Question about Motorola Mobility H700 Wireless Headset
Headset want work
My headset want pick up to my phone
    Sniper:
  • 84 Answers
The connectin must be bad or it might be one it is not compattel with you phone
Posted on Mar 31, 2008
The headset picks up but it doesnt answer the phone. CS70 NC headset.
If it's not answering the phone, your phone may need to be programmed for auto-pick up so that it automatically opens the telephone line when you turn on your headset. Also, make sure the round compatibility dial (located to the left of the base) is set right (not between numbers and most phones work on setting #1).
Good luck from Headsets Direct - 800-914-7996.
Aug 09, 2011 | Plantronics CS70 Wireless Headset
How does a regular headset work? I plugged it into the back of the phone, but don't know how to make it pick up...
if the headset is a wireless one there is a button on the headset itself you need to press to pick up or hang up a call. alternativly look for a headset or pick up button on the phone needs to be pressed. this i diffulcult to answer further without knowing the model of your headset.
download user manual for the phone at the following
http://www.tc.mtu.edu/voice/equipment/Mitel5220/5220userguideR4.0.pdf
check page 23 regarding using heaset.
when the phone rings press the headset feature on your phone and then select the ringing line button.
then press cancel to hang up.
I hope this was useful.
Jan 05, 2011 | Mitel 5220 IP Phone
Try to connect it to my boost mobile phone and the phone does a scan but doesnt picks up the bluetooth signal from the headset
Try this:
First, turn your bluetooth headset off. Then, start the scan to locate the headset on your phone. Just as the scan starts, turn your headset on. You may have to do it a couple of times to get it to work - but most headsets only go into pairing mode for a short few seconds just after being turned on.
Feb 06, 2010 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Can I pick up an incoming phone call by pressing a
You should be able to take the call by pressing the center button on the earpiece.
Dec 01, 2009 | Motorola Mobility Bluetooth Hands Free...
N99i dual sim phone - can't connect bluetooth headset
not compatible througe the cell towers you may have to contact the service provider for other hardwear options.
May 02, 2009 | Dual Electronics N99i Cellular Phone
Have the 6408D+ phone. Got a Plantronics CS55 Wireless Headset.
You can use an handset lifter accessory, such as the HL1 or HL10 to pick up the handset every time you need to use the headset.
Dec 12, 2008 | Avaya Definity 6408D Corded Phone
Whole house ringing when cordless phone is used
try deleting all headsets using primary headset (marked with no.1): 4-base/8-deregister/default pin '0000' and register them again using each headset (3-headset/8-register/same pin). it worked for me.
Oct 20, 2008 | Lands Phones
HEADSET
A button must be programmed as a "headset" key. When activated, it will lamp red, and put the conversation on the headset jack under the phone (next to the handset jack).
Or you can purchase a headset with an auto lifter for the handset. It picks up the handset enough to answer the call, but transfers the conversation to your headset.
Apr 14, 2008 | NEC DTU 8D-2 Corded Phone
Connect/Program Headset
Sure you can do it. as long as the headset has a plug for the handset your fine. Plug it in and you will have to pick up and hang up the handset as needed. The headset key eliminates you having to pick up and hang up the handset to answer with the headset.
Feb 21, 2008 | NEC DTU 8-1 Corded Phone
Headset stopped connecting
ya it happened to me once ...press the pick up button and hold for 4-5 seconds till the blue light lights up then unfold it and then search
Oct 26, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility H700 Wireless Headset Logo
35 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
