could not be completed" when I'd try to place calls so I turned it off in an attempt to restart the phone. Instead, the phone turned off and doesn't respond to holding down the End/Power button for several seconds at a time or to the Reset button. Please help.
  • 6 more comments
  • Anonymous Mar 23, 2008
    phone will not turn on when i hit the red button to turn it on. birghtly colored "samsung" appears accross the screen but thats it.
    recharged phone, pressed reset button, tried several times to turn on and off, removed from battery case
    recharged phone, turned on and off, pressed reset button
  • Anonymous Apr 09, 2008
    the phone won't turn on
  • Anonymous Apr 11, 2008
    I'm having the EXACT same problem. Any solution?
  • Anonymous Apr 12, 2008
    someone...anyone help!
    the same thing has happened to
    me and i've only had the phone
    for not even a year...
  • lionessgirl Apr 14, 2008
    I am having this same problem right now. I turned it off because it said network not responding and now the phone will not turn back on.
  • karabear1215 Apr 24, 2008
    any luck? I just had the same problem. I tried to make several calls and i got the message "call could not be completed" I turned off the off phone and now it will not turn back on. Did you get yours to work?
Someone...anyone help.
im having the same problem
and i haven't even had my
phone for a whole year...
Posted on Apr 12, 2008
SOURCE:
Hello, my phone just stopped making phone calls, I can text without problems, but the phone will not put a call through, incoming or outgoing. It will start dialing and say the call is active but there is...
Though it may sound simple, there are a few tricks to try first.
Turn off your phone, pull out the battery and SIM card. Check your SIM contacts (little gold pieces on the bottom of the card) Are they clean? If not, wipe it off with a soft cloth. Now place the SIM card and battery back in and turn your phone back on.
I worked for AT&T customer service for a good long while and this is the very first thing they will request you to do.
Attempt to make a call - If it still doesn't work, you're going to need to call AT&T customer service as they have tools to push settings and much more. Generally if your phone is acting up it's because you've left it on 24/7 and it just needs a reboot.
May 04, 2011 | Palm AT&T C/PHONE PALM CENTRO S64801
If i attempt to take picture, the fone replied says, camera failed
Try restarting the phone completely. Take out the battery for a few seconds. turn it on and try it again. if it fails then, try resetting the phone to factory settings. if that still fails then you've got a hardware problem. if the phone is under any kind of warranty, return it to your network provider or get it fixed at a local phone shop.
Mar 05, 2011 | Samsung S8300 Ultra Touch platinium-red...
My LG kf750 secret wont start up, wont turn on. It
You could try to hard reset your device, in an attempt to sort your problems out. Be warned that a hard reset will set everything on your phone to their factory defaults, for what you'll loose all the programs you have installed, as well as your personal data. Anyway, to perform a hard reset, turn your phone off completely, by pressing and holding the power button, and, then, answering to the power off prompt. Then, press and hold the Volume Down, the Call, and the Power buttons, until the LED (at the side of the camera) flashes. Release the buttons. That LED should flash in green/red/blue now. When your device powers up, it should be completely cleared.
Hope it works for you, since this is completely theoretical. I have never done it myself.
Regards,
Carlos
May 15, 2010 | LG Secret ? KF750 Cellular Phone
The phone will not show recent calls, missed calls, etc. Tried to do a software update, however, the phone says that none are available. Memory is not full. I have attempted to turn off the phone and...
I've had the same problem 4 times. I had to bring it in to the store to get it re-flashed. That fixes the problem for 6 weeks or so, and then it happens again... It's pretty inconvenient, but other than that, there really is no other solution they tell me.
Nov 22, 2009 | Casio G'zOne Boulder Cell Phone
My Dell xps 400 will not boot up completely, then won't power off
It sounds like the machine is experiencing hardware problems. You will either need to call Dell or take it into a local computer repair place.
Nov 16, 2009 | Dell Dimension XPS PC Desktop
The camera of my nokia 6600 is not working it says "HARDWARE FAILURE: PLEASE RESTART CAMERA" what does it mean? i already reset the phone but its still the same. what should i do?
You will need to format your phone and restore it to factory settings. Backup your data before you start the format. To format:
Press *#7780# on your phone, it shall ask you weather you want to restore the phone to factory defaults? Select Yes, enter the security code (default is 12345) the phone shall restart. Now once it comes back, press *#7370# and follow the same process again. After it comes back, everything should be working fine.
In case you do not remember the security code, then turn off the phone, press the star key (*), number 3 key and Green keys (the one used to make the calls) together and keeping them pressed turn on the phone, do not release the keys until you see the formatting screen, let it complete and the phone shall restart and then it should be working fine.
Oct 24, 2009 | Nokia 6600
LG Vu voicemail icon will not leave screen
call your phone from another phone and leave yourself a new message, then go in and delete that message, it worked for me
Jul 24, 2009 | LG Vu CU920 Cellular Phone
New Chocolate 3, charged fully; won't turn on
This may mean that this is a hardware malfunction, and that it should be taken back to the place from where it was purchased for either repairs, or refund.
Some possible solutions: Take the battery out, and put it back in, then try turning to cell back on.
Call the support line for the company that sells this phone, in this case, it is LG.
Jul 21, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Limited service
If your're getting this in an area you're sure should have signal, turn the phone completely off. Then turn it back on and it should re-registered with the closest tower.
Jul 12, 2009 | Samsung SGH-X830 Cellular Phone
Phone headache
concern ur handset to care center .. get ur phone battery checked .. then try to use phone ... if posible try to use  phone with  different battery
Oct 23, 2007 | Sony Ericsson Z310i Cellular Phone
Samsung UpStage SPH-m620 Cellular Phone Logo
42 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
