Question about Envision EN9410 19" Flat Panel LCD Monitor
My envision 19 inch montitor has two stuck pixels
They are red and i have it.
Thanks for any help .
  • emesee Mar 19, 2008
    i hate the stuck pixels.
    President:
  • 814 Answers
Go to YouTube and search for stuck or dead pixel repairs. They have a few solutions that may help you out. Hope this helps you !
Posted on Apr 16, 2009
Will my Envision 19" monitor,
You will need to set the display resolution and vertical sweep rate on the computer to something the monitor can handle. The monitor works best at 1440 x 900 at 59.8 Hz vertical rate. If your laptop's graphics chip doesn't have this setting (available settings are listed in the Display control panel), then look on page 19 of the monitor's owner's manual to find something that matches a resolution listed in the control panel.
Sep 21, 2011 | Envision Computers & Internet
I install window 7 but my benq 15" lcd monitar's screen rosuation not competible. pls guide me how i increase the rosulation thnx
As for your 15" LCD BENQ Monitor, "1024 x 768" pixels is the Maximum Resolution
If you increase your screen higher than the Maximum resolution you get a black screen! because the monitor cannot support the resolution higher than "1024x768" pixels.
How to change your screen resolution Win 7-> Link
FYI
Here are typical resolutions for some popular screen sizes
19-inch screen (standard ratio): 1280 x 1024 pixels
20-inch screen (standard ratio): 1600 x 1200 pixels
22-inch screen (widescreen): 1680 x 1050 pixels
24-inch screen (widescreen): 1900 x 1200 pixels
Hope it helps.
Nov 22, 2010 | Computers & Internet
I am having a long warm up period, 20 minutes,
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
May 10, 2010 | Envision 19" Widescreen Flat Panel LCD...
Envision 19" Monitor is "ghosting" . It is about 3 years old. Just starting doing it. Nothing has really changed on my computer. Thanks for any help.
Try reseating the input cables. If that doesn't work then you could try a new input cable. Updating your video card drivers might also do the trick.
Sep 23, 2009 | Envision 19" Widescreen Flat Panel LCD...
BLOWN PIXELS
Usually not but in some cases gently massageing the dot(tv turned on or off try both) with your finger may work (dont push too hard)
or put on a channel with static and try
your chances are slim though this is usually a defect in the lcd technology and most manufactures only warranty it for 5-7 stuck pixels
Jan 05, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Envision 19" widescreen
You can go to the Envision customer support website and look for the driver under the driver support section for you model monitor. The website is. www.envisiondisplay.com. You can also call the Envision customer support at this telephone number. !-888-838-6388. They should be able to help you with getting the correct driver to support your set-up. I hope this information helps you with your problem.
Dec 27, 2008 | Envision 19" Widescreen Flat Panel TFT LCD...
Envision Series / AOC 22 hdtv monitor
Probably blown capacitors, the 19" widescreen uses 6 16V 1000uF
Do you have a soldering gun? Its not that hard to fix, get the capacitors on ebay for $6-$8 with shipping.
Oct 31, 2008 | Envision 19" Widescreen Flat Panel LCD...
Monitor
Sylvia,
It's seems you had a stuck pixal... Turn your monitor off and try this tips: Wn't work in every case. It may take a few attempts to make sure you are pressing exactly on the dead pixel.These instructions will fix "stuck" pixels, not "dead" ones, like red, blue or green. An alternative, but similar technique involves gently massaging the stuck pixel with a warm damp soft cloth.Alternative technique to tapping: Using a rounded pencil eraser, push with moderate pressure into screen at stuck pixel.
Good lucks!
May 12, 2008 | LG Flatron 295LM 22" LCD Monitor
Envision EN9410 19" Flat Panel LCD Monitor Logo
83 people viewed this question
Top Envision Computers & Internet Experts
Cleverer2
Steve
Martin Murray
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
