Question about Samsung HCM5525W 55" Rear Projection Television
Problems with my hcm5525w projection TV
I turned it on and things have a blue hue on them. tv is working fine except colors are bad seems to be a lt of blue. My email is grml@sympatico.ca if you can help. Thanks
  • Anonymous Mar 21, 2008
    yes i do. a few months after the warranty expired
  • Samsung Master
  • 8,617 Answers
Try turning down the blue drive see if that helps. If not you will need to trouble shoot the blue drive circuitry possibly an open resistor
Posted on Mar 19, 2008
Need a color wheel for a hcm5525w samsung
This model of Samsung is a CRT based projection TV that usues no color wheel : (
Jul 25, 2011 | Samsung HCM5525W 55" Rear Projection...
Too much yellow
change crt coolant on blue and maybe the red if he`s contamined.
Apr 18, 2010 | Samsung HCM5525W 55" Rear Projection...
NO Blue Colors on any station/program
If you are using component video cablesm make sure the blue is connected from tv to source.
Oct 27, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Uneven Color on JVC Projection TV
hello i have a jvc 52" made in july 2004 replaced bulb twice under warranty plus replaced ballast board in 2005 replaced bulb dec 2008 my tv was before and after install having a blue hue reversed words
Sep 01, 2008 | JVC HD-52Z575 52" Rear Projection...
Bad Picture Blueish picture
If the red gun stops working it could make the picture very blue-greenish. This could be caused by a number of problems, including a coolant leak, but it's most likely a bad electrical connection somewhere in the set.
Best left to a professional repair guy, frankly.
Mar 19, 2008 | Samsung HCM5525W 55" Rear Projection...
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
Blue color is now green and oranges are pink
Most likely a CRT coolant leak onto signal pcb.Look for wet
evidence........T.
Oct 25, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Problem with color
Yes you have a problem in the red crt driver board. Most likely the driver transistor is failing. This is a component level repair, so if you have no experience with TV repair, play it safe and call in a trained tech to assist you in this matter. Good Luck
Jun 05, 2007 | Mitsubishi VS-50609 50" Rear Projection...
KP-53s65 multipule problems, hoping for single solution?
sounds like 2 different problems here. first problem sounds tuner related. second sounds convergence related. third issue (cost effective to repair ?) at this point i would replace the set. i hope this helps
Mar 12, 2007 | Sony KP-53S65 53" Rear Projection...
Samsung HCM5525W 55" Rear Projection Television Logo
56 people viewed this question
Jerry Greenberg
Jerry Greenberg
