Question about Car Audio & Video
Bad infinity amplifier
My amplifier on my 2002 chrysler 300M Pro-Am edition went bad according to the dealership (it was shorting out and causing the battery to drain) and I was told they are no longer being made nor could one be found. I thought about after market stereos but I've been told that my steering wheel controls will not work with these. I was wondering if there is somewhere I can have mine fixed?
    Sergeant:
  • 300 Answers
I know a few local stereo shops in my area (Oregon) that also do stereo repair. You might call around.
Your other option is to find out the exact model number of the amp and search eBay. When I searched, I found several OEM Infinity amps for sale, but of all different p/n's.
Posted on Mar 20, 2008
2002 Chrysler 300M heated seat problem
Make sure you have power to the seat if you do the internet sells many kits for this and step by step directions. Google it
Mar 04, 2013 | 2002 Chrysler 300M
2002 Chrysler 300M, stop lamp & park/horn circuits grounded on load side. What can cause this?
Do you know how to use a DVOM - digital volt ohm meter to trouble shoot automotive electrical circuits ? Using a wiring diagram to find testing points in the B+ power flow of the vehicle electrical circuits .
Free wiring diagrams here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model , engine size . Under system click electrical distribution , then under subsystem click power distribution . Click on the search button , then each link one at a time !
. stop lamp & park/horn circuits grounded on load side. What can cause this? A direct short to ground .
Finding The Source Of Electrical Shorts In Your Car
Electric Testing Techniques You Need to Know
Apr 29, 2017 | 2002 Chrysler 300M
Radio works, no sound though
some of these cars have infinity sound systems if this is the case the factory amplifier probably went bad and a new radio and an amp rewire will fix the issue. you might want to check the trunk too soetimes people cram all kinds of things in the trunk and you might have broken a speaker terminal on the rear deck and it is touching metal and shorting out the radio causing the sound prcesssor to turn off. hope this helps.
Aug 26, 2011 | 2000 Chrysler Sebring
Where can we get a copy of the wiring schematics for my 2002 Chrysler 300M? We have a short somewhere. The cd player is staying lit when the vehicle is turned off and the driver's seat goes crazy when...
go to autozone.com setup a profile its free, add your vehicle, and then you will have access to the automotive repair manual for your vehicle.
Dec 04, 2010 | 2002 Chrysler 300M
2001 chrysler 300m radio flashes and has power but no sound
You may have a short in the radio. I just went through this with my 2002 300M (caused by a dead battery..low voltage can cause this to happen). Spent $60 at Dealer today for them to tell me I need a new radio for $300 plus install. I found a brand new one at primelec.com for $24.99 Only 4 screws to install it, but be careful removing the surrounding face place as only pressure hooks holding it in place.
Jan 18, 2010 | 2001 Chrysler 300M
I have a 2002 crhysler 300m with a 3.5 high
Hello, Had the same problem but i did just the opposite I put a 2002 engine in a 2000. I found out that the cam sensor spocket (for the timing belt) Has the holes for the cam sensor in a different spots causing all kinds of problems also they did the same with the flex plate so I hope you took the one off the 2002 and used it or you will have to pull it back out and change it. Good luck
Nov 27, 2009 | 2002 Chrysler 300M
How can i get the factory infinity amp to turn on
the best way is to get the schematic for your specific car. that will tell you what you need (your looking for the remote/switch on wire. once you have the schematic ,if you need help reading it you can hit me up and i can help (i am a tech.) hit me up at ohmega1080@yahoo.com
Jun 21, 2009 | Car Audio & Video
I HAVE A 2003 CHRYSLER 300M SPECIAL 3.5HO AND REPLACED ALL FOUR 02 SENSORS AND STILL GET CODES P0132 AND P0152 TOOK CAR TO MY SHOP AND TOLD ME I HAVE INTAKE GASKETS LEAKING WOULD THIS CAUSE THESE CODES
yep po132 shorted to voltage po152 shorted to voltage.this means lean conditions .you got in take leak .if you get a high voltage conditions you got rich mixture.bad plugs or stop up air filter.
May 01, 2009 | 2003 Chrysler 300M
2002 chrysler 300 wont go into park
It sounds like your linkage is binding. Hold the brake down and shift between drive and reverse a few times and then into park. I had the same problem with my 2002 300m. It went away after working the shifter a number of times. DO NOT FORCE IT.
Apr 02, 2009 | 2002 Chrysler 300M
Infiniti I30 Battery+Parking brake lights on
The only thing your battery light and your brake light have in common is your battery and alternator. This happened to me and my battery was low because my alternator went bad. I suggest taking it to autozone (if there is one near you). They can test it for free.
Jan 02, 2009 | Pro-Fit Pro.Fit Ns 50 00 Infiniti I30 /I35...
Car Audio & Video Logo
175 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
