Question about iLO 2600 Television
Xbox 360 I hooked up my Xbox 360 to the component in the back and it shows nothing on the screen. Re-checked the cables, everything hooked up correctly and I still have a blue screen. What am I doing wrong? Any help would be appreciated. Dan
    New Friend:
  • 10 Answers
Http://www.wiredextreme.com/count.php?refer=2119 they can help
Posted on Jul 01, 2010
SOURCE:
How do I hook up Xbox 360 to this TV? I have no clue where all the plugs go in the back
component leads from xbox to component in on tv
Xbox 360 Component HD AV Cable
http://support.xbox.com/en-AU/xbox-360/system/connect-xbox-360-console-tv
https://www.youtube.com/watch?v=JlE2zHSoQmE
Nov 20, 2015 | Sanyo DS31590 31" TV
How do you get your xbox 360 to play, on a 65'' mitubishi projection tv,its connected but nothing comes on screen when i put a movie in just a blank screen and no sound,if i'm on a channel,the channel...
Hello
The Xbox 360 connects to a TV using either
- COMPONENT (red blue green for video, red and white for audio
- COMPOSITE (yellow for video, red and white for audio)
- HDMI
So, if your TV is on a "Channel", it is not on the correct input to view the Xbox 360.
Check the Xbox and verify which cables it is using to connect to the TV. When you find this, follow the cable to the back of the TV and find the input selection. It should be listed as the type and a number (i.e. HDMI 2, COMPONENT 1).
Have the Xbox on. Use the TV remote and use either the INPUT or the MENU options to change the input to the input that matches the port that the Xbox is connected to.
This should make the Xbox work.
When you are done with the Xbox, use the INPUT or MENU to change back to the tuner to watch TV.
Nov 03, 2013 | Mitsubishi WD-73734 73" Television
When I hook up my xbox 360 to a floor model flat screen that is probably 7 or 8 years old, there is sound but no picture. When we hook it up to our newer model flat screen everything works fine. Can you...
Are you trying to use HD? Component cables or HDMI? Component cables limit you to 720p. It's possible that your old TV doesn't support 720p or there is something wrong with the jacks. What sort of connections do you have?
Sep 03, 2010 | Microsoft Xbox 360 Console
Samsung HLR6167 keeps flickering on bright scenes
Try turning off your Energy Saving option. (mine is in Menu --> Setup --> Energy Saving).  See if that helps.
Oct 09, 2009 | Samsung HLN5065W 50" Rear Projection...
My xbox has color problems
Component, HDMI? May want to check cabling. Having the component cables plugged in incorrectly can create color problems.
Sep 03, 2009 | Microsoft Xbox 360 Console
White stripes on tv screen
Could be either really, you are using the component cables that came with the console correct? The lines look identical on both screens? If so then you are on the right track but I would lean towards the xbox360 being the culprit. I would bring your 360 into a local video game store and nicely ask them if they could hook it up to one of their TVs (they have them to test consoles people trade in), with their component cables and see if they have the problem as well. If they do you know it's the xbox and not the cables, if they don't then it sounds like you have a cable problem.
Jun 26, 2009 | Microsoft Xbox 360 Console
No video or sound.
This is usually caused by a bad graphics card on the xbox. It isn't always detected by the xbox motherboard. I'm sorry to say, but it's pretty much toast unless you can find a repair guy in your area to solder on a new vga card.
May 07, 2009 | Microsoft Xbox 360 Console
Xbox360 hd hookup problem---1080i
Your component cable is probably switched to the HD setting. You have to switch it back in order to get video when hooked up to a regular TV.
Jan 30, 2009 | Mitsubishi WS-55857 55" Rear Projection...
Plays dvds on xbox 360 fine, but no picture for games/dashboard
already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
Jan 02, 2009 | Sharp Televison & Video
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Televison & Video Logo
173 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
