Question about Samsung DVD-VR357
Samsung VR357 will not record
I have my cable set top box connected to the Sansung VR357 input with an s-video cable and still cannot get anything recorded. I have the video output from the VR357 going to my TV with an s-video cable. I have the audio output from the VR357 going into my Denon AVR 1602. I get video and sound when I play a prerecorded tape. But I am unable to record anything. Any advice?
  • 2 more comments
  • Zosh Mar 19, 2008
    My problem is with recording, not playback. I can play back tapes.
  • Zosh Mar 19, 2008
    It was not previously working and now not working. I have read the manual carefully.
  • Zosh Mar 19, 2008
    Thanks, but that is not the problem.
  • Zosh Mar 19, 2008
    For this I paid?
  • 4,889 Answers
The Component and S-Video outputs are for DVD playback only. The DVD Combo will not send VHS playback to the component or S-Video connections. you have to use component if you want to record.. checkout the 6th question in the FAQ..
Posted on Mar 19, 2008
    Sergeant:
  • Samsung Expert
  • 406 Answers
Please go throuh user manual for setup;
If it was previously working now its not working then Writer might be failed or mis aligned or Improperly setup.
If both the things does not work. Cusnalt authorised service center.
Regards
Rafique
    Master:
  • 377 Answers
Check if the record lock of the tape has not benn removed..
How to connect HDMI set top box to analogue VCR and then to Digital tv to record
Most set top boxes with HDMI also have a yellow video out and white audio out for connection to a VCR or DVD recorder. Connect these two RCA cables to the VCR's yellow and white INPUTS for recording. Set the VCR to LINE input. For VCR playback, connect yellow video and white audio OUTS from VCR to your TV's yellow and white INPUTS. Select this input on the TV set.
Feb 13, 2012 | Sanyo Televison & Video
DVD-VR357 RECORDS VIDEO (FROM VIDEO1) FROM COX DVR, BUT NO AUDIO
well there the first thing i would check is the audio connection..
basically if you are recording from a playing media, like a dvf player
it would be like this
audio and video out from the dvd player to the inputs in the recorder.. then the out puts from the recorder to the input in the tv... (just a refrence)
upload your diagram, and state exactly what you want to record from.. if its the tv or another media type..
If its from the tv,, lets say you got cable and you want to record from cable,, Its
connect the out put from the cable box to the input of the dvr, then the out from the dvr to the input of the tv..
or
if its from an arial
connect the arial to the dvr,, now connect the dvr to the tv,, I guess you got the picture of what i am saying..
Basically all the out put from the media you wish to record from to the DVR and then from the DVR to the Tv..
Feb 22, 2008 | Samsung DVD-VR357
I have purchased Samsung 550 - series L5 - I don't seem to be able to hook up the VCR to it to record. I have cable on it and I would like to be enable to record programs. Television ask if I want to...
You don't record from TV, you record from cable so cable needs to be hooked up to input on VCR.
If you don't use cable box you would hook cable to VCR then out of VCR to TV. If you use cable box then you need to connect Video and Audio outputs on cable box to Video and Audio inputs on VCR and switch input of VCR to Line input.
Feb 28, 2011 | Samsung Televison & Video
I got a magnavox dvd recorder and 4 head hi-fi stereo vcr and im having trouble with hooking it up to my cable box how do i record shows on my recorder without switching inputs on my tv because i switch...
Don't hook the DVD/VCR recorder through ur cable box.Hook the DVD/VCR recorder through ur tv only it should work find.This way each units have it own direct functions to the tv.U recording the shows from the tv not the cable box ok.
Nov 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a samsung dvd recorder, whats the proper way to connect for it to work, do i connect to cable box, tv
How you connect it depends on your system. You need to connect the video out of the recorder to the TV. If you want to record programs, you need to connect the cable box to the recorder's video in. (The unit doesn't have a tuner if you have the unit listed above.)
Place the IR Blaster near the set-top box IR receiver. Connect the RF cable from the wall to your set-top box and then another RF cable from the set-top box to the TV (not to the DVD recorder). Connect a composite A/V cable from the set-top box A/V (composite) out to the DVD recorder's A/V in (AV1) port. (Composite video is a three wire cable - the plugs are yellow (video) and red/white (R/L audio).)
Next you need to connect the unit to the TV. Depending on the TV, you can use an HDMI cable (best results), component video or another composite video cable (labeled AV2 AV out). If you use component video, you'll need a separate cable to carry the audio. (Component video cables have 3 RCA jacks on each end (red, blue and green). The audio cable has the red and white plugs.
You will only get a 480 (SD) signal output if you use anything other than the HDMI cable. (The progressive scan feature is not compatible with all TVs; see the manual for details.)
You can obtain the manual from http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_name=DVD-VR375 .
I hope this helps.
(you have an additional A/V IN connection as well as a DV In port on the front of the unit)
Sep 12, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
No HDMI video signal to projector
cheak out put on samsung to set it at 720 hdmi out ect might nee dto use red green blue or s video to see menu
Feb 05, 2008 | Samsung DVD-VR357
How To hook up vr357
Hi, You use the video and audio 'out' from your cable box to the 'in' on your Vr357. You can use s-video, component video cables or the av cables that came with it. You can use your HDMI cable from the VR 357 to your television. That will be for upconvert DVD watching. The cable box connection will still go from the box into your television. Hope that helps.
Jan 18, 2008 | Samsung DVD-VR357
Recording from cable dvr
You have to hook up an AV cable from the box to the DVDR.. Out on the cable box to IN on the DVD player.
Then put your DVD player on AV1 - ( you can do this by pressing the INPUT SEL button on the DVDR remote)
Then put the Cable box on whatever channel you want to record. And press the record button on the DVDR and you will record whatever channel the cable box is on
If you can't get to AV1 then you have to disable cable box control (menu>setup>system>cable box control>off
Jan 12, 2008 | Samsung DVD-VR357
How to record ?
I don't know a whole lot about electronic equipment, but I've never seen anything connected in so many ways at the same time. Maybe the antenna and one other type of connection. The different signals from all the connections are probably confusing each other. I would try one connection at a time to see if the problem improves. Good Luck.
Dawn
Dec 16, 2007 | Samsung DVD-VR357
Samsung DVD-VR357 Logo
89 people viewed this question
Jerry Greenberg
Jerry Greenberg
