Question about RCA TH1101 MP3 Player
Computer does not acknowledge it is connected to usb port
And it will not let me load songs on it. also songs that are on it skip.plugged it into my home theatre and it lost songs and the problem started after that.
  • 1 more comment
  • Anonymous Mar 19, 2008
    won't work on computer and it skips songs
  • Stellaet Mar 19, 2008
    my computer does not recognize the mp3. It did initially, but does not now
  • Anonymous Mar 22, 2008
    Changed the battery it lost over half of the songs on it and now I plug it into my pc and it does not show up as connected anywhere. The mp3says connected but, the computer does not read it at all. I have returned three others before this one all for the same reason. How do we fix it??
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
There are two possibilities - corrupt DB or songs in wrong format.
If it is a corrupt DB, then go to RCA's website for the latest firmware upgrade.
http://support.rcaaudiovideo.com/downloads.aspx?product=25
Make sure the songs are in the correct format. Make sure the songs are not AAC, WAV, streaming, or some other non-supported format
Mp3 players are more complicated than ever. This player may only accept DRM-encrypted WMA files. I would first check the songs that you have downloaded to make sure they did not have "temporary" licenses with a fixed end date. You can do this by right clicking on an individual song, clicking on properties, and selecting the "license," "digital rights mgmt" or "media usage rights" tab - the wording varies by configuration. It will give you info on the license. If the song says that it has no license, it will not work with this player. One remedy is to use mp3 converter software to convert all of those wma files to Mp3's - I don't know of any free ones, but you can certainly look for free Mp3 Converters. Another remedy on unlicensed songs is to hit the "acquire license" link in the license tab, if one exists.
-Tha Mp3 Doctor
Posted on May 24, 2008
SOURCE:
How do I delete songs from my ipod from a usb port on a computer?
First plug your i-pod 1st generation into my usb port on your computer.
Then download and install Sharepod. when the it appears right click the selected song and delete it, in the main menu
Mar 14, 2012 | Apple Audio Players & Recorders
I have a yamaha ypt-400 and i want to record what im playing, how do i do that?
The easiest way to record what you're playing in your ypt-400 is through a computer. There is a feature in it called "USB Connectivity" which allows you to play your songs in your computer and same time allows you to download songs from the internet. Once connected, you can create a folder in your computer storing all the songs you played in your ypt-400 . Once it is stored, you can replay those songs in your computer via winamp or media player. To connect to the computer you need a USB cable that will allow you to plug it to the USB port of your YPT-400 and to the USB port of your computer. You can buy this cable from any store that supplies electronic gadgets and accessories. One more thing, you can even email those songs to your friends. Try it.
Jul 24, 2011 | Audio Players & Recorders
Computer does not acknowledge the usb connection can't find driver on disk Using Vista
Make sure you're plugging the USB cable from the machine intoa USB port in the BACK of your computer, not one of the front ports or a porton a USB hub. The cable and machine need more power than most of those portsprovide, a technical detail that Singer doesn't realize. Good luck!
Mar 26, 2011 | Singer CE-200 Quantum Futura Computerized...
Itunes wot connect to ipod also ipod plays music but when i try to skip songs it freezes for about 10 sec then it plays again.
Try connecting to another computer's iTunes. If the computer recongnizes it, it could mean that your computer's USB ports are malfunctioning.
Jun 25, 2010 | Apple iPod classic MP3 Player
Computer does not acknowledge the camera when connected via usb
in that case try to use other usb cable, the n plug it directly to the usb port of your motherboard at the back of your cpu casing, try to use all the port, if they did not work, now you can use now a card reader, put your memory card to the card reader then plug it on the mothernoard usb port
Jun 30, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
RCA RT2870 USB won't allow playlists or let me skip folders
I have this same system and it looks like the USB playback is lacking this feature, of switching folders. A workaround is to use shuffle play to jump to one of the last songs in the first folder, then turn off shuffle and skip forward a few songs until you get into the next folder....and so on. Not very good, but for this price I was glad to have USB playback.
Some generic MP3 players will work in the USB port, but they play exactly the same as a USB drive. SO no real solution for this.
Jan 16, 2009 | RCA RT2760 System
Windows vista does not acknowledge Opal M4002a
If the player is not recognize try to connect the mp3 player ona different usb port and check if it will be detected if still not detected better connect this mp3 player to another pc and check if it will be detected on that second pc if not detected there's a possibilty that the mp3 usb functions is not working fine.
Jun 20, 2008 | RCA OPAL M4001 MP3 Player
Samsung mp3 player crash
Hi undercover. I don't have experience of your actual model, but I've had a similar thing happen to my Inovix MP3/4 player when it crashed (also crashing my whole computer!) and went completely 'dead'. Plugging it into the USB port had no effect - no charge symbol and the computer didn't even acknowledge something was being plugged in. Basically, I kept on trying every time I was on the computer! 2 days later, I plugged it in and 'ding-dong' Windows XP recognised something was in the USB port. I then carried out a Firmware re-load using the supplied disc, and my player burst into life! Firmware crashes are pretty common with various players, I believe. Depending on how old your player is, try the manufacturer's website to see if they've updated the Firmware. Good luck.
Aug 29, 2007 | Audio Players & Recorders
Usb connect then removes player repeatedly
have you tried to insert it at the other usb port in your pc? cause the port that you are using might be already defective try to use the other port.
Jul 27, 2006 | Creative Labs MuVo V200 MP3 Player
RCA TH1101 MP3 Player Logo
54 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
