Question about GE Nautilus 24" Built-in Dishwasher
GE Nautilus Dishwasher No water when i turn it on
I just recently moved into a new house and the dishwasher does not work. we are renting so i dont know how old everything is but i can hear a motor running but no water fills the dishwasher.
  • Anonymous Apr 25, 2008
    same problem
You need to prime the dishwasher by placing two large cups of water into the bottom.
Posted on Jun 18, 2008
Hi, I have the same problem with the same brand. Have you solved this problem? Or any experts can help? Thanks.
Benjamin
Posted on Jun 16, 2008
  • 52 Answers
Check and make sure the water supply is turned on under the sink. Someone may have turned it off if the place was empty for a bit.
Posted on Mar 25, 2008
We just moved into our house and are using a 4-5 year old Bosch dishwasher. It leaves a white film on everything. We use the recommended dishwasher detergent (Cascade powder) and Jet Dry. My wife is...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Aug 11, 2011 | Dishwashers
It takes 4 hrs to wash a load of dishes and when it's done there not clean. I've noticed that it doesn't make the washing noise, the water jut sits at the bottom and the soap is still in the...
heatman101
Jul 28, 2011 | Dishwashers
My GE nautilus dishwasher does not start and not getting water supply.
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble
No Water entering Dishwasher
heatman101
Dec 20, 2010 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus 24" Built-in Dishwasher - Does not stop filling with water
Hi
Thanks for using FixYa. If the dishwasher is overfilling it's caused because of water-inlet valve going bad. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. If the water-inlet valve is defective, you need to completely replace it. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 08, 2010 | GE Nautilus 24" Built-in Dishwasher
My Asko dishwasher is not producing water
Hi, Welcome to FixYa. Based on your description that the dishwasher is indeed filling with water but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump. First though, do you hear a quiet sound ( it will be super quiet if the wash impeller is broke so you have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver ) of a motor once the unit has completed filling with water ? If so that is a tell tale of no wash action yet the motor runs, hence broken impeller. If you don't hear anything it may be a wire come off the main motor/circulation pump...but not likely. Let me know what you find and I'll try and help you move forward from there. Good luck, Macmarkus :)
Aug 02, 2010 | Asko D1796FI Built-in Dishwasher
Wipers dont work. you can move them by hand. dont hear motor running
if they are moving freely by hand your wiper gears are striped out or something is broken in the linkage,you can get a new assembly at auto zone or most parts houses
Feb 23, 2010 | 1993 Chrysler Concorde
We dont know how 2 turn it on just moved house n no instructions aeg oko favorit dishwasher
Looks like what you need is available at
http://www.serviceforce.co.uk/pdfs/U20206.pdf
Good luck with the new house. Hope the dishwasher works well for you.
Try to run it with dishwasher cleaning kit (no utensils) to make sure everything is clean - that way you will get more life out of it. The cleaning kit (usually Finish) is sold in the supermarket in the detergent section.
Jan 31, 2010 | AEG 18 in. Favorit 54750Vi Slim-Line...
GE Nautilus dishwasher. Doesnt seem like motor is working
Dishwasher (Nautilus) not draining into sink but leaks onto floor.
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Blades will not turn
The motor probally damaged while you are moving the fan to the new house.
Jul 06, 2009 | Casa Vieja Probe Brushed Nickel Ceiling...
GE Nautilus 24" Built-in Dishwasher Logo
498 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
