I have an Onkyo TX-SR505 sound system which runs the sound from the TV through ceiling surround speakers. When I closed the cabinet door recently, I must have hit something and now I cannot get sound except through the Tv itself. I have tried every button combination I could think of and nothing has worked. The company that installed the system seems uninterested in coming back to help. Any ideas?
  • nspector49 Mar 20, 2008
    Tried all that a couple weeks ago, no help.
    Brigadier General:
  • 6,966 Answers
Hi nspector49,
If I may add to the posts of pincer and eagle338...
It may simply be that you hit either Speaker A or B switch on the front panel. Not knowing how your system is wired, you can push either or both and determine at which point the sound will come back.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 19, 2008
  • Louie  Role
    Louie Role Mar 20, 2008
    Hi again,
    Appreciate the postback.
    I am still assuming that there is nothing physically wrong with the Onkyo and it is a matter of selecting the proper switch combinations.
    A couple of questions pls:
    1. have you tried cycling through the different listening modes?
    2. have you tried doing #1 on the different input selections?
    3. some settings would only work if Speaker A is switched on, have you tried # 2 with spkr A also on?
    4. would you know if your cable is hooked straight to your TV or to a decoder/receiver box?
    5. if you have a decoder/receiver box, would you know if it is hooked straight to your TV or to the Onkyo TX-SR505?
    6. prior to the incident causing the loss of sound from the ceiling surround speakers, would you know what input selection was used to hear the TV audio from the ceiling surround speakers?
    Looking forward to your next post.
    Cheers.
  • 4,889 Answers
The only part that can be damaged by moderate impact in a sound system is the transformer.. Anyways before you do this just check if all the connections are properly in place.. If yes then open the unit and locate the transformer(its directly connected to your power supply input) check if you notice any broken circuits like disconnected wires or any dry solders. Check everything and reportback if you find anything fishy..
  • eagle338
    eagle338 Mar 27, 2008
    Did you fix it?
    Master:
  • 377 Answers
Check the connections at the back, see if there's a loose wire connected to each other.
Thanks
  • pincer
    pincer Mar 19, 2008
    Got a scrambled video?
How do you connect the skw 360 subwoofer to the onkyo tx-sr505 av receiver
Hi Kenny, sorry you can't. The TX=SR505 requires a powered subwoofer. The SKW-360 is passive. Thank you, Onkyo USA
Dec 02, 2016 | Onkyo Audio Players & Recorders
How to connect android movie box (Mx3) to TX-SR505 receiver
The TX-SR505 does not support Video Streaming, Thanks, JT
Dec 19, 2015 | Onkyo TX-SR505 Receiver
Component Audio Not working
Hello, where is the issue, audio or video? Your question has mixed messages. Thank you, Onkyo USA
Jun 02, 2017 | Onkyo TX-SR505 Receiver
How do I hook up my Onkyo receiver to my dish network box?
Take the cables from the receiver to the tv and connect it to your Onkyo where it says "in", then take another cable and run it from your Onkyo receiver where it says "out" and connect it directly to the tv. Make sure you cycle the inputs on your receiver and tv, so you get sound and video.
Daniel Busa
DISH Network Customer Service
Jan 05, 2011 | Onkyo TX-SR505 Receiver
I HAVE AN ONKYO TX SR500 AV RECEIVER WITH A 5.1 BOSE SURROUND SOUND SYSTEM WITH SONY TV. MOST RECENTLY ONLY ONE OF MY SPEAKERS IS WORKING ON MY SURROUND SOUND. ALL WIRES ARE CONNECTED. I CHECKED ALL...
The symptom you described can be caused by any number of things. I always start with the output power transistors which are the first things to blow with a speaker output overload condition. Unplug the power cord to your unit, remove the top cover and use an ohmmeter to check resistance from C to E on all 10 of the power transistors (Q6050 thru 54 and Q6060 thru 64) attached to the large heat sink. Blown transistors typically read <1 ohm, compared to good transistors that are >10k ohms. If you find a bad transistor it will need to be replaced.
Jan 25, 2009 | Onkyo TX-SR500 Receiver
Hi We are setting up our new Onkyo TX SR606 receiver but are having trouble with the automatic speaker set-up. The 2 front speakers, centre and the back right speaker are ok, but there is an error...
Hi there. If you are running a 5.1 speaker system, make sure your surround speakers are on the surround terminal NOT ON THE SURROUND BACK. the surround back is only for the 7.1 speaker system.
Sep 13, 2008 | Onkyo TX-SR606 Receiver
Onkyo TX-SR805 - surround sound problem
The speaker impedance is not the problem.
Apr 09, 2017 | Onkyo TX-SR803 Receiver
Do all speakers need to have the same impedance? (Protect mode)
Amplifiers sometimes like to have "balanced loads" on them, and this may be the case with your unit, meaning yes, all the impedances should match.
Judging by the impedance numbers you provided, you should be all set. You really want to avoid having something like 2 ohms on the left side and 8 ohms on the right side - grossly imbalanced. I don't see any problems with what you're going to run.
Mar 24, 2008 | Onkyo TX-SR505 Receiver
Rear speakers
THE 4 WIRES SHOULD BE FROM THE REAR SPEAKERS THEY GET WIRED INTO THE SURROUND SPEAKER OUT POSTS ON YOUR AMP (MAKE SURE YOU DO NOT GO INTO SURROUND BACK THIS IS FOR 6.1 AND 7.1 SYSTEMS).WHAT ARE THE WALL UNITS? NEED MORE INFO TO TRY TO HELP.
HOPE THIS HELPED A BIT.
CABLE GUY
Feb 13, 2008 | Onkyo TX-SR605 Receiver
Only one centerback speaker
First off, I would like to say congrats on the receiver purchase - it's a nice one. To get true 7.1 surround sound, you will have to run another wire to another speaker. Any of these listening modes that you want to get are most likely using the capabilities of these 7 speakers. If you were to hook up one speaker to the two rear surround channels, you would be defeating the purposes of having that extra "speaker" and not really be gaining anything. If you really do want to access the 7.1 listening modes, you could always hook up another speaker and just hide it behind your TV, depending on your setup (essentially tuck it in a place where it wouldn't be heard, close to the receiver so that you don't need a long wire run).
In answer to your specific question, there would be ways of doing this, but just not all that advisable - you'd be posing a hazard to your speaker and/or the receiver. Like I mentioned, I'd recommend going through the trouble of running another wire and hooking up an additional speaker for the rear surround. If you're going to be using a Bluray or HD-DVD player, it'll be worth it. Hopefully this helps to somewhat answer your question.
Dec 19, 2007 | Onkyo TX-SR605 Receiver
 Grubhead
Grubhead
