Question about Brinkmann 810-2300-B Grill
Grill will not heat up
Although our tank is full, the grill will not start. The little side-burner will power up nad works fine, but the grill...no way. We hear a "whoosh!" but the grill does not start. Help! Have had this several years and it has been great...up to now.
  • teeg Mar 24, 2008
    I have the same problem, only a little different. It lights but you can barely see the flame. It only heats to 200 degrees.
Same here i have no utter clue to the solution, only the main burner will light up if the other two are out and then when i flick one on they all die, it is a horrible instrument
Posted on Apr 20, 2008
I don't have the same problem. Have had mine for several months and all works fine. I espically like how the bread bakes on the grill part.
Posted on Jul 06, 2008
I thoroughly cleaned my Weber Genesis Silver A and have a full tank of gas. It won't get hotter than 250-300 degrees. Flames are blue.
You might have air block. When turning off the grill, leave one burner on and shut the tank valve.
When grill cools, close the remaining valve. When restarting the grill, open the tank valve, then the start burner, then the igniter. When first burner is going, open remaining two valves to preheat the grill.
This has worked on two different grills.
Dec 30, 2010 | Weber Genesis Silver A Grill
Grill won't heat up above 200 DEGREES with a nearly full tank
Try replacing the regulator and hose, not very expensive and fairly easy to do. If that doesn't help, let me know.
Jul 11, 2010 | Weber Genesis Silver B Grill
Grill will not light
If there is no gas check the tank, If the tank is fine look at the regulator. It has to be flat, because of a valve inside. This is a safety device incase of tipover.
Apr 14, 2010 | Jenn-Air JLG7130A
Grill lights but flame is low and goes out if control is moved from high. Burner tube is clean, spider screen is clean, and I have a full tank of LP. Grill is Q series about 1 year old and has been working...
Hello. Are you frustrated because your gas grill doesn't get hot enough lately. The problem you are having indicates that you have to go through a procedure called "RESETTING THE REGULATOR". Follow these easy steps:
1. Turn the burners on for one full minute and then off.
2. Next, remove the regulator and the hose from the tank.
3. Then reconnect the tank to the regulator and hose.
4. And very slowly open the tank.
5. Last step is to fire up the burners and start cooking with you new hot flame.
The problem began the first time you opened the valve on the tank too quickly. In the future, always turn the tank valve on s-l-o-w-l-y to prevent this problem.. Joe
Mar 22, 2010 | Weber Q Grill
Char Broil grill w/full tank and cleaned air jets, no heat
try opening the tank really slowly. if you open it too quickly the overfill protection devise in the tank will restrict the gas flow to the burners. hope this helps.
Sep 17, 2009 | Uniflame FG2204C Grill
Outdoor grill with no gas pressure, little heat
TURN THE TANK OFF , THEN REMOVE BURNER ASSEMBLY AND CHECK FOR OBSTRUCTION IN THE GAS LINE AREA . IT IS NOT UNCOMMON FOR SPIDERS TO BUILD WEBS INSIDE THE TUBES AND CAUSE MAJOR PROBLEMS
Aug 22, 2009 | Jenn-Air Grilling
Low heat from weber grill
turn tank off disconnect from grill make sure all knobs are turned off including side burner reconnect tank make sure fitting is all the way on tank turn tank on and try again
Aug 15, 2009 | Weber Genesis Silver C Grill
Propane grill
I had this problem when I turned on the burners before I turned on the tank, to fix it I had to turn everything off. Then turn the tank on and wait about a minute for pressure to build in the lines then turn on the burners. Hope this helps
Jul 10, 2008 | Uniflame FG2204C Grill
KENMORE Gas Grill 141-152210 Kenmore 437 sq. in cooking will only heat to 250 degrees
sudsy, this exact same thing would happen to me every time I changed a tank. I know it's nothing to do with the grill itself. I would have to seat and reseat the regulator hose to the tank a couple of times before it would start heating normally. Your model has 3 burners and I suspect that the flame is real low on each one even on the high setting. Try connecting and disconnecting the tank a couple of times and see if it comes to life. If worse comes to worse you can order a new regulator hose. Part number P3632L. Catriver..post back.
Apr 03, 2007 | Kenmore 437 sq. in. Cooking Area Gas Grill...
Brinkmann 810-2300-B Grill Logo
156 people viewed this question
Top Brinkmann Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
