Question about Biostar P4M890-M7 Motherboard
Problem i have a p4m890-m7 no mouse no key board detected icant go go to the bios setup
  • Anonymous May 11, 2010
    please check the keyboard and mouse port. else change key use usbkeyboard port.
    Genius:
  • 1,226 Answers
Hello.
the solution of yourpcdoctor is much good. in addtion to it please replace the mouse and keyboard port.
melnavz
Posted on Mar 24, 2008
    Problem Solver:
  • 13 Answers
That particular board has PS2 ports on it. I would suggest a couple of things. If you have a PS2 keyboard, plug it in and use it since legacy USB support might not be turned on in BIOS.
If that works, go into BIOS and turn on legacy USB support and then try the USB KB again.
Secondly, if you don't have a PS2 keyboard, get your manual out and clear the CMOS. It might be that the legacy USB is turned off and clearing the CMOS will re-enable that (assuming it is done at the factory).
Good luch.
Posted on Mar 19, 2008
SOURCE:
G31-M7 TE keyboard problems
you have to run the DRIVERS CD FIRST.
Apr 11, 2013 | Biostar G31-M7 TE Motherboard
I need driver vga P4M890-M7 SE for win7
It doesn't appear that BIO Star created drivers for vista/7 that I can tellhttp://www.biostar-usa.com/mbdownloads.asp?model=P4M890-M7%20PCI-E
Try the top one from the link above with XP/64 under the OS column the 64 may indicate Vista which in a lot of cases will also work on Windows 7
Nov 22, 2011 | Biostar P4M890-M7 SE Core 2 Duo/ P4M890/...
We need all driver Main board P4m890 m7 te
Aug 21, 2011 | Biostar P4M890-M7 Motherboard
I want latest vga driver for windows 7
Hello Sir,
There are some various models in your Motherboard, so you just have to choose your's from the various motherboard models provided in the link that, I have given you. After choosing the Board model, Choose the driver tab in the top of the appearing screen and download all the necessary drivers you need.
Link
http://www.biostar.com.tw/app/en/search/search.php?search=P4M890-M7
Aug 16, 2010 | Biostar P4M890-M7 Motherboard
When i start my pc a get at meeage that ram is over clk and the pc not start.tell me how to reset ram clk during startup
You'll need to clear the bios back to its default settings. There sre five versions of motherboards.
See the list below;
P4M890-M7 TE 7.x
P4M890-M7 SE 7.x
P4M890-M7 PCI-E 7.1
P4M890-M7 PCI-E 7.0
P4M890-M7 FE 7.x
I'll guide you using the manual for P4M890-M7 FE 7.x
Turn to page 17 and follow the instruction to clear the cmos. Open page 6 for a closer look of the JCMOS location. Once finished you will need to enter the bios and re-setup the settings. This time around try not to over clock the memory.
Link to Biostar; http://www.biostar.com.tw/app/en/mb/content.php?S_ID=358
Cheers'
Mike
Mar 09, 2010 | Biostar P4M890-M7 Motherboard
Key board not detected ,message on booting f1 to contunue
You could try and swap the keyboard usb connector to another usb connector, if its a ps2 connection then check in the bios that it is enabled, it should be by default.
Also if you don't have a converter from ps2-usb go & obtain one & you should be fine, assuming your keyboards ok.
Nov 08, 2009 | Biostar P4M890-M7 Motherboard
Problem
Hi CompSeller, there are three versions of the Biostar P4M890-M7. They are;
P4M890-M7 TE
http://www.biostar-usa.com/mbdetails.asp?model=P4M890-M7%20TE
CPU support for the TE;
http://www.biostar-usa.com/cpusupport775.asp#P4M890-M7%20TE
P4M890-M7 SE
http://www.biostar-usa.com/mbdetails.asp?model=P4M890-M7%20SE
CPU support for the SE;
http://www.biostar-usa.com/cpusupport775.asp#P4M890-M7%20SE
P4M890-M7 PCI-E
http://www.biostar-usa.com/mbdetails.asp?model=P4M890-M7%20PCI-E
CPU support for the PCI-E;
http://www.biostar-usa.com/cpusupport775.asp#P4M890-M7%20PCI-E
Everything you need is listed above including bios updates.
Enjoy!
If I can be of more service, just ask.
Mike
Apr 05, 2008 | Biostar P4M890-M7 Motherboard
Biostar P4M900-M7 SE BIOS ROM Checksum Error
The bios upgrade procedure stopped at half , leaving the bios corrupted. The computer now cannot do a regular boot procedure, this is the reason why it cannot recognise some device. If you are still able to boot from floppy, you can restart bios upgrade procedure from floppy. Just download floppy version upgrade and re do setup. Even if you do not find latest bios version, just download a floppy upgrade that is working, so that you can restart your machine regularly , and then do the update to latest version.
If you are not able to complete the bios setup, the only way to fix your motherboard will be flashing the CMOS chipset with a chip programmer device that will reinstall bios straight into cmos chipset.
You can have this done at the service point, in this case consider also replacing your motherboard.
Regards
Apr 03, 2008 | Biostar P4M890-M7 Motherboard
Biostar P4M890-M7 Motherboard Logo
239 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
Ekse
Thomas F. Schneider
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
