Question about Sony PlayStation Portable (PSP) Console
R button problem
I tried it once it started working the next day it started again
HELP!!!!!!!!!!!!!!!!!!!!
    Problem Solver:
  • 8 Answers
Hi, its more than likely the R-button ribbon cable thats gone, a replacement one can be bought here: http://www.console-spares.co.uk/catalog/index.php?app=gbu0&ns=prodshow&ref=PSP_Power_PCB2Mboard_Ribbon
Posted on Mar 22, 2008
Set time on MSP74810W
Instructions for setting an MSP74810W watch.
Press the "Mode." button three times (the "Mode" button is the one next to the lower left of the dial when facing it).The first time you press you'll see the ST, or stop watch function, the second time you'll see the AL, or alarm function, the third time you'll be back to the time of day function but the seconds will be flashing.
Change the flashing seconds digits to read 00 by pressing the "Start" button (the "Start" is the button next to the upper right of the dial when facing it).
-To advance from the flashing seconds' reading to the hour of the day's digit/digits you press the "Reset" button at the lower right of the dial,
-To advance from the flashing hour digit/digits to the minutes digit/digits you again press the "Reset" button,
-To advance from the flashing minutes digit/digits to the month's digit/digits you again press the "Reset" button,
-To advance from the flashing month's digit/digits
to the day of the month's digit/digits you press "Reset,"
To advance from the flashing day of the month's digit/digits to the day of the week's abbreviation you again press "Reset,"
-To advance from the flashing name of the week's abbreviation back to the seconds' of the minute you again press "Reset," and from there you can go through the cycle again.
While the hour of the day with its A[M] or P[M] designation, the minutes of the hour, the month of the year's number, the day of the month's number, or the abbreviation of the day of the week's name is flashing press the "Start" button once, repeatedly, or hold it down to advance the number or letters to their correct designations.
Once all designations are correct push "Mode" so that none of the numbers or letters are flashing. Your watch is now set.
Apr 01, 2014 | Watches
I have a 1994 wrangler.must crank starter multipul times for fuel to reach fuel rail on 2.4 or 2.5 4 cyl.Once finally starts will run great all day and start.Next day starts hard again.I replaced fuel
replace the fuel pump,the check valve that holds pressure on the fuel is in the fuel pump.The fuel in the lines is draining back into the tank
Dec 10, 2017 | 1994 Jeep Wrangler
Hello, i HAVE AN ACer laptop, AND AS YOU Can see the cAPSLOCk key turns on and off randomly. In addition the toucHPAD LOCks up until i hit a key, THEN IT WILL WORK AGAIN FOR A FEW MINUTES. fINALLY , the...
Hello vickiek42, these instructions will help you, first, click on the "Start" button, in the "Start Search Window, Type: keyboard; the "Keyboard's" Properties window will open. You can (Test) to see exactly how your keyboard is responding. if you are still having the same problem, (check the Keyboard Status), try "Updating the Drivers," by clicking on the "Properties" button. Now in the event that neither of these solutions solve the problem, which I hope you shouldn't have to do anymore; try "Uninstalling the Keyboard. To "Uninstall the "keyboard," do the following. Shut-down (turn- off completely), Next, turn-on the computer, and go back to the "Keyboard Properties," this time click on the "Change Settings" button, next click on the "Driver" button, and select the "Uninstall" button. Once that is finished, shut-down the computer again. Now you want to "Reconnect" all the devices that were connected before, and "Turn-on" the computer. You will repeat exactly what you did from the start, this will "Reinstall the Keyboard. Restart the computer again after all changes have been made; this will ensure the changes take place properly.
  • Next, I will guide you through the steps to fix the "Touch Scrolling." First, click on the "Start Button" paul7of9_43.jpg in the (right, pane) select to open the Control Panel: next open the [Hardware and Sound] category, paul7of9_44.jpg click on the "Mouse" applet. Next, in the Mouse Properties" (window) click on the "Device Setting" button, paul7of9_47.jpg once the window open, click on the "Settings" button just below the "highlighted" (Name) of the device: Synaptics TouchPad. paul7of9_48.jpg Try out some of the "items listed" Tapping, Virtual Scrolling... "You must click on the "Apply and OK buttons when finished. " Note: Restart the computer; this will make sure the changes are correctly applied, and working properly. "Rating the solution will let me know if the problem is fixed, or you will need further assistance, thanks for using FixYa, paul7of9"
Jan 31, 2011 | Acer 90.46907.001 Keyboard
I have the blue screen of death
Hi , its very simple. it will work , but you need to be patient enough. It may take few hours but it will. First of all answer one thing ? did you fiddle with your comp parts, ex Ram or Hard disc or charger. if yes. Do the following. Take out the power , remove the battery, take out the Ram ( if you have two slots for ram , change the slot for one and remove other ram) . Now , press and hold the power button for 30 sec or so, connect the power and release the power button. once it starts connect the battery later on. IF you fail , do all the steps again again till it starts. Believe me it will work , I had same prob, I made a research on this , my comp is back from death. Since then its one year, no prob. You need to believe me and yourself. It will 100% start , you try for a hour or so and leave it , try again after some time or next day. It took for my research and fo my comp rebirth , nearly 15 days. But its back and 100%. I try to fiddle again with ram one day , its gone , but already I knew how to bring it back and I did it in first attempt. Once it starts , its better to reload the windows. Each time you remove the ram ( use only one ram if you have two) change the positions and remember them. You will , and you will. but remember everything I wrote. thanks.
Jul 21, 2010 | Acer Aspire 7110-2069 Notebook
Frozen buttons
I think you may need to buy a new unit not on a sptial
Jun 16, 2009 | Sony DHG-HDD250 200-Hours Video Recorder
Hp does not work when press power button
Have you tried it without the battery installed?
Nov 15, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
AFTER DOWNLOADING UPDATE FOR LOGITECH MOUSE WILL NOT WORK.
If you have XP (Green start button in left corner) you may want to try System restore. Its under Start > Programs > Accessories > System Tools > System Restore. Once you have selected that you will want to choose "Restore My Computer to an earlier time" then choose next. On the next screen you will see a calendar with bold dates. Those are the days that have restore info available. There should be one that list the Logitec driver update, Just click that entry on the right and choose next. After confirming that you have slected the correct date, choose Next again.
This will cause your system to restart and then your system should work as it did before you installed the update.
According to Microsoft, this procedure wont cause any data loss.
Since your mouse isnt work you will need to use the keyboard shortcut Ctrl - Esc to bring up start menu. (Hold Ctrl and tap Esc key) Once the menu opens, you can you the keyboard arrows to select the menu options above. Then use Enter or Space bar to choose System Restore, Once there you can tab to the options and space to select options.
Thanks
Jul 20, 2008 | Computers & Internet
Dodge ram van e250 dies while driving
try changing the coil- sometimes they get hot and break down- once they cool off vehicle will start and run until they get hot again
Jul 05, 2008 | 1992 Dodge Ram 250
Setting Bench Watch
Reset Instructions Bench. (BC0013BR)
Time and Location
If you hold in the light, start and the reset button for a few seconds a screen will appear with the 12h or 24 h clock setting and also the date and country.
Once you have that screen if you press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time.
Once you have changed the date and time to the correct date press the light button, start button and reset button and it will save the settings.
Alarm
Hold in the light, start and the reset button for a few seconds a screen will appear
press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time. Use the light button to set the screen.
Feb 27, 2008 | Watches
Sony PlayStation Portable (PSP) Console Logo
19 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
