Question about Eureka 431A Optima Bagless Upright Vacuum
Brush roll not spinning
I have a Eureka Bagless Optima 431 Lightweight Upright that is not working. I took it apart to clean the brushroll and have tried to put it back together several times, but the brushroll will not spin anymore. Maybe I'm putting the belt in the wrong spot? Where can I find a diagram or something?
  • 1 more comment
  • coolperson_s Jan 15, 2009
    i took it apart and the white wire was disconnected im not sure where it is supposed to connect. anyone know?
  • cyndi89 Jan 17, 2009
    I bought a eureka optima and the brush will not work on the carpet unless you stand it upright it is only 6 months old. I love the sweeper but now i can't vacuum my carpet
  • Anonymous Mar 26, 2014
    I took it apart and forgot how to put it back together
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=414813&thid=453845
Brushroll not spinning
Posted by vistaloopy on Mar 19, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka 431A Optima Bagless Upright Vacuum. You have only 2 choices, the belt is either side driven belt or the belt is a center driven belt and the brushroll has one side that is for the belt and the side driven brushroll and the motor pulley must be in line in order to work properly, you may want to check the bearing holders, some vacs will mark the ends with words like NEW or USED and both have to be identical in order to fit right. Once you have the brushroll out it should spin if you set it on it’s side and if that happens you are OK, then watch the ends of the brushroll. Align the end with the motor pulley, B4 install the belt place the belt on the pulley side and install the brushroll. Then once the brushroll is in and spins properly, and then you can use a belt puller and stretch the belt onto the motor pulley and then track it in a straight line. If you need further help please feel free to contact your local vac dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept for U.S.
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 10, 2008
SOURCE:
How to replace the motor for the roller brush on the Eureka Optima upright lightweight 431
If you can hear the motor but the beater bar doesn't turn, it's the belt that needs replacing. If you don't hear a thing when it's plugged in and turned on, then you need a new vacuum. Besides, the part, if you could buy one, may cost half of what a new unit will cost. Treat yourself!
Cheers,
Chance
San Diego, CA
Oct 25, 2017 | Eureka Vacuums
I have a Eureka 5902AVZ and the brushroll does not work. when i remove the belt, which is not torn nor worn out, the motor spins perfectly fine. Though when i put the brushroll back into place, it shows...
Hi and welcome to Fixya. I am Kelly.
You have correctly identified the problem as the brush roll itself.
There is a bearing under each end cap of the brush roll. You can gain access to the bearings usually by gripping the browah roll end caps and rotate the caps in opposing but loosening (ccw rt / cw left) directions.
Many times I have found that there is just a mass of hair under the end cap that functions like a brake. Clean it up really well on under BOTH end caps.
Do a spin test by putting the end caps back on (Hold it horizontal) and rotating the brush roll with your thumbs. It should spin freely.
If it feels like there is still friction then your probably going to have to take the brush roll with you down to the nearest vacuum cleaner repair / supply shop and get 2 new bearings. Most shops will install the NEW bearings for you if you have the brush roll in hand. It is a much cheaper fix than the brush roll itself.
(buy a new belt too!)
Take care
Kelly
http://www.eureka.com/servlet/ListParts?model=5902avz
Feb 10, 2010 | Eureka 5902AVZ Bagless Upright Vacuum
Reset button for Eureka 431 bagless upright???Where is it?!
If the red light is one the says "check brushroll" then you have to take it apart to find out what the problem is. It might be that the roll has too much stuff rapped around it so you have to take it out and clean. It could also be the rubber belt is not properly in place. Once you take the bottom off the belt should go on the far right side. Those are the only things i can think of. I have had mine for 3 years and have never seen a reset switch. Usually when my light comes on it is because there is a lot of hair rapped around my brush roll.
Jan 17, 2009 | Eureka 431A Optima Bagless Upright Vacuum
I need help changing belt on my Eureka Optima
If you're not familiar with how the vacuum is put together, taking it apart can be a real pain. Thankfully, most of the screws on the unit are the same size and type. For the ones you need to remove, a #2 Phillips should do the trick.
Unplug the vacuum, and flip it over, flat on the ground.
Press the silver button on the neck where the roller head attaches to the body and pull the head off. This isn't completely necessary but it makes it easier to work on.
Remove the 12 screws holding the case together. There will be 2 smaller (I think) screws by where the head swivels. Keep track of those.
Once ALL the screws are removed, the case should be loose and pretty easy to remove.
Flip it back over and carefully move the top cover to the side.
If you're looking at the piece head on as if someone were vacuuming facing you, the belt side of the brushroll should be on your right.
Remove the far side (non belted side) of the brushroll first by lifting it straight up.
The belt should be slack enough to remove the belted side of the brushroll and replace the toothed belt.
When reinstalling the brushroll, stretch the belt a little and put that side back first. Trying to get the belt side in after doing the far end takes too much effort.
Make sure the belt is tracking straight by rotating the brushroll and adjusting the belt as needed.
Since it's all opened up you may want to give it a good cleaning too.
Reverse the rest of the steps to put it back together.
Sep 13, 2008 | Eureka 431A Optima Bagless Upright Vacuum
Broken piece
You will have to replace the brush roll, part #60844-5, belt # 61120B. You should be able to get them from a repair shop, get the right one or it won't work right. You maybe able to go eureka.com and order direct.
Mar 01, 2008 | Eureka 4700A Maxima Bagless Upright Vacuum
Eureka optima 431A
Belt number is 74376, there should be screws on the bottom, take those out and the top comes off, or the top and bottom come apart. You will want to clean evrything so the brush roll will roll easily.
Dec 18, 2007 | Eureka 431A Optima Bagless Upright Vacuum
Eureka 431A Optima Bagless Upright Vacuum Logo
2,316 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
