Question about Jenn-Air JES9800A Electric Kitchen Range
Second repair on F9-1 Error Code
A little over 90 days ago we found when we started the cleaning cycle on our vintage 2005 range, it would abort after a minute or two and show code F9-1, call for service. The local authorized Jenn-Air repair service replaced a clock and sensor - the clock was covered under warranty but we paid for the sensor ($25) and labor ($100). For various reasons we never got around to actually cleaning the oven until now, and found the same problem. The repair guy says the parts order place now wants him to order a door latch assembly instead ($50 - not covered under warranty) , so we'll have a bill for another 150 bucks. This doesn't seem right. I thought I saw something about a door latch being the proper fix for this oven when I first jumped on the Internet with the error code late last year. Should we have to pay if someone got the wrong fix for this range? Just really seems wrong and unfair to me. And what if THAT doesn't fix it? Starting to feel like a guinea pig. Seems someone should take responsibility for the first fix not working. Any/all advice appreciated!!!
  • leithalinda Jun 02, 2008
    Don't know what the mentioned "reset procedure" is (though would like to know - where can I find that, please?), but this story got worse before it got better. We paid for the door latch assembly and installation, plus the tech supposedly replaced the control board again, and the self-clean STILL didn't work; now we got crazy messages telling us to remove the probe (which was not in place). The tech said the mfr. wanted us to replace the probe well (yet MORE money), and we got suspicious and complained to Jenn-Air. Long story short, after several no-charge factory visits, turns out that at some point the local service guy had failed to properly tuck in some wiring and it literally burned and fused. All is well now, but we'll never be calling that local guy again. He was incompetent, not a diagnostician but just a parts replacer, and was ready to keep charging us for replacing parts for as long as we were willing to pay, rather than getting to the bottom of things and standing behind his own work. Terrible experience, but we are grateful to the mfr. for finally stepping in and taking care of us. We were ready to throw the Jenn-Air out the window though we have been loyal to the brand for over 20 years.
  • 3 Answers
Stove computer needs to be re-set. as given in already posted solutions. But i will add ....keep trying . It took 7 trys but finally the darn thing reset itself. Ps I shut off power for a good 5 minutes before trying the reset procedure. also I did not hit the final cancel ( last step)
Posted on May 28, 2008
My 05 zx4 Check engine light is on for one day, off the second day, then on for two days, and now is off. Auto zone read code P0171. Really needs help !
Thats called a lean condition.. Need to check for vacuum leaks Check all your vacuum hoses and your duct work on your air filter assembley
Sep 09, 2011 | 2005 Ford Focus
What is the f7 fault code
I have the double wall ovens. The lower oven read door lock & flashed F7. Check to make sure the lock is not sticking out a bit, it is on the left side of the oven. I'm not sure if this is what the f7 fault code is, but it worked for me :)
Nov 24, 2010 | Fisher and Paykel AeroTech Double OD302...
Trouble Code 3255
Thanks for using Fixya!
1. Cycle the ignition key ON-OFF-ON-OFF-ON within 5 seconds. To cycle the ignition key ON means to turn it only as far as it takes to get the radio to come on. It does not mean to turn the engine on.
2. Count the number of times the "check engine" lamp on the instrument panel flashes on and off. The number of flashes represents the code. There is a slight pause between the flashes representing the first and second digits of the code. Longer pauses separate individual codes. For example, flash-flash-flash [pause] flash-flash represents the code 32.
A code of "55" represents end of error codes. If this is all you get then no error codes are stored in the computer. This is the normal condition for a neon.
CODE Description of Trouble Code
11 Timing belt skipped 1 tooth or more from initial learned value, Intermittent loss of either camshaft or crankshaft position sensor, No crank reference signal detected during engine cranking
12 Direct battery input to PCM was disconnected within the last 50 key-on cycles
13 No change in MAP from start to run
14 MAP sensor voltage too low
15 No vehicle speed sensor signal
17 Closed loop temp not reached or engine cold too long
21 02s sensor problem (oxygen sensor), upstream or down stream
22 Engine coolant temp sensor out of range
23 Intake air temp sensor out of range
24 Throttle Position sensor out of range
25 Idle air control motor circuits, target idle not reached (+/- 200),vacuum leak found
27 Injector control circuit
31 Evap purge flow monitor failure or evap solenoid circuit
32 EGR system failure
33 A/C clutch relay circuit
34 Speed control Solenoid circuits
35 Rad Fan control relay circuit
37 Torque converter clutch solenoid CKT or park/neutral switch failure
41 Generator field not switching properly
42 Fuel pump relay control ckt, Auto shutdown relay control ckt, No ASD relay output voltage at PCM, Fuel level sending unit volts out of range, Fuel level unit No change over miles
43 Multiple/ single cylinder misfire
44 Battery temp sensor volts out of range
46 Charging system voltage too low
51 Fuel system lean
52 Fuel system rich
53 Internal control failure
54 No Cam signal at PCM
55 End of error messages (If you get this only, no errors were found)
62 PCM failure SRI mile not stored
63 PCM Failure EEPROM write denied
64 Catalytic Converter Efficiency Failure
65 Power steering switch failure
So in your case, you are getting error 3255 right? so you are getting error 32 EGR system failure and 55 which is no other error found.
I hope you get this sorted out.
Have a great day sir.
- HotRatchet
Jul 27, 2009 | 2005 Dodge Dakota
Amana gas range will not heat up in bake mode
it turned out to be the igniter...a friend tested it and found it to be bad.....
Nov 16, 2008 | Amana AGDS902 Gas Kitchen Range
While runing the clean cycle on my 2 day old bosch hgs7282uc gas range, it came up beeping error code 120 after an hour or so of it running.
I PURCHACED A BOSCH HGS7282UC GAS RANGE 6 MOS AGO. THE DOOR WONT CLOSE TIGHTLY,THE HEAT ESCAPES AND HAS MENTED MY KNOBS ON THE STOVE
Apr 29, 2008 | Bosch Kitchen Ranges
GE Profile XL44 range
I think it's the ignitor.   Ours has been doing a very slow lighting for quite a while.  I found if I did a cleaning cycle it seems to work a little better... otherwise a new ignitor  ( Ours is gas )...  now it is flashing the probe and bake lights alternately and will not turn the oven on at all....  not so impressed at this point.....
Sep 23, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Jenn-Air JES9800A Electric Kitchen Range Logo
181 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
