Question about Kenwood SW-38HT Subwoofer
100watt sub MY sub has a constant buzzing bass sound coming out of it... whats the deal?
  • Anonymous May 26, 2008
    it has a constant buzzing and it gets louder when the volume is turned up
  • Warren Laurent Oct 10, 2008
    Fuse blown, replaced fuse - blown again....another fuse and smoke coming from heat sink /circuit board connection.
    Is it worth taking to a repairer?
    Warren Laurent
    Cedargrove Qld Australia
  • 4,234 Answers
There is a problem wwith teh power supply or the amp section. Does the noise remain constant or does it vary in volume? The sub should have a level control, does the noise vary with that control?
Dan
Posted on Mar 20, 2008
PROBLEM WITH SUB WORKING ON A PIONEER VSXAX5I RECIEVER
The problem is in the powered sub, the buzzing sound is caused by one or more defective audio output ic's that drive the subwoofer directly, service is the only option to remedy the situation.
Apr 14, 2012 | Pioneer Audio Players & Recorders
I have a few problems. i have 2 amps and 4 subs. first problem is when i connect one amp to my speakers it just hisses and crackles. this never happened before. when i turn up the gain to try and get...
The first amp, sounds like there is straight power going through the gain instead of it being limited. The second amp...hook the other subs up to it and see if it sounds ok. If so, then the subs are messed up. If it sounds the same, make sure the subs are connected correctly.
Oct 21, 2009 | Car Audio & Video
Audio buzzing
Check the cables because this sound comes when the polarity of wires interreact with each other.
May 07, 2009 | Vizio GV42L 42 in. LCD Television
Unwanted bass coming out of my subs
there has to be sumthn hooked up wrong bc i have had same problem with my 12' subs but it was simply a matter of my rca jacks but sense you have checked them try rewiring the speakers if that does not work then your rca module may be burned out within the amp..iso then check the amp by taking the cover off and making sure nuthn is burned on the inside.or if any wires are loose or touching.
Feb 24, 2009 | Kenwood eXcelon KAC-X812D Car Audio...
Sunfire True Sub Constant Hum & Thump on Initial Signal
IF THE SUB HAS AUTO SIGNAL SWITCH THIS OFF BUT TO BE HONEST IT SOUNDS LIKE YOU HAVE A SPLIT VOICE COIL.
Jun 20, 2008 | Sunfire True Sub Signature Subwoofer
ZX1500.1 Major Problem
If the subs are pushed to their limits straight out and remain there as long as the amp is on, the amplifier probably has shorted output transistors. If the speakers are moving in and out like they would be on a bass note, there may be something wrong with the shield ground of the head unit.
Dec 13, 2007 | Kicker ZX1500.1 Car Audio Amplifier
Subs will go off the wall with bass, but not in tune with music.
hi, first disconnect the rca input, then switch on headunit and if the amp produces a constant bass thump it then means it has an internal fault. if the amp idles quietly then replace the rca cable, or try connecting the headunit lineout feed directly to the bass amp, in this way you cud find out if your fault is coming from the headunit or the equaliser. cheers
Nov 23, 2006 | MTX Thunder 8302 Car Audio Amplifier
Kenwood SW-38HT Subwoofer Logo
253 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
