Question about Sharp VC-A560U VHS VCR
Vcr not working
Hello, I have a Sharp vcr and the -/+ buttons all of a sudden don't work either on the vcr itself of the remote
My sharp vcr VC-H91cannot be switch on. only the standby light is on
Posted on Mar 26, 2008
I have a remote oneforall i need codes for a SHARP VCR please help need codes
There are two codes for Sharp. You'll have to try both to see which one works. 0048 & 0807. I am assuming you don't have a manual.
On the remote press and release the VCR/DVD button. Press and hold the SET button until the LED blinks twice. (it will blink once when you first press it, that doesn't count.) Just wait a few seconds. After it blinks twice, release the SET botton, and enter the CODE..
The LED should blink twice. Aim the remote at your VCR and press
POWER.. The VCR should turn on. If not, try the other code.
0048 worked on mine. Good Luck!
Aug 15, 2011 | Universal Remote Control Remote Control
Tip
Acessing Menu with universal remote
We used a One4All model URC3021BOO remote. We programmed BOTH the TV function and the DVD/vcr button with code 0807.  To access the menu PRESS TV then MENU button then DVD/VCR button will allow you to change menu functions using left and right and select buttons. *TV button will access Menu screen BUT NO menu functions. * DVD/VCR button will NOT access menu screen but WILL control menu functions if menu is already displayed. May work with other sharp products, or other universal remotes? These original (RRMCG1330PESA) remotes run 38.00+ to buy new so try this FIRST!
on Oct 29, 2008 | Sharp 13VT-J100 13 in. Combo
Would you happen to know the 3 digit manufacture code for a Sharp VC-H992U Video Cassette Recorder? I need this info to input it into my TV so that the VCR will work with the TV. The TV provider is Dish...
Hello! Here is the link to our remote codes, if that fails follow these additional steps for the Power Scan this should resolve it as well.
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
***BEFORE STARTING THIS USE THE INSTRUCTIONS IN THE LINK TO PROGRAM THE REMOTE TO 222
  1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate (about 3 seconds), then release.
  2. For AUX mode Power Scan ONLY: press 0 for a TV, press 1 for a VCR/DVD, press 2 for any other device, then press *.
  3. Press and release the Power button.
  4. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
  5. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
  6. To verify the code works try several different functions for that equipment.
Daniel Busa
DISH Network Customer Service
Dec 23, 2010 | Sharp VC-H992U VCR
I need the remote code for a Sharp 27F541. I tried the codes provided by Charte Comm for their universal remote and none of them work. Thanks.
Hello
The Universal remote code for Sharp are [01 and 02].
Four digit remote codes for sharp are
[0079- 0123- 0063- 0020- 0004- 0009- 0226- 0266- 0006- 0095- 0122]
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Nov 07, 2010 | Sharp 27F541 TV
I have a Magnavox DVD/VCR combo that I have lost the remote to. I have bought universal remote after universal remote trying to get one that will work the DVD player or at least will setup the date and...
Universal remote does not work with Magnavox combo of dvd vcr, because no dubbing button. But magnavox has many remotes that will NB884, NB559, NB677.NB627 which also works on Sharp dvd vcr combo.
Nov 05, 2010 | Philips Magnavox Learning Universal Remote
Getting a specific channel on the TV without using a remote
Usually if you go into the setup menu, there is an option to allow you to either "scan" for a channel, or "input" a channel. In this case, select "input" and see if the TV will allow you to press the up and down channel buttons and go to a specific channel. If so, when you get to channel 4, press the "add this channel" option (or whatever the menu option says) and you should then be able to go to channel 4 using the buttons on the front without skipping over it.
Jan 24, 2010 | Televison & Video
Hi i have a sharp tv vcr combo please can you help
Hello Sandra,
This is the code that you will need for you Sharp Tv combo ' 179 '
Hope this helps you out.
Cheers Little Dish Fitter
Oct 11, 2009 | Zenith ZN110 Remote Control
No remote specific to Sharp combo unit..how to turn off closed captionning
on some models the menu button is on the front disguised as the volume up/down or channel up/down buttons. you have to push both up/down buttons on either one of these to bring up the menu.
Apr 24, 2008 | Sharp 13VT-K100 13 in. Combo
I don't know how to program my remote anymore!
I had the same problem and typed in the model of my vcr instead of the remote model. This is the site I found, although my tv is not on the list, I followed the steps at the bottom of the page and found that code 08 worked for my Phillips TV. I hope this helps all of you with finding your codes and programming your remotes.
http://www.remotecodelist.com/remotes/sharp/sharp_vch982.html
Jan 14, 2008 | Sharp RRMCGA342WJSA Remote Control
Sharp VC-A560U VHS VCR Logo
308 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
