Question about Garmin StreetPilot c340 GPS Receiver
Why does my garmin c340 tell the wrong side of road a house is on?
My unit at times allow me to go about 100yards past the address before it say I have arrived at my destination.
  • 97 Answers
This is common with most GPS receivers not just yours. It has to do with your position relative to the Sat. and the amount of processor utilization looking for triangulation readings. Basically its a brief signal deterioration on one or more signals so your device is lagging a bit.
please rate. thanks.
Posted on Mar 19, 2008
SOURCE:
My Garmin StreetPilot C340 is not allowing me to enter an address - when it prompts for state it's blank and won't allow me to type my state, so is my food screen, lodging and fuel won't come up. Yet it...
There is a small pinhole on the bottom or right hand side of the unit for reset. Try hitting this with a paper clip or pin. If that doesn't help you may have to take it into a store.
Apr 14, 2010 | Garmin StreetPilot c340 GPS Receiver
I just upgraded my garmin c340 and now it tells me to get off of the freeways and to take side roads..i do not know how to fix this. i just returned from a family reunion in oregon, i live in denver, co....
You can set the unit to avoid highways. It sounds as though this setting has been turned on. Press the wrench key at the bottom of the main screen. The press "Navigation." If "Avoidances" says "Enabled", press it. If there is a checkmark next to "Highways", press and remove it. Then press "OK". This should correct the problem.
Oct 22, 2009 | Garmin StreetPilot c340 GPS Receiver
My Garmin C340 is dead!!!!
I had the same problem on a trip. Required two fixes and once I did this the unit worked fine.
1. Replace the fuse in the car adapter (reason it wasn't charging when I used it in the car).
2. See the users manual on page 31 regarding resetting your C340.
http://www8.garmin.com/manuals/StreetPilotc340_OwnersManual.pdf
Jul 21, 2008 | Garmin StreetPilot c340 GPS Receiver
C340
Try resetting the unit. There is a reset button under the faceplate. Carefully remove the faceplate with the Garmin logo with your fingernail or a knife blade. There is a reset button along the right side. I bought a refurbished C340 and it did the same thing right out of the box. The tech support people where I purchased the unit told me how to reset it.
Jun 11, 2008 | Garmin StreetPilot c340 GPS Receiver
Address
I found out that my road is not on the garmin map,therefore it goes to a road or street
that has the same house number
Hilroy
Apr 23, 2008 | GPS
Can't finish typing street address or city before choices are given I don't need
If the unit is not allowing you to continue to enter the street address, press the back button until you get to the city. Press "Search All" instead of the name of the city and try the address again. It could be that the unit has the address listed in a different city (it sometimes goes by how the post office lists the ZIP code). See if this helps. As for taking the unit apart to access the reset button, all you have to do is remove the faceplate. There is an intentation under the top. Insert your fingertip and pull it forward. Carefully remove the faceplate, and the reset button is on the right hand side.
Feb 26, 2008 | Garmin StreetPilot c340 GPS Receiver
Display problem
Have you tried resetting the unit? It sounds like you may have a problem that Garmin needs to address. I would try to reset it first, then make sure you have the latest firmware loaded on the unit. If you still have the problem, it may have to be sent to Garmin for repair.
Feb 07, 2008 | Garmin StreetPilot c340 GPS Receiver
Locating Satellites
I had the same problem and i plugged mine in the car for about 10 mins and it works great now
Dec 25, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
157 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
