Samsung computer monitor display problem ....display is displaced to left and not centered. what adjustment buttons allows to fix. trying to help someone else. is it part of the menu button or something else.
  • SHAK139 May 11, 2010
    I HAVE A I531 POLAROID WITH NEW BATTERYS AND A GREEN LIGHT FLASHES AND
    THEN IT MAKES A BEEPING SOUND THEN CUT OFF PLEASE HELP ME
    (SHAKEEL.ARMSTRONG@YAHOO.COM)
    Genius:
  • 1,226 Answers
Hello!
Infront or in the side of your monitor there is menu option. either you select the right adjustment by selecting the left or right menu then continue pressing the until it go back to the center. refer to monitor manual for the adjustment menu of the screen.
melnavz
Posted on Mar 19, 2008
  • Emelio Navaja
    Emelio Navaja Mar 19, 2008
    In menu find the vertical or horizontal view. that is the adjustment menu.
Dell Monitor E207WFP Picture Not Centering
Try another monitor on the PC, see if that helps.
If it does, the monitor is faulty. Try resetting it to fctory settings.
If it isn't, it's probably your graphics adapter, or something in between.
First check the vga cable, then reinstall the graphics driver.
I hope this helps,
Yannick.
Jun 17, 2009 | Dell E207WFP LCD Monitor
I have a new Samsung 24'' LCD Monitor. I have alot of distortion, almost like a waving effect. Any patches to fix this?
hi friend try this:
Monitor Problems:
THE COMPUTERS SEEMS TO BE WORKING, BUT THE SCREEN IS BLANK.
- Check the monitor if turned on.
- Check all the LED power on the monitor, if it has one.
- Adjust brightness and contrast controls all the way to the maximum.
- Check the video cable from the monitor to the computer to be sure if it is properly connected.
- Check the power cable. If it is connected properly at both ends.
- Try different monitor on your computer. If it does not work, the display card is likely at fault. Replace the display card.
- Try your monitor on a different computer. If it does not work, replace the monitor or have it repaired by a trained technician.
COMPUTER BOOTS, BUT DISPLAYS “JUNK” ON THE SCREEN
- It may be that the display card is defective. Try a different card. If it works the first card may be bad.
- Try the suspected bad card on another computer. If it displays the same thing it is conclusive that the card is bad.
DISPLAY IS DIM, OVERLY BRIGHT, OR BLURRY, OR UNPLEASANT.DISPLAY IS OFF CENTER. LEFT OR RIGHT SIDE OF MONITOR IS OBSCURED.
- Try adjusting the control knobs located on either the front or back of the monitor. It maybe necessary o open the monitors casing to get the proper adjustment controls. In this case be very careful because there are high voltages in the monitor.
THE VIDEO DISPLAY FADES AND BRIGHTENS, OR IS WARY.
- The voltage may be fluctuating due to so many appliances or electric devices on he same branch circuit.
- Turn off other appliances and peripherals, such as printers, external modem, refrigerator, microwave oven, transformer, etc. and see if that solves the problem. If the problem persists, try swapping out the display cards. If changing the monitor solved the problem, repair or replace the monitor.
IMAGE IS NOT STRAIGHT ACROSS THE SCREEN
- If the monitor is still under warranty, bring it back to the dealer for adjustment. If the you want to do it your self, bare in mind that this is potentially dangerous procedure because it must be done while he monitor is on and there is very high voltages around the picture tube.
Apr 01, 2009 | Samsung SyncMaster T240HD 24" TFT LCD...
Can't Adjust Width of Display
I think the problem is that you need to find which buttons move your selections around, For the most part the Plus and Minus buttons are pretty obvious, but the movement buttons aren't always. The movement buttons allow you to scroll between the different options. There are often 5-6 buttons on a CRT or LCD monitor. Placement varies between companies. Lets get the obvious buttons out of the way. Usually, there is 1 button that clearly says Menu. Sometimes it is on the button, sometimes over. This allows you to access the full monitor menu options. Then there are the plus and minus buttons. These buttons allow you to adjust your settings. With some companies, pressing one of these 2 buttons will allow you to adjust the contrast or brightness without entering the full menu. Some companies, with more interesting montitor technology have a back button, or a degauss button, to remove magnetic damage from the monitor. This extra button(s) is(are) not common and can usually only be found in higher end monitors. Now for the 2 buttons I left out. Most companies will designate these buttons with an up and a down arrow, but not all. You might have to fiddle around with them to find out which one does what, but these buttons are used to navigate the screen between different option sets. Sometimes this is up and down movement, sometimes it is left to right. It depends on the design of the company. I've seen one that had a turnstyle-like menu screen and you navigated left or right to select the option. Once you can find out which button brings you in what direction, it should be easier to manipulate the screen to your perticular wants. I hope this helps
Mar 30, 2009 | Dell E773C 17" CRT Monitor
Brightness/Contrast Adjustment
try going to the setup screen button left of adjustments
try going to the set up menu on the left of the buttons come down to the slider control just above the information icon then go across to color reset hope this helps regards Jim
Mar 12, 2009 | Samsung SyncMaster 2253BW LCD Monitor
I cannot access the menu to adjust my aspect ratio - greyed out
Normally there are some buttons on the monitor that allow you to center the window, make it wider, etc. Also, find the button that says Degrauss..this will demagnetize your monitor and sometime that will do it...
Jan 24, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Polaroid monitor picture is shifted to left about an inch
Hi you may try
1)to key the auto(adjust) button at TV monitor keyboard if not ok,
2)to change display pixels density from PC display setting because TV monitor could not support the display pixels you using and sync.the picture on well.
3)also you may adjust monitor screen H position(it maybe not convenience for back TV).
Dec 21, 2008 | Polaroid Computers & Internet
Display is off-center
Try the Auto adjust button on the monitor buttons first.
If the entire picture of the computer is showing you can try to shift and stretch the picture through the menu button.
Sep 04, 2008 | E-Machines eMachines Monitor E15T4
Centering your monitor screen
on the monitor press the menu button in that adjust the horizontal and vertical size correctly ... you will having the option to adjust in the menu button ...
this will fix your problem ...
thank you
bye
any doubts you can reply me
i am always here to assist you
rate my solution
Mar 08, 2008 | Samsung SyncMaster 240 T 24.1" Flat Panel...
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
