Question about Panasonic DMR-E50 DVD Recorder
Panasonic DMR-E50 no power
Hi, I have this unit dont record with it much but use it for a av switcher noticed tonight it wont power on Tried unpluging for awhile holding power button no luck is it shot?Thanks
  • 185 Answers
Check the two pin power plug on the back panel.
These units have a common problem on the power board where a regulator overheats and finally blows. Sometimes even before it blows it will take out an internal fuse. If the power board is faulty the repair is easy for an engineer and not too expensive.
Posted on Mar 21, 2008
  • javerilal Aug 27, 2010
    Thanks for your solution.
    However my Panasonic wont power on when switched on>I have tried a different two pin lead>replaced the internal fuse and the fuse in plug too.
  • Palmbeach
    Palmbeach Aug 27, 2010
    Hello
    If the unit is completely dead even though you have changed the two fuses and the power lead, it will almost certainly mean there is a power board problem. Either there is a break in the connection between the power board and the mother board, or there is a break in the printed circuit on the power board due to it being burnt out (this could be repaired), or the regulator has blown and will need replacing.
    You will need to obtain an STRG 6353 regulator. These are easily available from online stores. You can then take the regulator and a few instructions I will give you to a local repairer and they should be able to fix it. Better still, if you can use a soldering iron you can fix it yourself.
    Remove the power board from the unit. It is quite easy to remove but make sure the machine is unplugged from the wall power socket before touching anything. Also, be careful when disconnecting the connector plugs and strips from the board so they are not damaged. Take a look for any areas that look darkened by overheating and are burnt. Check the printed track to see if there are any breaks where there shouldn't be. If necessary these can be bridged with wire.
    Follow my full instructions here>
    http://www.fixya.com/support/t1445531-dv...
    The procedure is for the DMR E55, but the E50 is similar. This will almost certainly bring your unit back to life.
My Panasonic DMR-E50 wont read anything ....
hi there,
there could be a few reasons for this, but the most likely is that the laser has gone in it, ie... not reading any discs. it could also just be a loose cable or connector inside the recorder. the only way to know for sure is to open it up and see i'm afraid :( if its the laser, you will have to get it replaced i'm afraid. Hope this helps
Jan 18, 2011 | Panasonic DMR-E50 DVD Recorder
Error message "remote dvd 3"
PRESS 3 AND ENTER ON YOUR REMOTE OR VICE VERSA
Aug 03, 2009 | Panasonic DMR-E50 DVD Recorder
Bubble console code for panasonic dmr e50 dvd recorder
hi have seen your plight i have a booklet with codes as panasonic codes 2017 1990 1986 1925 1910 1909 1908 1907 1905 1762 1490 1462 1362 1011 1010 0824 0703 0632 0503 0490 good luck
Aug 31, 2008 | Panasonic DMR-E50 DVD Recorder
Panasonic
There is a manual for a E50S and a E50K. Could one of these be yours? One might be close enough to help. Go here
http://www2.panasonic.com/consumer-electronics/support/
Aug 08, 2008 | Panasonic DMR-E50 DVD Recorder
PANASONIC DMR-E50
service.us.panasonic.com/OPERMANPDF/DMRE50.PDF
Apr 08, 2008 | Panasonic DMR-E50 DVD Recorder
My display on the dmr-e50 shows ready but will not turn on.
UNPLUG UNIT FROM THE WALL SOCKET & REPLUG AFTER 12 SECONDS.
Jan 23, 2008 | Panasonic DMR-E50 DVD Recorder
Panasonic dmr-e50 remote control
The aswer is in the manual that can be had on line, page 45. You have 3 different remote types, 1,2,3, All you have to do is hold down the ENTER button and the number 1 or 2 or 3 on the remote for a few seconds and it will change the setting.
Jan 13, 2008 | Panasonic DMR-E50 DVD Recorder
Remote Controle Problem
You can get a replacement original Panasonic DMR E-50 remote from various suppliers on the net or on eBay - part number is IRC85049. Just google 'Panasonic DMR E-50 remote'
Jan 04, 2008 | Panasonic DMR-E50 DVD Recorder
DVD DMR-E50 Doesn't Work
As it's been 5 months I suspect problem's been solved - how? I have similar problem, E50 recorded DVD-r's lock up after playing about an hour. RAMs and commercial DVDs play fine.
Aug 12, 2007 | Panasonic DMR-E50 DVD Recorder
Panasonic DMR-E50 won't recognise blank DVD's only
You can only record to dvd-ram or dvd-r NOT dvd-rw!
Dec 03, 2006 | Panasonic DMR-E50 DVD Recorder
Panasonic DMR-E50 DVD Recorder Logo
172 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
