Question about Microwave Ovens
Whirlpool Microvave Vent Model GH7208XRQ
Error code F2-H2 is on screen
  • derbonne Mar 19, 2008
    how do I reset microwave have already tried to unplug but has same error code
  • Microwave Ovens Master
  • 9,098 Answers
It's better to reply back instead of starting a new thread.
Unplugging it for a while and then plugging it back in is how you reset it.
I put in a message to Whirlpool technical to see if they can tell me what this code is. I'll reply back when I find out.
Posted on Mar 30, 2008
  • William Miller
    William Miller Jul 05, 2008
    This may be a moot point now, but my message was deleted without being read by Whirlpool. Nice...
    There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille.
    It may contain a chart explaining the trouble codes.
    If you find it, and it does, feel free to send me a scan of it or let me know what it says this code means.
    That way I can help you and others. Thank you.
I have to slam the door very hard for it to close correctly what would cause this problem?
Incorrectly adjusted door catch. They have movement on them to allow a tight seal due to the microwave capability.
I just found the specs and instructions on it.
Whirlpool Gold 2 0 cu ft Velos SpeedCook Oven
Mar 09, 2016 | Whirlpool Gold 2.0 cu. ft. Velos SpeedCook...
Whirlpool mircowave model MH3184XP the display reads F2
There is a problem with the control pad. The membrane, or surface, of the pad may be broken or damaged somewhere, resulting in the F2 error code. This is common for Whirlpool microwaves.
Press "Stop/Cancel" twice and select a new cook program. Press "Start" to begin.
If the error code persists, press "Stop/Cancel" again and unplug the microwave. Wait several minutes and plug it in. If the F2 code appears again, it requires repair.
Replacement membranes can be found online
http://www.appliancepartspros.com/whirlpool-panel-asy-control-8205376-ap3775860.html
but the internals of a microwave are dangerous, having high voltages even when unplugged. With the cost of parts and labour from a service tech, you may be best buying a new oven.
Sep 04, 2013 | Whirlpool MH3184XP Microwave Oven
My microwave vent cover is sticking (grease?) & I can't release it to clean. Anjy suggestions?
Magnetic vent cover also has one popular feature. It can be painted or applied wallpaper over it and can even be covered with carpet to blend with the room and remain unnoticeable.
Jan 14, 2013 | Whirlpool Gold 2.0 cu. ft. Velos SpeedCook...
Whirlpool ADG 4956 - problem F2
Hi, here is the answer for f2 "F2 - error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.
Reconnect power to the range and observe for an hour.
If the error code reappear - replace the control board.
If not - replace the membrane switch.
Apr 24, 2011 | Whirlpool Microwave Ovens
Error message on a whirlpool microwave oven ''F2 H2 Hood Keys scanning''
The F2 H2 error code refers to a faulty hood/light switch. This is a combonation board located just behind the buttons on the left panel. The part number for the switch board is 8206049. Since the screws holding this left panel on are only accessable with the door of the microwave removed, I would recommend this repair to be done by a profressional repair person.
Apr 18, 2010 | Microwave Ovens
Whirlpool microwave gh7208xrq totally dead 20amp
In many Whirlpool models, there are several fuse and thermal cutouts (TCOs) / thermostats.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Jan 30, 2010 | Whirlpool GH7208XR Convection / Microwave...
My new Whirlpool oven Model number GBD 279 PVS02 error code EO F2
F2 E0 is a shorted keypad. Replace the keypad which is your entire touch pad. In rare cases your ERC or electronic range control can also be bad, unlikely though. Hopefully this is still under warrantee as the part alone is over 150.00. I recommend you have a technician replace this as most parts houses will not warrantee a electical part if a customer installs it. Good Luck, Appliance Specialists.
Dec 15, 2009 | Microwave Ovens
Microwave Ovens Logo
724 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
