Question about Nintendo GameCube Console
My gamecube problems.
My gamecube has not been working lately because it will not spin the disc but for a few seconds if it spins at all. it also can not read the disc, what can i do?
    Problem Solver:
  • 8 Answers
If the disc does not spin or spins strangely, it is almost always because the gamecube is having problems reading the disc, and not a problem with the motor. The laser can be adjusted to a higher power, but you will need several special tools to do so. You should be able to find a guide by googling for gamecube laser adjust. If that doesn't solve the problem, you either need to replace the laser or the laser control board.
Posted on Mar 24, 2008
  • Anonymous Mar 24, 2008
    Previous assumes that you cleaned the laser with a q-tip and rubbing alcohol, and that the disc is known to work fine.
SOURCE:
My gamecube disc's won't spin at all it makes a weird noise after a couple of seconds too.
Well maybe the motor might be shot or the lens is out of anglement then. Buy a wii instead because wii's are better than gamecube are.
Sep 27, 2011 | Nintendo GameCube Console
Press play, red light comes on, disk spins for a couple of seconds then stops, why?
Gamecube disc reader advance fix video Well I think that the lens went out of anglement then.
Sep 13, 2010 | Nintendo GameCube Console
My gamecube does not spin the discs that i put into it and does not read them. Is there something i can do to fix this without having to buy a new one?
One time I ccidently touched the lens in my 10 year old gamecube so now the lens and the laser dont read the discs anymore because it is knocked out of anglement so you could buy a new gamecube now or buy a wii because wii's can still play gamecube disc's too.
default.jpgGame Cube Disk Read Error Fix (Advanced Skill)
May 19, 2010 | Nintendo GameCube Console
Every time I put a game in it will play for a good while and then all of sudden it will say, problems reading disc check owners manual, or something like that.
This is not nessesarily a solve issue, however it worked with mine, I had the same issues when playing games. I would be in the middle of gameplay, and the the error screen would pop up and say that the disc coudnt be read, All I did to fix the issue was open the unit, blow the dust off the disc drive motor and attatched ****, then I used some 3 in one oil on all the motors inside the system. So far it hasnt messed up (FINGERS CROSSED) I hope this helps.....I noticed with my gamecube that it would quit spinning the game, and after I made it past the gameplay loaded in memory it would error out because it needed to spin the disc and load more programing into memory.....if your disc dont spin you are guarenteed a disc read error
Sep 26, 2009 | Nintendo GameCube Console
I bought a gamecube online and it wont spin the disk
Sounds like you need the Gamecube sensor switch replaced. That is a small door device for detecting when the Gamecube DVD door or lid is closed allowing disc initiation to begin. When your Gamecube doesn't detect disk at all and simply continues the message: "Please insert a NINTENDO GAMECUBE DISC," this is the problem. You can test this by inserting a game disc, opening the Gamecube door, and then closing it. If the message "Please insert a NINTENDO GAMECUBE DISC" remains unchanged, and there is no spinning of the disk, then your GameCube lid closed door sensor is probably broken and should be replaced. You can search Google for Part GCPT032, or for GameCube Lid Closed Door Sensor.
An easy fix if you know how to open the Cube. It's cable simply plugs in, and it is held by one tiny screw.
Sep 05, 2009 | Nintendo GameCube Console
Gamecube game won't play
try cleaning you lens or cleaning your game disc.
Jun 30, 2009 | Nintendo GameCube Console
Disc wont read and game won't spin
I Had The Same Problem! And I Have A Solution. Unscrew the top off and look inside.
there is the off and on switch on the opposite side to the right of it are 2 little switches, they have probably been displaced, they must be held back, the problem is they are running the disks around and it they aren't in the back they wont do anything.The Laser Should Be Cleaned using a Q-tip and Peroxide. Don't Use Too Much Just Clean Off The Laser, If That Doesn't Work, Its A Problem Inside The Machine, And is Extremely Hard To Fix, If Thats Your Problem, I Would Just Buy A New One For 99$ Rather Then Paying 80$ For Some Guy To Look At It And Say You Cant Fix It, If He Can Fix It, You Were Lucky, But If I Were You, I Wouldn't Take That Chance, Try What I Said, It Worked For Me, Now My Cube Is As Good As New. XD
I Really Hope This Has Helped You.
-XoX-Alyy-XoX-
Nov 03, 2007 | Nintendo GameCube Console
Gamecube console
You may have to adjust the POT of the GameCube lens... The POT is basically the power and spread the lens uses to read discs... the problem is, over a long period of time, the POT figure drops down, and if it drops too low, you will need to replace the lens.. The machine could still be salvageable, and play games and load them faster than before if you adjust the POT on the machine.. Here is a guide on what is required to open up the machine and do it, if you feel it necessary.... http://modthatcube.pxn-os.com/content/pot.htm
Apr 01, 2007 | Nintendo GameCube Console
Nintendo GameCube Console Logo
237 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
