Panasonic Television We have a Panasonic model CT-32G19 television. Is is HD compayable. or do we have to get a converter? Thank youo
  • 8,617 Answers
The CT-32G19 is a standard TV you will need a converter
Posted on Mar 19, 2008
SOURCE:
Panasonic color tv remote model number EUR7613Z70 manual
You will usually find the instructions for using a remote control in the manual for the TV that the remote came with. For the Panasonic EUR7613Z70, this includes the CT-36E33. Panasonic has the manual on the CT-36E33 product page: http://shop.panasonic.com/support-only/CT-36E33.html . The direct link to the manual for the CT-36E33 is currenlty ftp://ftp.panasonic.com/television/om/ct-27e33_mul_om.pdf . The section on the remote starts at page 8.
I hope this helps.
May 16, 2018 | Panasonic Televison & Video
Television problem
HELLO!!
FROM WHEN ARE U FACING THIS PROBLEM ???
Dec 30, 2007 | Panasonic CT-36HL43 36" TV
Does a CT-27614A need a digital converter for antenna?
According to http://www.dtv.gov/consumercorner.html#faq9
I hope this soultion is helpful.
How can I be sure that I am buying a digital TV (DTV)?
By law, beginning March 1, 2007, all television reception devices (including TVs, VCRs, DVRs, etc.) imported into the U.S. or shipped in interstate commerce must contain a digital tuner. Retailers may continue to sell analog-only devices from existing inventory, but must prominently display on or near the analog-only device a Consumer Alert label with this advisory:
What is the difference between “Integrated” DTVs and DTV or HDTV “Monitors”?
An Integrated DTV set is a television with a built-in digital tuner (also referred to as “a DTV”). A digital tuner is also sometimes called a DTV decoder or DTV receiver. If you have an Integrated DTV, you will not need any additional equipment, with the exception of a broadcast antenna (either a rooftop antenna or “rabbit ears” connected to the set), to receive over-the-air digital broadcast programming. Integrated DTVs can also receive and display analog broadcast programming, so you can continue watching analog broadcasts.
In contrast, a DTV Monitor is not capable of receiving digital broadcast programming without additional equipment; it is simply a display device without the processing capability for DTV reception. A digital or HD set-top box must be connected between the antenna and the monitor to receive and display over-the-air digital or HD programming.
If you have a digital or HD “Monitor” and would like to purchase a digital or HD set-top box to view over-the-air programming, confirm with your retailer that the set-top box is compatible with your Monitor.
Feb 12, 2009 | Panasonic Televison & Video
Not DTV ready?
it meens the tv set is in dtv and the dtv conection is not set up.
hd tv is a red blue a green cable.
and the antena conection needs to come from a converter box if signal is coming from antena if from sat or cable you should have a hd box that feeds your set.
hope this helps.
daniel.
Jan 13, 2009 | Panasonic CT-27SC13 27" TV
Analog or Digital?
This TV is analog and will need a converter box when Analog TV is turned off in 2009.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 10, 2008 | Panasonic CT-20D11 20" TV
Panasonic television
I had the same problem, however mine was a 32inch. It is a blown fuse. It is not the power cord. What you need to do is find out what fuse voltage you need. Hope this advice helps. I have a panasonic model CT-32SX12C.
Aug 20, 2008 | Panasonic CT-36SX12 36" TV
Is this?
This is from page 5 of the Operating Instructions:
TV set can
receive 480i signal only.
This means the television is NOT high definition, it is a STANDARD definition television.
Mar 15, 2008 | Panasonic CT-36SL13 32" TV
Comcast Remote Code for Panasonic CT-2707D
panasonic expects a 5 digit code. add a 1 to the codes lists, worked for me. 10250, 10051
Jan 23, 2008 | Televison & Video
Tv wont come on had a powersurge hasnt come on since why?
TV fuse open /replace
If same proiblem fuse pop the power IC was shortage.
Jan 03, 2008 | Panasonic CT-32G19 TV
My Panasonic Television
sounds like you either have a bad vertical deflection ic, or a bad resistor supply power to the ic. i'me not sure of the location, but panasonics usually put it in ic401.it is a ic with 10 to 16 pins all in a row. it will ne screwed to a small heatsinkthe making on the ic should start with laXXXX. x being numbers. good luck
Feb 05, 2007 | Panasonic CT-32D30 32" TV
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Ekse
