Its not connecting to my computer, and some of the songs sound like they are skipping or a broken record.
  • btenl Aug 09, 2008
    when i plug it into the computer it dosent conect it charges but dosent synic
  • snazzy tie Feb 21, 2009
    i have a T10, it used to connect to the computer fine
    now it doesnt connect to any computers and instead just charges.
    and suggestions?
I have been researching the same problem for hours. It seems the operating system may be one issue. If you are running XP like I am I have read that you need to update the service pack.
Others have written that the t10 works on other computers. Some have also suggested installing Media Player 11.
Good luck. let me know how you go..
Posted on Aug 09, 2008
Im recording a song on adobe audition 1.5 and it suddenly starts skipping. why would something like this happen?
It could be your sound card, driver, or computer hardware not meeting adobe's requirements. Follw this detailed troubleshooting list. http://kb2.adobe.com/cps/331/331631.html
Feb 03, 2011 | Adobe Audition 1.5
Itunes skips during music playback
Boot to safemode and see if it does the same thing.
Oct 16, 2017 | Apple iTunes
Turntable swingarm skips to last song
Most likely your stylus (needle) is bent, broken or missing. Check to see if it's there or not. If it's broken or damaged, you will need to replace it. Under the cartridge, you should see a small arm that has the actual diamond on the end of it. If the arm is there, but the diamond is missing off the end, the arm won't stay in the groove and will instead skip across the record to the middle.
Mar 01, 2009 | Sony PS-LX250H Turntable
Downloaded songs appear in iTunes library but won't play on comp
I had exactly the same problem and followed the OP's solution, which worked, but I couldn't hear the track as it was being recorded.  So I tweaked the solution.  If you do the following, you don't have to keep changing System Preferences as you switch from record to listening:
Go to System Preferences, press the Sound icon, and click on "Sound Effects."  Then select the drop down menu and select "Play alerts and sound effects through selected sound output device" rather than the USB choice.  Then click on "Output" and select how you want to listen; I used speakers so I selected "Headphones" where the port is "Built-in audio."  Then click on "Input" and select the USB choice.  Now record a track and you can hear it being recorded through your speakers (or headphones).  When it's done recording and after the software transfers it to iTunes, you can play it again through your speakers without going to the preferences panel.
Dec 25, 2008 | ION Audio iTTUSB Turntable
Sandisk keeps skipping/freezing songs!
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Apr 13, 2008 | SanDisk Sansa E280 MP3 Player
Recording not right
Check the recording buffer latency on your recording software. And so you know, you should max your ram out with that soundcard. or have everyone record there parts in as, 5 ins is alot for a machine to process, especially if youre recording to 1 track..brutal, and the final recording will be real muddy.
Keep me posted.
Oct 25, 2007 | Behringer (UCA202) Sound Card
Skipping songs
We could try formatting the player and after the format has been complete try updating the firmware of the player. Change the settings fo the player to MSC then connect to your computer, open my computer and right-click the player and choose format remove the tick mark on the quick format and after the format has been completed. Unplug the device and go to the sandisk website and download the firmware update and install it and when it ask you to connect the device hook the plyer and perform the update for the player. Note: It may be the songs on the player are not that properly transferred that why it is skipping and also the player might also have had bad sectors that is why we have formatted the player. Hope this helps.
Jun 24, 2007 | SanDisk Sansa E280 MP3 Player
My Sansa skips the songs I put on it, what can should I do
I restored settings to default factory settings and has been working and not skipping the songs. Restoring to factory settings does not delete any of your data/songs
-Raj
Nov 27, 2006 | SanDisk Sansa e250 MP3 Player
106 people viewed this question
 Grubhead
Grubhead
