Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Samsung 47 inch rear peojection ic's
Now i have figured out my problem but then ran into another one. i am hearing conflicting stories about the part numbers. my t.v. i bought used after the owner did not pick it up after a repair. anyways there are two ics in this model and they have two diffrent numbers on them. one is a stk392-040 ans the other is a stk392-010. should this be this way or should the ic's be the same part number?
  • Samsung Master
  • 8,617 Answers
Those two part numbers interchange. How ever the 392-140 is alot better IC i would put both 140s in they are more durable over the 110
Posted on Mar 19, 2008
SOURCE:
My 47 inch samsung rear projection tv, the perfect focus does not\r\nwork it say no senosr data can anyone help
Hi:
This is an indication of bad convergence Ic that needs replacing. There are two of them that needs replacing. you and inditify them because they are mounted on two large metal heatsinks inside the set. The part number you are looking for is STK392-110
Sep 24, 2011 | Samsung Televison & Video
My samsung 47 in projrction tv has blue gosting or a blue double
Thats usually related to the convergence Ics and the 3.9 ohm resistors needing replacement.
Jan 23, 2010 | Samsung HC-P4752W 47" Rear Projection...
What is conversion problems and how do I fix it on a 47 inch panasonic rear projection tv
Replace Both of your STK ICs they are big black ICs will have Part number on them Call Mats Electronics for Parts 1-800-628-1118 STKs are your convergence ICs
Nov 13, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Help me fix my 60 inch projection samsung
try unplugging the three convergence yoke plugs then try powering up the set if it powers up the Convergence ICs are bad and will need replacement.
Jul 25, 2008 | Samsung HCL4715W 47" Rear Projection...
Samsung HC-P4752W 47 in. Rear Projection bigscreen TV
You dont have to remove the aluminum heat sink. The ICs are attached with screws and then just unsolder the ICs from the circuit board and then replace the new ics into the pin hole locations after applying heat sink compound onto the back then screww the new ICs to the heat sinks then solder the pins. Very easy repair.
Jun 19, 2008 | Samsung HC-P4752W 47" Rear Projection...
Adjusting the convergance
On my 55 inch rear projection Samsung, there is a menu option to adjust the convergence. There is a manual as well as an automatic option. It is easier to do with the remote control. My Samsung remote has a button called 'perfect convergence' or something like that. you can also get to it from the menu tree pushing the menu button on the front of the set. You need to scroll through all the options to adjust color, contrast, parental control, etc. You should find it.
I assume the same is true on the 37inch samsung.
How old is the set? A number of samusng sets have problems with two large IC's that tend to burn out. This causes the symptom of colored shaddows, tend to be worse the further away from the center of the screen. I just finished doing the repair to my set. If you cannot adjust the convergence, that is most likely your problem.
May 13, 2008 | Samsung HCN473W 47" Rear Projection...
How to remove back of Samsung HCL4715W 47 in rear projection TV
the screws are identified by little arrows pointing to the screw holes. However I would be surprised if its the convergence board most times its the Convergence ICs located on the sub board
Apr 22, 2008 | Samsung HCL4715W 47" Rear Projection...
Samsung hc-p4752w
Not sure of the part number most use STK392-110 or 120s . You will need to look at the ics in your set they will have the IC numbers stamped on them they will have STKxxx-xxx whatever that number is thats the sanyo part number for those ICs
Mar 14, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung rear projicton tv 42 inch aa68-50523a
If both red and blue have moved evenly, I would re-solder your STK convergence IC's before they overheat and your forced to replace them.
Mar 14, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Red outline
You should buy a Service Manual for this set here http://www.thecdguyz.com/ before trying anything with your hdtv.
I bought my manual here and saved big $$$ doing this stuff myself.
Oh yeah, my service manual came on a cd and only cost me $13.00usd including shipping.
Merry Christmas!
Oct 28, 2007 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
44 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
