Question about HP Compaq Evo Notebook N600c
Evo n600c notebook
When i jiggle the power cord, it flickers...but wont come on anymore. what is the problem the cord or the socket. can i change out the socket. i noticed when looking at used evo's that this section is damaged sometimes.
    Novelist:
  • 119 Answers
Hi, your problem is the DC socket Plug on the motherboard. This is a solution 5$ (for the plug only) and soldering iron and solder. If it is within warranty give it straight away for repair at their cost. THIS IS a VERY common problem to HP laptops. Dont Accept anything other than a full repair. (requires dissasembly of the plastics to expose the connector and be able to resolder it.)
If it is out of warranty then find the plug, and DIY or engineer friends may be in order :) If you send it to 3rd partie tech shops they may charge 100-150$ for a 5$ spare part..the rest is their time spent and many six packs.
Regards
Posted on Mar 27, 2008
LAPTOP SCREEN IS BLACK AN FAN ISNT WORKING
Sounds like your power cord/charger got fried. Either that or the motherboard. Bring it to a pc shop and have them test the power cord/charger.
Jun 30, 2012 | Compaq Evo N600C PC Notebook
LAPTOP SCREEN IS BLACK AN FAN IS NOT WORKING
Sounds like your power cord/charger got fried. Either that or the motherboard. Bring it to a pc shop and have them test the power cord/charger...
I Have A Compaq Evo N600c Laptop No Power Help!!!
Yeah it could be. Always use the correct adapter mentioned for your laptop. Otherwise it could harm the inner wirings and the motherboard. Always go for the right adapter. If it was any motherboard problem, atleast it would've blinked. So this might be the problem of your adapter or may be of the power button.
Apr 18, 2010 | Compaq Evo N600C PC Notebook
Evo N600C, display is 'dim' and mainly 'red'
There is one CCFL lamp on the bottom edge of the LCD screen.
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 04, 2009 | HP Compaq Evo Notebook N600c
Compaq evo n600c battery wont work
wrong battery for it or connectoers on battery dirty could be the charger for the battery is bad and shorted battery out
Mar 26, 2009 | HP Compaq Evo Notebook N600c
My touchpad wont work
Go to control panel + mouse + device settings to see if the synaptics touchpad is enabled otherwise you can download the touchpad driver from here to reinstall it. Post your results back here.
Feb 25, 2009 | Compaq Evo N600c Notebook
Need help with Evo N600c battery Pack
Wouldnt fancy taking one apart myself, replacement ones are not very expensive, look here on battery trader , Compaq Evo N600c laptop battery
Dec 08, 2008 | HP Compaq Evo Notebook N1000c
Fried something?
A half volt will not make any difference. Sounds like the power supply is malfunctioning. Start by trying a different one. Keep in mind that you may have fried the new motherboard by using a faulty power supply. Popping sounds indicate a short or loose/exposed wires, and are never good with any electrical device, especially a laptop since they are sensitive to power fluctuations to begin with.
May 14, 2008 | HP Compaq Evo Notebook N600c
EVO N600C 'S POWER SUPPLY
Sounds like the power adapter connector on the motherboard needs to be replaced. or soldered in tighter.
Mar 23, 2008 | HP Compaq Evo n610c Notebook
EVO n600C NOTEBOOK battery not charging.
1. Check the socket u pluged it in
2. have the charger tested for continuity.
Mar 14, 2008 | HP Compaq Evo Notebook N600c
HP Compaq Evo Notebook N600c Logo
99 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
