Question about Toshiba Satellite A105 Notebook
Ac led blue battery led amber will not power on
When i press the power buton on my Toshiba Satellite A105-S2716 nothing happens. no lights no nothing. when i plug the ac adapter in the ac led turns blue then a few seconds later the battery led comes on amber but still nothing when i press the power buton.
any help would be greatly appreciated
  • 1 more comment
  • eddie  dahlgren
    eddie dahlgren Mar 19, 2008
    update ..... it seems that my laptop has turned into an expenive battery charger because after an hour of being pluged in the bat led turned blue also. but still does nothing when i press the power button
  • eddie  dahlgren
    eddie dahlgren Apr 04, 2008
    turns out it was a cracked solder conection on the motherboard only alowing power to get to the battery and not any further . i repaired the solder conection then i was having trouble with a corupt bios. managed to get it flashed to the latest and now everythings fine.
  • Mark Williams
    Mark Williams May 11, 2010
    In which case check the output voltage of the power brick.
    Genius:
  • 1,027 Answers
Check with toshiba, they have an update on this link
On my Toshiba M105-S3051 the reset switch is a pin hole above and to the left of my microphone jack on the front.
Posted on Mar 27, 2008
  • Mark Williams
    Mark Williams Apr 04, 2008
    I just had to replace the power adapter on a Nobilis N243S8,
    OH BOY, WHAT A JOY.
    Problem Solver:
  • 10 Answers
When The Light Is Blue You are getting Power To The Unit. Have You Tried removing the battery Leave The Power Cord Pluged Into The Side Of The Unit. Then Try To Power The Unit Up Again. If Nothing Happens. Chck The manual I Think There Is A Reset Button Somewhere On The Machine Most Toshibas Have Them Somewhere. Hope This Works
sosec
Posted on Mar 23, 2008
2 Suggested Answers
MUKHTAR
  • 2022 Answers
SOURCE: toshiba a100 laptop
remove the battery and connect power adoptor and try to on
Posted on Mar 25, 2008
Thought I should add more detail about what the laptop is doing. The laptop sat for a long time with a dead battery, because the power supply low voltage wire got chewed by one of our puppy's when it was...
from the web -
1 Removed the battery
2 Removed the AC power
3 Plugged in the AC power again
Note:- At this point the light from flashing amber light to solid green indicating AC Power
4 Plugged in the Battery
Note:- Solid green AC power light and Amber charge light
Oct 30, 2013 | Toshiba Satellite C655D-S5084 Laptop
Toshiba satellite 1005 s157 laptop powers on and then turns off
it could be your ac converter in your laptop.. best bet would be to check the memory, take both the batteries out and try restart it without batteries.. if non of this works i believe it might be your ac con...
success
Jun 18, 2012 | Toshiba Satellite Computers & Internet
I have a Toshiba Satellite A105-S2716 its about 3 years old and I have tried all extended life batteries but they don't charge.
Toshiba had issued a bulletin and a BIOS upgrade (version 2.0) to address the battery not charging/working issue (it's a bug in the system is what it is). Make sure that's done before contemplating any hardware changes or repairs.
Aug 22, 2011 | Toshiba Satellite A105-S2716 Notebook
Are all Satellite A105 15.4" screens the same? I
The LCD assembly will have a part number either on a paper sticker or printed on some empty real estate. Check for one that matches the structure of part number(s) listed on eBay.
You can start with the link below:
Toshiba Satellite A105 LCDs
Aug 07, 2011 | Toshiba Satellite A105-S2716 Notebook
How do i get toshiba satellite A105-S2716 Drivers to install?
Here is the site to download the driver...
http://www.drivershq.com/drivers/Toshiba/Satellite/A105-S2716/4183/9941/10714/Drivers.aspx
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Oct 16, 2010 | Toshiba Satellite A105 Notebook
Toshiba Satellite Blinking battery light
Its certainly power issue..... i have had a similar problem with one other toshiba notebook and it was a dying battery....i suggest you to get a new battery for ur set...
May 05, 2009 | Toshiba Satellite A105 Notebook
Power
1: verify that the Power Adapter is putting out 19.2v
If not, replace the adapter
If it is, then the problem may be in the on/off button console, the front MOSFETs that acts like an electronic switch. OR a small ceramic fuse.
in all honesty, you should provide additional information.
Battery charge light on?
Power light on?
Noise?
Fan turns?
Is the light on on the power supply?
Is the battery charged?
Jun 27, 2008 | Toshiba Satellite A105-S2716 Notebook
Toshiba a100 laptop
Definitely try without the battery. These models are known to have a "short" problem, usually with the palm rest, which causes this failure, although it usually is more sporatic, and doesn't happen 100% of the time.
Also, can you remove all but 1 piece of memory.
Good luck, and let us know what happens.
Mar 19, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 Notebook Logo
300 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
