My battery was low on my Toshiba laptop, so I plugged in the recharger. As I did so, my computer died, even though I thought my battery was at 20%. Now my laptop won't turn on even though it's plugged into the recharger. What should I do?
1)Reason
a.No voltage.
b.External shot circuit or overcharge, anti-charge
c.Cells expansion and short circuit caused by direct anode contact and continuous high efficiency electric current overcharging.
2)Solutions:
a.Check if the battery is without voltage or electric current.
b.Avoid short circuit.
c.Avoid collision and pressure among batteries.
d.Charge the battery after it automatically powers off , then full charge the battery.
check above hope it help your laptop.good luck to you!
if you nead to buy a new Toshiba Satellite A100-S8111TD laptop battery please visit:http://www.buy-battery.ca/laptop-batteries.php/1+toshiba+satellite--a100-s8111td------(with--intel--celeron--processors)
if not match model please find one here:toshiba laptop battery
Try removing the battery and running the laptop just on the p/s. If it
works like this the battery is dead. Otherwise the laptop has a problem.
If
the battery is dead, buy a new battery or run it on p/s alone.
Laptops
should be run on battery alone as much as possible, or the battery dies.
