I cant get the pictures to show from the sd memory card to show in the camera
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
A bit more information might be helpful. Is your problem that you cannot view the pictures on your SD memory card while the card is installed in your camera? If this is the case you might make sure the card is properly installed. Sometimes if the card is not fully engaged in the memory slot the camera will not register it. Try removing the card and reinstalling it.
Posted on Mar 19, 2008
I have a Nikon D5300. I can see the photo count number increasing, but I cannot view the images and they are not going on the SD card. Where are they? The SD card is not full.
many small Nikon cameras have memory to store images ON THE CAMERA. If you have a memory card installed that the CAMERA CAN READ it will put images on the card. if the memory card is corrupted the camera will not use it.
First Backup all IMAGES on Memory Card to COMPUTER make sure you saved ALL images. This is IMPORTANT.
After you SAVED all images you PUT Memory card back in camera and FORMAT it (Format is in TOOL Menu that looks like a wrench)
Now if you can take an images and it saves to memory card you are done. To see if they go to MEMORY CARD. Turn off camera and remove MEMORY CARD and Check.
If it STILL does not work you may have a defective memory card.
Feb 23, 2017 | Nikon Cameras
"memory full" but SD cards are empty
Not sure if it will be this, but has the SD card got locked by accident? There is a little sliding button on the side of the card, which can be locked to protect the content. My camera shows the card as full if I accidentally lock the card. You can just slide it back again to unlock it. I never noticed the button was there until I accidentally knocked it while loading the card in and out of my PC to transfer the photos.
Dec 04, 2012 | Fuji FinePix S1000FD Digital Camera
Camera locks up with SD card
Put the SD memory card into an USB card reader and plug the card reader into the USB port of a working computer to check if the memory card is working.
If the computer cannot detect the memory card as an external storage device and cannot open the files or folders and it cannot be formatted in FAT32 then the SD memory card is faulty and needs to be replaced..
Mar 24, 2012 | Sanyo Xacti VPC-S770 Digital Camera
My camera won't show any pictures from my SD card
You have to change the 'storage' to 'memory card' or 'external card' from 'internal memory' or 'camera' using the camera menu.
Dec 10, 2011 | VistaQuest VQ-5115 Digital Camera
Need help with moving pictures from internal Kodak Z740 to SD card
Hi.
You will need to use a computer, there is no option for direct transfer from internal memory to SD card.
Remove the SD card from inside the camera and connect the camera to the computer using an USB cable. With no SD card the computer will show the pictures stored in camera's internal memory. Copy the pictures in the internal memory in computer hard disk, then eventually move them onto the SD card.
Regards.
Ginko
Jul 18, 2011 | Pentax Optio S Digital Camera
Memory card says full when i put new sd 2gb card in card won't work on my kodak easyshare cw330 camera
I was checking to see if your camera had a limit to the size of SD memory card and couldn't find a thing so what I suspect is that the SD card lock has been engaged here is a diagram to show you how to unlock it.
Also any new memory card needs to be formatted in the camera before the camera can "read" it.
After pictures have been loaded to the memory card and then downloaded to the computer the memory card needs to be formatted to clean the old pictures off and make the memory card ready to accept new pictures.
Dec 30, 2010 | Kodak EASYSHARE CW330 Digital Camera
Just put a new memory card in the camera but the screen keeps showing internal memory is full
How to switch the camera over to saving pictures directly onto the SD card.
    1. Menu
    2. Cam settings
    3. Chose AUTO or SD card option and Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you still experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
    After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 16, 2010 | Kodak EasyShare C643 Digital Camera
    I put a new memory card in our Kodak EasyShare
    Your camera is only supporting SD/MMC Cards (up to 1 GB)
    The card that you currently have might be faulty. Please try another card.
    You might also need to switch the camera over to saving pictures directly onto the SD card.
    1: Menu 2: Cam settings 3: Chose AUTO or SD card option Press OK
    Dec 25, 2009 | Kodak EasyShare C330 Digital Camera
    I have a new memory card. I cant get pictures
    You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
    Oct 27, 2009 | Kodak EasyShare C330 Digital Camera
    Pictures
    You have to make sure that the sd memory card you were using, hasn't been in another camera. If it was, your camera read the memory card differently, and it didn't show you had taken any. If this was the case, put the sd card back into the camera you took it from, and hopfully it will show on that.
    If I wasn't even close, put you sd memory card in your computer, and hopefully, they will show up on there.
    I'm sorry if I didn't get what you were saying, and didn't even answer you problem. I hope this helps.
    Oct 01, 2008 | Nikon Coolpix L11 Digital Camera
    Computers & Internet Logo
    70 people viewed this question
    David Payne
    David Payne
