Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Wep network key
I have purchased a new laptop and do not have the number for the westell I've been using in my home. It will not connect without it....how do I get this number and where? Please help if possible
    Scholar:
  • 89 Answers
Hello, All router are set up with a default address to access the settings. Usually it is 192.168.1.1 If this is not it, google the mfg and model number and default address after it. Example: "d-link 12345 default address" This should give you links to someone that's had the same problem and has listed their default address. Hope this helps.
Posted on Mar 19, 2008
I have a 2wire 1000SW router/modem connected by an ethernet cable to a Hewlett Packard media center PC running Windows Vista. The internet Wifi connectivity problem arose after I visited a best Western...
If you check your router you will find a reset button or a little hole in back insert pin in hole and press for 10 seconds your Moden should have reset now you will have to put in your login and password to access modem
Feb 28, 2017 | 2wire Computers & Internet
I want to connect my laptop to the wireless network i have found network but it is asking for akey where do i find it and what is it?
A WEP key is a security code used on some Wi-Fi networks. WEP keys allow a group of devices on a local network (such as a home network) to exchange encoded messages with each other while hiding the contents of the messages from easy viewing by outsiders.
Search your ISP (Internet Service Provider) into the list of Available Wireless networks and connect it.If it still asks for the key then you need to call up the ISP for the key. Because they provide you wih the key whe you purchase internet connection from them.
Sep 26, 2010 | ASUS Computers & Internet
Would like to change my wep number
Welcome to FixYa! A WEP key is a security code used on some Wi-Fi networks. WEP keys allow a group of devices on a local network (such as a home network) to exchange encoded messages with each other while hiding the contents of the messages from easy viewing by outsiders. For you to be able to change the WEP key, please follow the instructions below.
1. Open up a browser.
2. Type 192.168.1.1
3. Type admin as the username and admin as the password ( if admin is not accepted as the password,try to use password as the password )
4. Click on Wireless Connection Tab.
5. Click on Basic Wireless Security Settings.
6. Scroll don on the page and you will see there the WEP key option.
7. Type your preferred WEP key which consist of 10 characters, 0-9 and A-F only.
8. Click Save Settings.
Hope this information will help. Thank you for using FixYa!
Sep 22, 2010 | Westell Wirespeed VersaLink...
I need wep key westell model 327w
Unfortunately, no one could not provide you any WEP key. WEP is a key that you set to your router so that no one could connect to your wireless network. As an owner of the network, you should know what your network key was.
If you forgot your WEP key, you need to reset the router to factory default, configure it and set a new WEP key.
That is the only way. Thank you!
Nov 02, 2009 | Westell Wirespeed VersaLink...
My new Mac notebook can not connect to my Westell
Try changing the channel setting on the Westell modem from 6 to some other channel, I chose 11 and it fixed the problem
Nov 21, 2008 | Westell Wirespeed VersaLink...
Need wep to connect laptop from school to home network while at home
YOU SHOULD BE ABLE TO FIND THE WEP KEY IN YOUR INTERNET CONNECTIONS. IF THERE IS NO WEP KEY, JUST CREATE ONE AND YOU SHOULD BE GOOD TO GO. THIS CONNECTION LINK HAS A TAB TO SHOW CHARACTERS IF THE KEY HAS BEEN ENTERED. YOU WILL PROBABLY HAVE TO REMEMBER IT, OR JUST CREATE A NEW CONNECTION WITH A NEW WEP KEY! THAT IS THE EASY WAY! GOOD LUCK.
Oct 30, 2008 | NetGear WG511 802.11g/b Wireless Adapter
WEP key for 2wire 2700
The WEP number is in a wireless router near you, you must have a wireless router been setup in your home, then you have to program it. you choose your wep key code and only will have access to this wireless network.
contact your local IT or computer repair guy to help you with this process.
Jun 13, 2008 | 2wire 2700HG-B Router (2700HGB)
Westell versalink 327w i need default password
If the 327 was never set up for wireless you need to connect to it with an Ethernet cable and plug that into your Mac and one of the RJ45 ports on the back of the 327. Type http://192.168.1.1 into your browser, this should take you to the Westell Home Page (Your Router). The default for wireless in this router is disable. There are tabs across the top on the page, select Configuration>Wireless>Basic. This opens the Wireless Operation Window. If Wireless is disabled, click arrow to enable. You can also enable and disable encryption in this same window and if you choose to use the basic WEP in the device, the WEP key is on the label on the bottom of the router. If all this is good your laptop should be able to detect the wireless connection, the default is the serial number on the bottom of the router so you will know which connection is yours. REMEMBER TO CLICK SAVE before exiting the window! Hope this helps.
May 21, 2008 | Westell Wirespeed VersaLink...
How to change wep security key
hi, sometimes if changes was done you need to recofingure you're wireless all over especially if the key has been saved on your pc to be rembered, you could actually reset your router and configure it by going to your routers gateway by doing an ipconfig you'd be able to see the gateway..launch it in your browser n youd be able to access the configuration of the versalink...i could actually give you more detail though im in a hurry, better you call your isp provider or bellsouth now att since westell versalink are manufactured by them and they give great tech support for connectivity problem...
Nov 28, 2007 | Westell Wirespeed VersaLink...
Wireless connection
It wants what is called key 1 of the wep code. You are probably putting in the password you used for wep. Look at the router config and see what the actual wep key is.
Nov 25, 2007 | Computers & Internet
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Carlos Soto
Carlos Soto
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
